Date/Time: Thu, 23 Jan 2025 09:53:02 +0000
Change TPO Price increments
View Count: 1969
[2018-11-15 16:05:39] |
User573770 - Posts: 8 |
I used TPO charts. My data feed for E- Mini (ES) is in .25 increments. ie. 2716.00,2716.25,2716.50,2716.75,2717.00 The Chart displays in Whole number increments. 2716.00, 2717.00 … I am trying to get it to look like the 11-13-2018.png Note: increments on Right are .25 |
2018-11-14 Sierra TPO screen 1.PNG / V - Attached On 2018-11-15 16:01:34 UTC - Size: 54.09 KB - 444 views 2018-11-14 TPO Setting Screen.PNG / V - Attached On 2018-11-15 16:01:43 UTC - Size: 154.09 KB - 340 views 11-13-18.PNG / V - Attached On 2018-11-15 16:01:50 UTC - Size: 854.46 KB - 361 views |
[2018-11-15 18:32:37] |
You need to adjust the Scale Increment setting in the Scale window for the TPO study. Refer to: http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleIncrement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-15 18:34:03
[2018-11-15 18:33:21] |
The post above has been updated with the correct link.
[2018-11-26 16:31:37] |
I never received response from last post I still cannot get charts to show a row at every .25 Tick. (Only whole numbers) Please see last post THanks |
[2018-11-26 17:57:29] |
We did respond. You need to adjust the Scale Increment setting in the Scale window for the TPO study. Refer to: http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleIncrement And also refer to: Time Price Opportunity (TPO) Profile Charts: Letter/Block Price Increment in Ticks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-26 18:35:07] |
I am sorry but I believe I followed all instructions and cannot get this to work. I have attached screen shots of my settings. Can you send me an exact screen shot to show me what I am missing? Everything moves in the .25 increment but my TPO letters are only in whole numbers. I cannot get an additional 4 rows to show letters at every .25 tick THank you for your patience. |
2018-11-26 TPO Settings.PNG / V - Attached On 2018-11-26 18:30:44 UTC - Size: 187.9 KB - 316 views 2018-11-15Sierra Global Symbol Settings .PNG / V - Attached On 2018-11-26 18:31:05 UTC - Size: 127.04 KB - 333 views |
[2018-11-26 20:12:12] |
Change the Letter/Block Increment in Ticks Input with the TPO Profile Chart study to 1. You have this set to 4, which means that each line of the TPO chart is looking at 4 ticks, or a price value of 1.0. And also you may want to change the "Scale Increment" on the Scale Window to .25 . You have it set to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-26 20:12:40
