Date/Time: Thu, 23 Jan 2025 05:09:02 +0000
[Bitmex] Too many reconnect attempts lead to ban
View Count: 1965
[2018-11-15 06:26:44] |
Andrew Ton - Posts: 28 |
Hi, I got banned from Bitmex because Sierra did so many attempts to reconnect during a busy period. Appearantly, they only allow about 20/ hour at maximum or even less. Can you help me lower the rate or look into this problem with bitmex. A log file during a 15 min period shows 23 reconnect attemps under this line: Socket (5) | Shutdown started. Waiting for graceful close. I can sumbit the log file if you need it for further investigation. Thank you. |
[2018-11-15 06:54:20] |
Provide us the log file, and we will see how to solve this. We did start to implement a solution to this but we need to verify the details.
[2018-11-15 08:15:30] |
Please find below the message log during the busy period from 8:31 AM Sydney time (before I got banned around 12PM). Thank you. Reading Internal Order ID file. | 2018-11-15 08:31:08 Reading Trade Orders file. | 2018-11-15 08:31:08 Reading Trade Positions and Account Balance file. | 2018-11-15 08:31:08 Listening on UDP port 22904. | 2018-11-15 08:31:08 Software version: 1815 64-bit | 2018-11-15 08:31:08 Usage end date: 2018-11-24 | 2018-11-15 08:31:08 Enabled for: Advanced Features. | 2018-11-15 08:31:08 Enabled for: Advanced Features 2. | 2018-11-15 08:31:08 Enabled for: Sierra Chart Historical Data Service. | 2018-11-15 08:31:08 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-11-15 08:31:08 Current selected Data/Trading service: BitMEX Trading Direct | 2018-11-15 08:31:08 Chart Update Interval: 500 | 2018-11-15 08:31:08 Time Zone: +11:00:00 (AEST+10AEDT+01,M10.1.0/02:00,M4.1.0/03:00) | 2018-11-15 08:31:08 2018-11-15 08:31:08 Local computer time | 2018-11-15 08:31:08 2018-11-14 21:31:08 Local computer time in UTC | 2018-11-15 08:31:08 2018-11-15 08:31:08 Local computer time in SC Time Zone | 2018-11-15 08:31:08 2018-11-14 21:31:06 Server time in UTC | 2018-11-15 08:31:08 Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-11-15 08:31:08 Program path: C:\SierraChart\ | 2018-11-15 08:31:08 Data Files path: C:\SierraChart\Data\ | 2018-11-15 08:31:08 OS Version Number: 10.0 | 2018-11-15 08:31:08 Locale Setting: C | 2018-11-15 08:31:08 Checking for new symbol settings for service code bitmex.exchange.trading | 2018-11-15 08:31:08 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 08:31:08 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-11-15 08:31:08 Received 5 login tokens. | 2018-11-15 08:31:10 Symbol settings are up-to-date for bitmex.exchange.trading | 2018-11-15 08:31:10 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-11-15 08:31:10 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-11-15 08:31:10 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-11-15 08:31:12 HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-11-15 08:31:12 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-11-15 08:31:12 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 08:31:12 HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-11-15 08:31:12 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 08:31:15 HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-11-15 08:31:15 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 08:31:15 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 08:31:15 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 08:31:15 BitMEX WebSocket socket (1) | Connecting to IP: 54.229.165.13. | 2018-11-15 08:31:15 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 08:31:15 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 08:31:15 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 21:31:15 GMT | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=AExFERB4TUeF5We8hMts2cE/RMQTnhfpNiS9UqIvn3uDsFG+zfq/wIlKtbJqG6uTqRejUevnOmH/5izf3/IyP1dNg5CF9BG0UbJwBxeAQWBAEEftd/trL9ZVeXdf; Expires=Wed, 21 Nov 2018 21:31:15 GMT; Path=/ | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: okymyfaa/HegKXwQ6VnUB2Fd7DQ= | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 08:31:16 BitMEX WebSocket | Header line. | 2018-11-15 08:31:16 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 08:31:16 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 08:31:16 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-11-15 08:31:17 HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-11-15 08:31:17 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-11-15 08:31:17 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 08:31:17 HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-11-15 08:31:17 XBTUSD-BMEX 1 Min #2 | Reloading chart. | 2018-11-15 08:31:21 XBTUSD-BMEX 15 Min #4 | Reloading chart. | 2018-11-15 08:31:21 XBTUSD-BMEX 10 Sec #1 | Reloading chart. | 2018-11-15 08:31:21 ETHUSD-BITFINEX 1 Min #5 | Reloading chart. | 2018-11-15 08:31:21 XBTUSD-BMEX 1 Min #6 | Reloading chart. | 2018-11-15 08:31:21 BTCUSD-BITFINEX 1 Min #7 | Reloading chart. | 2018-11-15 08:31:21 XBTUSD-BMEX 5 Min #8 | Reloading chart. | 2018-11-15 08:31:21 BTCUSD-BITFINEX 5 Min #9 | Reloading chart. | 2018-11-15 08:31:21 XBTUSD-BMEX #10 | Reloading chart. | 2018-11-15 08:31:21 + Loading market depth data. | 2018-11-15 08:31:23 XBTUSD-BMEX 10 Sec #3 | Reloading chart. | 2018-11-15 08:31:23 XBTUSD-BMEX 1 Min #11 | Reloading chart. | 2018-11-15 08:31:23 Loaded depth data records for XBTUSD-BMEX 2018-10-30 from 2018-10-31 08:30:52 to 2018-10-31 10:59:59. | 2018-11-15 08:31:23 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 08:31:23 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.229.165.13. | 2018-11-15 08:31:23 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 08:31:23 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2018-11-15 08:31:23 DTC Client socket (3) | Creating socket. | 2018-11-15 08:31:23 DTC Client socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 08:31:23 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 08:31:23 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 08:31:23 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 08:31:23 Delaying start of download for XBTUSD-BMEX | 2018-11-15 08:31:23 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 08:31:23 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 08:31:23 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 08:31:23 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 08:31:23 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 08:31:23 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 08:31:23 + Loading market depth data. | 2018-11-15 08:31:24 Loaded depth data records for XBTUSD-BMEX 2018-10-31 from 2018-10-31 11:00:03 to 2018-11-01 10:59:59. | 2018-11-15 08:31:25 Loaded depth data records for XBTUSD-BMEX 2018-10-10 from 2018-10-11 00:00:04 to 2018-10-11 10:59:59. | 2018-11-15 08:31:25 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 08:31:27 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 08:31:27 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 08:31:27 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 08:31:27 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 08:31:27 Loaded depth data records for XBTUSD-BMEX 2018-11-01 from 2018-11-01 11:00:03 to 2018-11-02 10:59:59. | 2018-11-15 08:31:28 Loaded depth data records for XBTUSD-BMEX 2018-10-11 from 2018-10-11 11:00:04 to 2018-10-12 10:59:58. | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 