Date/Time: Thu, 23 Jan 2025 05:15:07 +0000
Same two charts don't match eachother
View Count: 723
[2018-11-15 14:32:24] |
User432142 - Posts: 44 |
l deleted data and l re-download but l still have same issue, the issue is data missing and same two charts dont match each other. both of them are 100 pricechanges candlestick chart for S&P. one of them is numbers bars chart |
2018-11-15_17-15-19.jpg / V - Attached On 2018-11-15 14:27:44 UTC - Size: 668 KB - 309 views Attachment Deleted. |
[2018-11-15 19:10:48] |
For both of those charts go to Chart >> Chart Settings and make sure all of the settings on the first and second tabs match. We would expect that to resolve the issue.
