Date/Time: Thu, 23 Jan 2025 05:07:06 +0000
Relative volume loading time
View Count: 563
[2018-11-15 10:51:07]
nonojnet - Posts: 8
Hello. I've configured relative volume study with default setup but "Display Cumulative Volume Average Cumulative Volume Difference= Yes" and "Period - Days to Include= 60". It's an intraday chart with tick by tick config. It takes a couple of minutes in loading, which i presume it's too much due to some wrong parameter. Any suggestions/solutions?
Thanks.
[2018-11-15 19:26:40]
First thing we recommend you do is refer to help topic 30.1 here:
http://www.sierrachart.com/index.php?page=doc/helpdetails30.html#TooMuchDataToLoadOrLoaded
You should probably also increase the time frame per chart bar. You really should not have less than a minute per bar. Five minutes per bar would be good.
[2018-11-16 08:38:30]
nonojnet - Posts: 8
Solved. Thanks.