08:31:29 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 08:31:29 Loaded depth data records for XBTUSD-BMEX 2018-11-02 from 2018-11-02 11:00:03 to 2018-11-03 10:59:59. | 2018-11-15 08:31:30 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 08:31:30 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 08:31:30 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 08:31:30 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 08:31:31 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 08:31:31 Loaded depth data records for XBTUSD-BMEX 2018-10-12 from 2018-10-12 11:00:00 to 2018-10-13 10:59:59. | 2018-11-15 08:31:32 Loaded depth data records for XBTUSD-BMEX 2018-11-03 from 2018-11-03 11:00:04 to 2018-11-04 10:59:59. | 2018-11-15 08:31:32 Loaded depth data records for XBTUSD-BMEX 2018-10-13 from 2018-10-13 11:00:03 to 2018-10-14 10:59:59. | 2018-11-15 08:31:34 Loaded depth data records for XBTUSD-BMEX 2018-11-04 from 2018-11-04 11:00:02 to 2018-11-05 10:59:59. | 2018-11-15 08:31:34 Loaded depth data records for XBTUSD-BMEX 2018-10-14 from 2018-10-14 11:00:03 to 2018-10-14 23:59:59. | 2018-11-15 08:31:35 HD Request # 2 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 08:31:35 HD Request # 2 | Download start date-time: 2018-11-15 08:30:52.000 | 2018-11-15 08:31:35 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 08:31:35 Socket (4) | Creating socket. | 2018-11-15 08:31:35 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 08:31:35 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-11-15 08:31:36 HD Request # 2 | Sending historical data logon request message. | 2018-11-15 08:31:36 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-11-15 08:30:52. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 08:31:36 Loaded depth data records for XBTUSD-BMEX 2018-11-05 from 2018-11-05 11:00:03 to 2018-11-06 10:59:59. | 2018-11-15 08:31:37 HD Request # 2 | Decompressing data. | 2018-11-15 08:31:37 HD Request # 2 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 08:30:52 | 2018-11-15 08:31:37 HD Request # 2 | Timestamp of first Intraday data file record written: 2018-11-15 08:30:52 | 2018-11-15 08:31:37 Socket (4) | Signaling to core to close socket | 2018-11-15 08:31:37 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 08:31:37 Historical data download thread signaled to stop. | 2018-11-15 08:31:37 HD Request # 2 | Received 703 records from 2018-11-15 08:30:52 to 2018-11-15 08:31:30 (38.0 seconds) and wrote 698 records for XBTUSD-BMEX | 2018-11-15 08:31:37 Added 58 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 08:31:37 HD Request # 2 | Completion time: 0s | 2018-11-15 08:31:37 HD Request # 2 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 1 | 2018-11-15 08:31:37 Removed historical data download ID 1 | 2018-11-15 08:31:37 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 08:31:37 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 08:31:37 HD Request # 3 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 08:31:37 HD Request # 3 | Download start date-time: 2018-11-15 08:30:52.000 | 2018-11-15 08:31:37 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 08:31:37 Socket (5) | Creating socket. | 2018-11-15 08:31:37 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 08:31:37 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 08:31:37 Socket (4) | Closed. | 2018-11-15 08:31:37 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-11-15 08:31:37 HD Request # 3 | Sending historical data logon request message. | 2018-11-15 08:31:37 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-11-15 08:30:52. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 08:31:38 HD Request # 3 | Decompressing data. | 2018-11-15 08:31:38 HD Request # 3 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 08:30:52 | 2018-11-15 08:31:38 HD Request # 3 | Timestamp of first Intraday data file record written: 2018-11-15 08:30:52 | 2018-11-15 08:31:38 Socket (5) | Signaling to core to close socket | 2018-11-15 08:31:38 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 08:31:38 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 08:31:38 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 08:31:38 Socket (5) | Closed. | 2018-11-15 08:31:38 Loaded depth data records for XBTUSD-BMEX 2018-11-06 from 2018-11-06 11:00:05 to 2018-11-07 10:59:59. | 2018-11-15 08:31:38 Historical data download thread signaled to stop. | 2018-11-15 08:31:39 HD Request # 3 | Received 44 records from 2018-11-15 08:30:52 to 2018-11-15 08:31:33 (41.0 seconds) and wrote 36 records for ETHUSD-BITFINEX | 2018-11-15 08:31:39 HD Request # 3 | Completion time: 2s | 2018-11-15 08:31:39 HD Request # 3 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 2 | 2018-11-15 08:31:39 Removed historical data download ID 2 | 2018-11-15 08:31:39 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 08:31:39 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 08:31:39 HD Request # 4 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 08:31:39 HD Request # 4 | Download start date-time: 2018-11-15 08:30:52.000 | 2018-11-15 08:31:39 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 08:31:39 Socket (4) | Creating socket. | 2018-11-15 08:31:39 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 08:31:39 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 08:31:39 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 08:31:39 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-11-15 08:31:40 HD Request # 4 | Sending historical data logon request message. | 2018-11-15 08:31:40 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-11-15 08:30:52. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 08:31:40 HD Request # 4 | Decompressing data. | 2018-11-15 08:31:40 HD Request # 4 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 08:30:52 | 2018-11-15 08:31:40 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-11-15 08:30:56 | 2018-11-15 08:31:40 Socket (4) | Signaling to core to close socket | 2018-11-15 08:31:40 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 08:31:40 Historical data download thread signaled to stop. | 2018-11-15 08:31:40 HD Request # 4 | Received 128 records from 2018-11-15 08:30:52 to 2018-11-15 08:31:38 (46.0 seconds) and wrote 126 records for BTCUSD-BITFINEX | 2018-11-15 08:31:40 HD Request # 4 | Completion time: 2s | 2018-11-15 08:31:40 HD Request # 4 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 3 | 2018-11-15 08:31:40 Removed historical data download ID 3 | 2018-11-15 08:31:40 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 08:31:40 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 08:31:40 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 08:31:41 Socket (4) | Closed. | 2018-11-15 08:31:41 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 08:31:41 Loaded depth data records for XBTUSD-BMEX 2018-11-07 from 2018-11-07 11:00:00 to 2018-11-08 10:59:59. | 2018-11-15 08:31:42 Loaded depth data records for XBTUSD-BMEX 2018-11-08 from 2018-11-08 11:00:03 to 2018-11-09 10:59:59. | 2018-11-15 08:31:43 Loaded depth data records for XBTUSD-BMEX 2018-11-09 from 2018-11-09 11:00:04 to 2018-11-09 23:38:03. | 2018-11-15 08:31:44 Loaded depth data records for XBTUSD-BMEX 2018-11-10 from 2018-11-10 13:50:48 to 2018-11-11 10:59:59. | 2018-11-15 08:31:45 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 08:31:47 Loaded depth data records for