Date/Time: Thu, 23 Jan 2025 05:13:49 +0000
Was DPL Removed In The New Version....?
View Count: 1289
[2018-11-15 09:41:47] |
007700 - Posts: 43 |
The DPL value indicates the cumulative Profit/Loss of the closed Trades since midnight (default reset time). This DPL value is reset at midnight every day. Midnight is according to the Time Zone setting in Sierra Chart. You can change the reset time from midnight to another time. To change this, select Global Settings >> General Trade Settings. Set the Daily Stats Reset Time to the time that you want the DPL (Daily Profit/Loss) to be reset and accumulate from. Date Time Of Last Edit: 2018-11-15 09:54:36
[2018-11-15 18:46:34] |
We are going to be updating all of this documentation because it is out of date and we will have one section that is linked to which explains this. In newer versions, the reset time is controlled per chart and is based on the Session Times as explained at step 4 here: http://www.sierrachart.com/index.php?page=doc/DailyProfitLossValue.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-15 18:46:46
