Date/Time: Thu, 23 Jan 2025 05:08:28 +0000
Problem with 1837 version
View Count: 895
[2018-11-15 14:15:50]
User210074 - Posts: 63
Hello, i just installed the 1837 version.
I have a problem compiling a Test.cpp file
#include "sierrachart.h"
#include "scdatetime.h"
#include "scstudyfunctions.h"
SCDLLName("Test");
SCSFExport scsf_Test(SCStudyGraphRef sc) {
if(sc.SetDefaults){
   sc.GraphName="Test";
   sc.FreeDLL=1;
   sc.AutoLoop=1;
   sc.GraphRegion=0;
   sc.UpdateAlways=1;
  if(sc.Index==0){sc.AddMessageToLog("Test Ok",1);}
  else{}
To create the dll I click on Build \ Build With Visual Studio C ++
The dll is not created because I have the error message :
F:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" amd64
'cl' n'est pas reconnu en tant que commande interne
ou externe, un programme ex‚cutable ou un fichier de commandes.
-- End of Build -- 14:43:13
The message said :
the "cl" command is not recognized as an internal or external execution command.
I uninstalled and reinstalled "visualcppbuildtools_full". It's the same, it does not work.
What does it take for the compiler to work again to create the dll?
[2018-11-15 17:20:04]
We cannot help with this. This is a Microsoft compiler issue of some kind. You need to use the Remote Build command instead.
[2018-11-15 19:44:28]
I have a problem when i use the Remote Build for cpp.
I have the same error message on all my cpp.
-- Starting remote build of Custom Studies Source files: Test.cpp. 64-bit -- 20:23:11
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
Test.cpp:3:30: fatal error: scstudyfunctions.h: No such file or directory
compilation terminated.
-- End of Build -- 20:23:14
I understand there is a link problem, but I can not fix it.
In all "studies" (of ACS_Source) in it works well.
Before that the update worked well too.
Can we not use this function anymore ?
I noticed that I no longer have error handling as in the old version.
I take it that you removed it.
What needs to be done to restore this error handling.
if it 's a bug i will install the old version.
[2018-11-15 20:19:21]
What function is that? What functions are you using from scstudyfunctions.h?