XBTUSD-BMEX 2018-11-11 from 2018-11-11 11:00:04 to 2018-11-12 10:59:59. | 2018-11-15 08:31:50 Loaded depth data records for XBTUSD-BMEX 2018-11-12 from 2018-11-12 11:00:00 to 2018-11-13 10:59:59. | 2018-11-15 08:31:51 Loaded depth data records for XBTUSD-BMEX 2018-11-13 from 2018-11-13 11:00:04 to 2018-11-14 10:59:59. | 2018-11-15 08:31:53 Loaded depth data records for XBTUSD-BMEX 2018-11-14 from 2018-11-14 11:00:00 to 2018-11-15 08:30:51. | 2018-11-15 08:31:54 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 08:32:00 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:32:00 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:32:00 * HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 08:35:00 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 08:35:00 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 08:35:00 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 08:35:00 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 08:35:00 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 08:35:17 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 34.249.83.22. | 2018-11-15 08:35:17 BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:35:18 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:35:18 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:35:18 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:35:18 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:35:51 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:35:51 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:35:51 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:35:51 * HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 08:38:51 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 08:38:51 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 08:38:51 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 08:38:51 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 08:38:51 HTTPS www.bitmex.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 08:39:12 HTTPS www.bitmex.com:443 (4) | Connecting to IP: 34.248.216.179. | 2018-11-15 08:39:12 BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:39:13 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:39:13 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:39:13 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:39:13 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:39:59 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:39:59 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:39:59 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:39:59 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:41:44 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:41:44 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:41:44 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:41:44 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:42:55 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:42:55 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:42:55 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:42:55 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:43:25 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:43:25 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:43:25 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:43:25 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:43:50 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:43:50 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:43:50 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:43:50 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:44:39 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:44:39 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:44:39 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:44:39 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:44:58 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:44:58 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:44:58 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:44:58 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:46:13 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:46:13 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:46:13 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:46:13 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:46:37 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:46:37 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:46:37 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:46:37 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:48:08 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:48:08 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:48:08 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:48:08 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:48:44 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:48:44 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:48:44 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:48:44 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:50:28 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:50:28 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:50:28 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:50:28 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:50:43 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:50:43 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:50:43 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:50:43 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:51:23 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:51:23 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:51:23 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:51:23 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:51:47 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:51:47 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:51:47 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:51:47 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:53:52 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:53:52 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:53:52 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:53:52 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:54:26 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:54:26 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:54:26 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:54:26 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:11 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:11 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:11 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:11 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:22 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:22 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:22 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:22 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:47 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:47 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:47 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:47 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:58 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:58 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 08:56:58 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 08:56:58 * HTTPS www.bitmex.