Date/Time: Thu, 23 Jan 2025 05:00:30 +0000
Delaying on real-time data
View Count: 616
[2018-11-15 06:31:29] |
User401188 - Posts: 1 |
Hi team, I m currently trading NQ by using Sierra chart, but do face a problem in those days. The Sierra chart seems to have a delay in my NQ real-time data. I tried to refresh n reload the data, but it didn't work; then I hace to restart the problem several times to get an updated the data and bars. Could you help me on this please? Thx! |
[2018-11-15 07:47:10] |
This is not relevant to the issue but you are running an older version. Update following the instructions here: Software Download: Fast Update And in regards to real-time futures data, refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above *completely* before you ask further questions about real-time futures data. And *think about that information* before you ask questions about futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
