Date/Time: Tue, 22 Apr 2025 14:11:46 +0000
Symbol Settings not found for current Service
View Count: 3933
[2018-11-15 15:05:39]
CarlRostron - Posts: 80
Hi, I opened up SC today and found the Yellow message "Symbol Settings not found for current Service". This seems to happen on all of the FTSE Stocks e.g.
KGF..LS
or
EZJ.LS
for example.
This was working before and I dont beleive I've changed any settings. I have my feed set to SC Data - All Services.
I have just tried the Global Symbol Settings 'Full reset' button but that didnt work.
Any idea please what I can try at all?
Thank you
[2018-11-15 18:27:50]
You can safely disregard that message and we are going to update the Symbol Settings to include the London stock exchange as well. This will be done later today.
At that time you just need to follow the instructions here:
[2018-11-16 07:36:44]
Sorry for having to come back to this, but another issue relating to the FTSE stocks, and I'm not even sure if the two items are related, but the ticker DC..LS has stopped downloading data. Most of the other FTSE symbols I have tried are updating on a Daily timeframe ok.
I thought perhaps it maybe because the Ticker has a double Dot (..LS), so I tested AO..LS as well and the same problem exists for that too. I tried HL..LS, again that failed:
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: HL..LS | 2018-11-16 02:35:05
- I'm on a Historical Daily chart, not Streaming Live Data
Maybe you can advise me further please or should I wait as you suggested in #2?
Date Time Of Last Edit: 2018-11-16 07:37:33
[2018-11-16 07:49:39]
Yes this is related and that is now resolved.
Go to those charts and select Edit >> Download Data From End of Chart.
[2018-11-29 07:59:36]
Hi, just coming back to this once again. I noticed that:
BT.A.LS
Is still doing this. I have completed the steps in #4 above that doesn't resolve it.
imageBT.A.LS.PNG / V - Attached On 2018-11-29 07:58:50 UTC - Size: 39.96 KB - 365 views
[2018-11-30 08:33:17]
This is now resolved. Let us know if there any other symbols with a problem.
[2023-03-01 16:38:58]
$tack - Posts: 100
I get this same message when i type in symbol brk.b and other symbols with "." with iqfeed as my data source.
But the shart shows up with data.
[2023-03-02 00:21:07]
Sierra_Chart Engineering - Posts: 19305
Refer to:
Global Symbol Settings: Symbol Settings Not Found Message
Date Time Of Last Edit: 2023-03-02 00:21:34
[2023-03-14 23:28:58]
$tack - Posts: 100
thanks I was able to follow your reference and resolve the issue