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 08:59:58 HTTPS www.bitmex.com:443 (4) | Signaling to core to close socket | 2018-11-15 08:59:58 HTTPS www.bitmex.com:443 (4) | Received socket Close event. | 2018-11-15 08:59:58 HTTPS www.bitmex.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 08:59:58 HTTPS www.bitmex.com:443 (4) | Closed. | 2018-11-15 08:59:58 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 09:00:25 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.171.170.78. | 2018-11-15 09:00:25 BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:00:26 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:00:26 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:00:26 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:00:26 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:00:43 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:00:43 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:00:43 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:00:43 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:03:06 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:03:06 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:03:06 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:03:06 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:03:55 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:03:55 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:03:55 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:03:55 * HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 09:06:55 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 09:06:55 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 09:06:55 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 09:06:55 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 09:06:55 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 09:14:25 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.76.67.67. | 2018-11-15 09:14:25 BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:14:26 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:14:26 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:14:26 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:14:26 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:14:49 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:14:49 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:14:49 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:14:49 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:15:39 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:15:39 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:15:39 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:15:39 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:15:53 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:15:53 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:15:53 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:15:53 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:18:12 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:18:12 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:18:12 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:18:12 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:18:35 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:18:35 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 09:18:35 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 09:18:35 * BTCUSD-BITFINEX [M] Daily #7 | Reloading chart. | 2018-11-15 09:20:31 HD Request # 5 | Downloading Historical Daily chart data for BTCUSD-BITFINEX. Starting date: 2018-11-13. Service: bitfinex | 2018-11-15 09:20:32 HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 09:20:32 Socket (4) | Creating socket. | 2018-11-15 09:20:32 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 09:20:32 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-11-15 09:20:32 HD Request # 5 | Sending historical data logon request message. | 2018-11-15 09:20:32 HD Request # 5 | Requesting historical Daily data starting at 2018-11-13. | 2018-11-15 09:20:33 HD Request # 5 | Decompressing data. | 2018-11-15 09:20:33 HD Request # 5 | Receiving historical Daily data for BTCUSD-BITFINEX starting at 2018-11-13 | 2018-11-15 09:20:33 HD Request # 5 | Writing historical Daily data to the file BTCUSD-BITFINEX.dly | 2018-11-15 09:20:33 Socket (4) | Signaling to core to close socket | 2018-11-15 09:20:33 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 09:20:33 Historical data download thread signaled to stop. | 2018-11-15 09:20:33 HD Request # 5 | Received 3 records from 2018-11-13 00:00:00 to 2018-11-14 00:00:00 (2.0 days) and wrote 2 records for BTCUSD-BITFINEX | 2018-11-15 09:20:33 HD Request # 5 | Completion time: 2s | 2018-11-15 09:20:33 HD Request # 5 | Daily data download complete for BTCUSD-BITFINEX. Unique request ID: 4 | 2018-11-15 09:20:33 Removed historical data download ID 4 | 2018-11-15 09:20:33 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 09:20:33 Socket (4) | Closed. | 2018-11-15 09:20:33 BTCUSD-BITFINEX [M] Daily #7 | Reloading chart. | 2018-11-15 09:20:33 BTCUSD-BITFINEX [M] 1 Min #7 | Reloading chart. | 2018-11-15 09:20:43 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 09:21:35 HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 09:21:35 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 09:21:35 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 09:21:35 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 09:21:35 ETHUSD-BMEX 1 Min #2 | Reloading chart. | 2018-11-15 09:40:26 ETHUSD-BMEX 60 Min #4 | Reloading chart. | 2018-11-15 09:40:27 ETHUSD-BMEX 10 Sec #1 | Reloading chart. | 2018-11-15 09:40:27 XBTZ18-BMEX 15 Min #3 | Reloading chart. | 2018-11-15 09:40:27 ETHUSD-BITFINEX 1 Min #5 | Reloading chart. | 2018-11-15 09:40:27 ETHUSD-BMEX 1 Min #6 | Reloading chart. | 2018-11-15 09:40:27 ETHUSD-BITFINEX 1 Min #7 | Reloading chart. | 2018-11-15 09:40:27 ETHUSD-BMEX #8 | Reloading chart. | 2018-11-15 09:40:27 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 4 | 2018-11-15 09:40:27 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 4 | 2018-11-15 09:40:27 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 09:40:27 Delaying start of download for ETHUSD-BMEX | 2018-11-15 09:40:27 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 09:40:27 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 5 | 2018-11-15 09:40:27 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 5 | 2018-11-15 09:40:27 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 09:40:27 + Loading market depth data. | 2018-11-15 09:40:27 Loaded depth data records for ETHUSD-BMEX 2018-11-04 from 2018-11-05 08:30:52 to 2018-11-05 10:59:59. | 2018-11-15 09:40:27 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 09:40:28 Loaded depth data records for ETHUSD-BMEX 2018-11-05 from 2018-11-05 11:00:03 to 2018-11-06 10:59:59. | 2018-11-15 09:40:28 Loaded depth data records for ETHUSD-BMEX 2018-11-06 from 2018-11-06 11:00:06 to 2018-11-07 10:59:59. | 2018-11-15 09:40:29 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 09:40:29 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 09:40:29 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 09:40:29 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 09:40:29 Loaded depth data records for ETHUSD-BMEX 2018-11-07 from 2018-11-07 11:00:00 to 2018-11-08 10:59:59. | 2018-11-15 09:40:30 Loaded depth data records for ETHUSD-BMEX 2018-11-08 from 2018-11-08 11:00:03 to 2018-11-09 10:59:59. | 2018-11-15 09:40:30 Loaded depth data records for ETHUSD-BMEX 2018-11-09 from 2018-11-09 11:00:04 to 2018-11-09 23:38:02. | 2018-11-15 09:40:31 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 09:40:31 Loaded depth data records for ETHUSD-BMEX 2018-11-10 from 2018-11-10 13:50:47 to 2018-11-11 10:59:59. | 2018-11-15 09:40:32 Loaded depth data records for ETHUSD-BMEX 2018-11-11 from 2018-11-11 11:00:04 to 2018-11-12 10:59:59. | 2018-11-15 09:40:32 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 09:40:32 Loaded depth data records for ETHUSD-BMEX 2018-11-12 from 2018-11-12 11:00:00 to 2018-11-13 10:59:59. | 2018-11-15 09:40:32 HD Request # 6 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 09:40:32 HD Request # 6 | Download start date-time: 2018-11-15 08:30:52.000 | 2018-11-15 09:40:32 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 09:40:32 Socket (2) | Creating socket. | 2018-11-15 09:40:32 Socket (2) | Connecting to IP: 192.81.56.146. | 2018-11-15 09:40:32 HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-11-15 09:40:33 HD Request # 6 | Sending historical data logon request message. | 2018-11-15 09:40:33 HD Request # 6 | Requesting Intraday data. Start date-time: 2018-11-15 08:30:52. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 09:40:33 HD Request # 6 | Decompressing data. | 2018-11-15 09:40:34 HD Request # 6 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 08:30:52 | 2018-11-15 09:40:34 HD Request # 6 | Timestamp of first Intraday data file record written: 2018-11-15 08:30:52 | 2018-11-15 09:40:34 Socket (2) | Signaling to core to close socket | 2018-11-15 09:40:35 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 09:40:35 Historical data download thread signaled to stop. | 2018-11-15 09:40:35 HD Request # 6 | Received 14852 records from 2018-11-15 08:30:52 to 2018-11-15 09:40:28 (69.6 minutes) and wrote 14848 records for ETHUSD-BMEX | 2018-11-15 09:40:35 Added 8 Time and Sales records to Intraday data file for ETHUSD-BMEX after download. | 2018-11-15 09:40:35 HD Request # 6 | Completion time: 3s | 2018-11-15 09:40:35 HD Request # 6 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 5 | 2018-11-15 09:40:35 Removed historical data download ID 5 | 2018-11-15 09:40:35 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 09:40:35 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 09:40:35 HD Request # 7 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 09:40:35 HD Request # 7 | Download start date-time: 2018-11-15 08:30:49.000 | 2018-11-15 09:40:35 HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 09:40:35 Socket (4) | Creating socket. | 2018-11-15 09:40:35 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 09:40:35 Loaded depth data records for ETHUSD-BMEX 2018-11-13 from 2018-11-13 11:00:05 to 2018-11-14 10:59:59. | 2018-11-15 09:40:35 Socket (2) | Socket gracefully closed by remote side. | 2018-11-15 09:40:36 Socket (2) | Closed. | 2018-11-15 09:40:36 HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-11-15 09:40:36 HD Request # 7 | Sending historical data logon request message. | 2018-11-15 09:40:36 Loaded depth data records for ETHUSD-BMEX 2018-11-14 from 2018-11-14 11:00:00 to 2018-11-15 08:30:51. | 2018-11-15 09:40:36 HD Request # 7 | Requesting Intraday data. Start date-time: 2018-11-15 08:30:49. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 09:40:36 HD Request # 7 | Decompressing data. | 2018-11-15 09:40:37 HD Request # 7 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 08:30:49 | 2018-11-15 09:40:37 HD Request # 7 | Timestamp of first Intraday data file record written: 2018-11-15 08:31:02 | 2018-11-15 09:40:37 Socket (4) | Signaling to core to close socket | 2018-11-15 09:40:37 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 09:40:37 Historical data download thread signaled to stop. | 2018-11-15 09:40:37 HD Request # 7 | Received 3689 records from 2018-11-15 08:30:49 to 2018-11-15 09:40:30 (69.7 minutes) and wrote 3688 records for XBTZ18-BMEX | 2018-11-15 09:40:37 Added 1 Time and Sales records to Intraday data file for XBTZ18-BMEX after download. | 2018-11-15 09:40:37 HD Request # 7 | Completion time: 2s | 2018-11-15 09:40:37 HD Request # 7 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 6 | 2018-11-15 09:40:37 Removed historical data download ID 6 | 2018-11-15 09:40:37 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 09:40:37 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 09:40:37 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 09:40:37 Socket (4) | Closed. | 2018-11-15 09:40:37 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 09:40:37 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 09:40:40 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 09:42:03 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 52.49.223.204. | 2018-11-15 09:42:03 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 09:46:57 HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 09:46:57 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 09:46:57 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 09:46:57 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 09:46:57 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:05:37 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.194.18.106. | 2018-11-15 10:05:37 HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:09:32 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 10:09:32 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:09:32 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:09:32 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 10:09:32 HTTPS www.bitmex.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 10:13:10 HTTPS www.bitmex.com:443 (4) | Connecting to IP: 52.17.75.33. | 2018-11-15 10:13:10 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:15:41 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:15:41 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:15:41 BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-11-15 10:15:41 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:15:41 BitMEX WebSocket socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:15:41 Connection to the external service has been lost. | 2018-11-15 10:15:41 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:15:41 HTTPS www.bitmex.com:443 (4) | Signaling to core to close socket | 2018-11-15 10:15:41 HTTPS www.bitmex.com:443 (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:15:41 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:15:41 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:15:41 HTTPS www.bitmex.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 10:15:41 HTTPS www.bitmex.com:443 (4) | Closed. | 2018-11-15 10:15:41 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:15:44 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:15:44 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:15:44 BitMEX WebSocket socket (1) | Connecting to IP: 52.48.220.180. | 2018-11-15 10:15:44 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:15:44 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:15:44 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:15:44 GMT | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=RooO83s8y4HoRTL8r6cMDKB6aHjBuYfLnQhm7g255+SX+HrLmFnRHXZQIUSILX9+hV2rmaX2BzpTq2zRYTS5iu7PD4lhRyapBQRY3Jy7FbQvvwrLbe4rENMMZypC; Expires=Wed, 21 Nov 2018 23:15:44 GMT; Path=/ | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: fhK8NobqOlq+neYOQOaDInZvJ3Y= | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:15:45 BitMEX WebSocket | Header line. | 2018-11-15 10:15:45 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:15:45 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:15:45 DTC Client socket (3) | Signaling to core to close socket | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:15:45 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 1 | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 1 | 2018-11-15 10:15:45 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:15:45 Delaying start of download for ETHUSD-BMEX | 2018-11-15 10:15:45 DTC Client socket (2) | Creating socket. | 2018-11-15 10:15:45 DTC Client socket (2) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:15:45 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:15:45 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:15:45 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 4 | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 4 | 2018-11-15 10:15:45 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 5 | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 5 | 2018-11-15 10:15:45 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:15:45 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:15:45 DTC Client socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:15:45 DTC Client socket (3) | Closed. | 2018-11-15 10:15:45 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:15:46 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:15:48 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:15:48 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:15:48 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:15:48 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:15:48 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:15:48 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:15:48 HTTPS www.bitmex.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-11-15 10:15:50 HTTPS www.bitmex.com:443 (3) | Connecting to IP: 52.48.220.180. | 2018-11-15 10:15:50 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:15:50 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:15:50 HD Request # 8 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:15:51 HD Request # 8 | Download start date-time: 2018-11-15 10:15:42.000 | 2018-11-15 10:15:51 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:15:51 Socket (4) | Creating socket. | 2018-11-15 10:15:51 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:15:51 HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-11-15 10:15:52 HD Request # 8 | Sending historical data logon request message. | 2018-11-15 10:15:52 HD Request # 8 | Requesting Intraday data. Start date-time: 2018-11-15 10:15:42. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:15:52 HD Request # 8 | Decompressing data. | 2018-11-15 10:15:53 HD Request # 8 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:15:42 | 2018-11-15 10:15:53 HD Request # 8 | Timestamp of first Intraday data file record written: 2018-11-15 10:15:43 | 2018-11-15 10:15:53 Socket (4) | Signaling to core to close socket | 2018-11-15 10:15:53 Historical data download thread signaled to stop. | 2018-11-15 10:15:53 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:15:53 HD Request # 8 | Received 25 records from 2018-11-15 10:15:42 to 2018-11-15 10:15:49 (7.0 seconds) and wrote 24 records for ETHUSD-BMEX | 2018-11-15 10:15:53 HD Request # 8 | Completion time: 0s | 2018-11-15 10:15:53 HD Request # 8 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 7 | 2018-11-15 10:15:53 Removed historical data download ID 7 | 2018-11-15 10:15:53 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:15:53 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:15:53 HD Request # 9 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:15:53 HD Request # 9 | Download start date-time: 2018-11-15 10:15:43.000 | 2018-11-15 10:15:53 HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:15:53 Socket (5) | Creating socket. | 2018-11-15 10:15:53 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:15:53 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:15:53 Socket (4) | Closed. | 2018-11-15 10:15:53 HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-11-15 10:15:53 HD Request # 9 | Sending historical data logon request message. | 2018-11-15 10:15:53 HD Request # 9 | Requesting Intraday data. Start date-time: 2018-11-15 10:15:43. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:15:53 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:15:54 HD Request # 9 | Decompressing data. | 2018-11-15 10:15:54 HD Request # 9 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:15:43 | 2018-11-15 10:15:54 HD Request # 9 | Timestamp of first Intraday data file record written: 2018-11-15 10:15:43 | 2018-11-15 10:15:54 Socket (5) | Signaling to core to close socket | 2018-11-15 10:15:54 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:15:54 Historical data download thread signaled to stop. | 2018-11-15 10:15:54 HD Request # 9 | Received 144 records from 2018-11-15 10:15:43 to 2018-11-15 10:15:49 (6.0 seconds) and wrote 137 records for XBTUSD-BMEX | 2018-11-15 10:15:54 Added 7 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:15:54 HD Request # 9 | Completion time: 0s | 2018-11-15 10:15:54 HD Request # 9 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 8 | 2018-11-15 10:15:54 Removed historical data download ID 8 | 2018-11-15 10:15:54 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:15:54 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:15:54 HD Request # 10 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:15:54 HD Request # 10 | Download start date-time: 2018-11-15 10:15:42.000 | 2018-11-15 10:15:54 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:15:54 Socket (4) | Creating socket. | 2018-11-15 10:15:54 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:15:54 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:15:54 Socket (5) | Closed. | 2018-11-15 10:15:54 HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-11-15 10:15:54 HD Request # 10 | Sending historical data logon request message. | 2018-11-15 10:15:54 HD Request # 10 | Requesting Intraday data. Start date-time: 2018-11-15 10:15:42. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:15:55 HD Request # 10 | Decompressing data. | 2018-11-15 10:15:55 HD Request # 10 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:15:42 | 2018-11-15 10:15:55 HD Request # 10 | Timestamp of first Intraday data file record written: 2018-11-15 10:15:44 | 2018-11-15 10:15:55 Socket (4) | Signaling to core to close socket | 2018-11-15 10:15:55 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:15:55 Historical data download thread signaled to stop. | 2018-11-15 10:15:55 HD Request # 10 | Received 10 records from 2018-11-15 10:15:42 to 2018-11-15 10:15:51 (9.0 seconds) and wrote 8 records for BTCUSD-BITFINEX | 2018-11-15 10:15:55 HD Request # 10 | Completion time: 2s | 2018-11-15 10:15:55 HD Request # 10 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 9 | 2018-11-15 10:15:55 Removed historical data download ID 9 | 2018-11-15 10:15:55 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:15:55 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:15:55 HD Request # 11 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:15:55 HD Request # 11 | Download start date-time: 2018-11-15 10:15:33.000 | 2018-11-15 10:15:55 HD Request # 11 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:15:55 Socket (5) | Creating socket. | 2018-11-15 10:15:55 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:15:55 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:15:55 Socket (4) | Closed. | 2018-11-15 10:15:55 HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-11-15 10:15:56 HD Request # 11 | Sending historical data logon request message. | 2018-11-15 10:15:56 HD Request # 11 | Requesting Intraday data. Start date-time: 2018-11-15 10:15:33. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:15:56 HD Request # 11 | Decompressing data. | 2018-11-15 10:15:56 HD Request # 11 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:15:33 | 2018-11-15 10:15:56 HD Request # 11 | Timestamp of first Intraday data file record written: 2018-11-15 10:15:49 | 2018-11-15 10:15:56 Socket (5) | Signaling to core to close socket | 2018-11-15 10:15:56 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:15:56 Historical data download thread signaled to stop. | 2018-11-15 10:15:56 HD Request # 11 | Received 15 records from 2018-11-15 10:15:33 to 2018-11-15 10:15:52 (19.0 seconds) and wrote 14 records for XBTZ18-BMEX | 2018-11-15 10:15:56 HD Request # 11 | Completion time: 0s | 2018-11-15 10:15:56 HD Request # 11 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 10 | 2018-11-15 10:15:56 Removed historical data download ID 10 | 2018-11-15 10:15:56 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:15:56 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:15:56 HD Request # 12 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:15:56 HD Request # 12 | Download start date-time: 2018-11-15 10:15:43.000 | 2018-11-15 10:15:56 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:15:56 Socket (4) | Creating socket. | 2018-11-15 10:15:56 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:15:56 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:15:56 Socket (5) | Closed. | 2018-11-15 10:15:56 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:15:57 HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-11-15 10:15:57 HD Request # 12 | Sending historical data logon request message. | 2018-11-15 10:15:57 HD Request # 12 | Requesting Intraday data. Start date-time: 2018-11-15 10:15:43. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:15:57 HD Request # 12 | Decompressing data. | 2018-11-15 10:15:58 HD Request # 12 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:15:43 | 2018-11-15 10:15:58 HD Request # 12 | Timestamp of first Intraday data file record written: 2018-11-15 10:15:50 | 2018-11-15 10:15:58 Socket (4) | Signaling to core to close socket | 2018-11-15 10:15:58 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:15:58 Historical data download thread signaled to stop. | 2018-11-15 10:15:58 HD Request # 12 | Received 11 records from 2018-11-15 10:15:43 to 2018-11-15 10:15:52 (9.0 seconds) and wrote 10 records for ETHUSD-BITFINEX | 2018-11-15 10:15:58 HD Request # 12 | Completion time: 1s | 2018-11-15 10:15:58 HD Request # 12 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 11 | 2018-11-15 10:15:58 Removed historical data download ID 11 | 2018-11-15 10:15:58 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:15:58 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:15:58 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:15:58 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:15:58 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:15:58 Socket (4) | Closed. | 2018-11-15 10:15:58 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:15:58 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:15:58 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:16:00 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:16:03 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:16:09 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX is currently unavailable. | 2018-11-15 10:17:03 SC DTC Data with Market Depth | Real-time data for symbol XBTZ18-BMEX is currently unavailable. | 2018-11-15 10:17:03 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX is currently unavailable. | 2018-11-15 10:17:03 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:17:13 SC DTC Data with Market Depth | Real-time data for symbol XBTZ18-BMEX has been restored. | 2018-11-15 10:17:13 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:17:13 HD Request # 13 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:17:13 HD Request # 13 | Download start date-time: 2018-11-15 10:16:57.000 | 2018-11-15 10:17:13 HD Request # 13 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:17:13 Socket (5) | Creating socket. | 2018-11-15 10:17:13 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:17:13 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:17:14 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:17:14 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX has been restored. | 2018-11-15 10:17:14 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:17:14 HD Request # 13 | Setting DTC encoding to Binary VLS | 2018-11-15 10:17:14 HD Request # 13 | Sending historical data logon request message. | 2018-11-15 10:17:14 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:17:14 HD Request # 13 | Requesting Intraday data. Start date-time: 2018-11-15 10:16:57. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:17:14 HD Request # 13 | Decompressing data. | 2018-11-15 10:17:14 HD Request # 13 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:16:57 | 2018-11-15 10:17:14 HD Request # 13 | Timestamp of first Intraday data file record written: 2018-11-15 10:17:02 | 2018-11-15 10:17:14 Socket (5) | Signaling to core to close socket | 2018-11-15 10:17:14 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:17:14 Historical data download thread signaled to stop. | 2018-11-15 10:17:14 HD Request # 13 | Received 17 records from 2018-11-15 10:16:57 to 2018-11-15 10:17:10 (13.0 seconds) and wrote 15 records for XBTZ18-BMEX | 2018-11-15 10:17:14 Added 2 Time and Sales records to Intraday data file for XBTZ18-BMEX after download. | 2018-11-15 10:17:14 HD Request # 13 | Completion time: 1s | 2018-11-15 10:17:14 HD Request # 13 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 12 | 2018-11-15 10:17:14 Removed historical data download ID 12 | 2018-11-15 10:17:14 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:17:14 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:17:14 HD Request # 14 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:17:14 HD Request # 14 | Download start date-time: 2018-11-15 10:16:58.000 | 2018-11-15 10:17:14 HD Request # 14 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:17:14 Socket (4) | Creating socket. | 2018-11-15 10:17:14 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:17:14 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:17:15 Socket (5) | Closed. | 2018-11-15 10:17:15 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:17:15 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX has been restored. | 2018-11-15 10:17:15 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:17:15 HD Request # 14 | Setting DTC encoding to Binary VLS | 2018-11-15 10:17:15 HD Request # 14 | Sending historical data logon request message. | 2018-11-15 10:17:15 HD Request # 14 | Requesting Intraday data. Start date-time: 2018-11-15 10:16:58. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:17:15 HD Request # 14 | Decompressing data. | 2018-11-15 10:17:16 HD Request # 14 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:16:58 | 2018-11-15 10:17:16 HD Request # 14 | Timestamp of first Intraday data file record written: 2018-11-15 10:17:02 | 2018-11-15 10:17:16 Socket (4) | Signaling to core to close socket | 2018-11-15 10:17:16 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:17:16 Historical data download thread signaled to stop. | 2018-11-15 10:17:16 HD Request # 14 | Received 24 records from 2018-11-15 10:16:58 to 2018-11-15 10:17:10 (12.0 seconds) and wrote 21 records for ETHUSD-BMEX | 2018-11-15 10:17:16 Added 1 Time and Sales records to Intraday data file for ETHUSD-BMEX after download. | 2018-11-15 10:17:16 HD Request # 14 | Completion time: 1s | 2018-11-15 10:17:16 HD Request # 14 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 13 | 2018-11-15 10:17:16 Removed historical data download ID 13 | 2018-11-15 10:17:16 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:17:16 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:17:16 HD Request # 15 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:17:16 HD Request # 15 | Download start date-time: 2018-11-15 10:16:59.000 | 2018-11-15 10:17:16 HD Request # 15 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:17:16 Socket (5) | Creating socket. | 2018-11-15 10:17:16 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:17:16 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:17:16 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:17:16 Socket (4) | Closed. | 2018-11-15 10:17:16 HD Request # 15 | Setting DTC encoding to Binary VLS | 2018-11-15 10:17:16 HD Request # 15 | Sending historical data logon request message. | 2018-11-15 10:17:16 HD Request # 15 | Requesting Intraday data. Start date-time: 2018-11-15 10:16:59. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:17:17 HD Request # 15 | Decompressing data. | 2018-11-15 10:17:17 HD Request # 15 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:17:02 | 2018-11-15 10:17:17 HD Request # 15 | Timestamp of first Intraday data file record written: 2018-11-15 10:17:02 | 2018-11-15 10:17:17 Socket (5) | Signaling to core to close socket | 2018-11-15 10:17:17 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:17:17 Historical data download thread signaled to stop. | 2018-11-15 10:17:17 HD Request # 15 | Received 158 records from 2018-11-15 10:17:02 to 2018-11-15 10:17:12 (10.0 seconds) and wrote 158 records for XBTUSD-BMEX | 2018-11-15 10:17:17 Added 26 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:17:17 HD Request # 15 | Completion time: 0s | 2018-11-15 10:17:17 HD Request # 15 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 14 | 2018-11-15 10:17:17 Removed historical data download ID 14 | 2018-11-15 10:17:17 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:17:17 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:17:17 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:17:17 Socket (5) | Closed. | 2018-11-15 10:17:17 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:17:18 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:17:18 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:17:18 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:19:48 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:19:48 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:19:48 BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-11-15 10:19:48 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:19:48 BitMEX WebSocket socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:19:48 Connection to the external service has been lost. | 2018-11-15 10:19:48 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:19:48 HTTPS www.bitmex.com:443 (3) | Signaling to core to close socket | 2018-11-15 10:19:48 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:19:48 HTTPS www.bitmex.com:443 (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:19:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:19:48 HTTPS www.bitmex.com:443 (3) | Socket gracefully closed by remote side. | 2018-11-15 10:19:48 HTTPS www.bitmex.com:443 (3) | Closed. | 2018-11-15 10:19:48 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:19:51 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:19:51 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:19:51 BitMEX WebSocket socket (1) | Connecting to IP: 52.49.24.30. | 2018-11-15 10:19:51 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:19:51 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:19:51 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:19:51 GMT | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=AmaazRRc+QaG+Yn6HqekFhyRUrzuJr5WZ+TSJQjkgJMvTE7xggzk929lR8Zt3PD3WIEvY3cg8AL9JJA+3Dyrbzt5di1vO0MeUuwqqvRLKnq3E6I05xHnWdKsZjjJ; Expires=Wed, 21 Nov 2018 23:19:51 GMT; Path=/ | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: NUwlBiY1XeZqU0xhzdJzknl9+A0= | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:19:52 BitMEX WebSocket | Header line. | 2018-11-15 10:19:52 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:19:52 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:19:52 DTC Client socket (2) | Signaling to core to close socket | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:19:52 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:19:52 DTC Client socket (3) | Creating socket. | 2018-11-15 10:19:52 DTC Client socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:19:52 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:19:52 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 2 | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 2 | 2018-11-15 10:19:52 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:19:52 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:19:52 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 4 | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 4 | 2018-11-15 10:19:52 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 5 | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 5 | 2018-11-15 10:19:52 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:19:52 DTC Client socket (2) | Received socket Close event. | 2018-11-15 10:19:52 DTC Client socket (2) | Still waiting for graceful close or receive error. | 2018-11-15 10:19:52 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:19:52 DTC Client socket (2) | Closed. | 2018-11-15 10:19:52 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:19:52 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:19:53 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:19:54 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:19:54 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:19:55 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:19:55 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:19:55 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:19:55 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:19:55 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:19:55 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:19:55 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:19:57 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 52.49.24.30. | 2018-11-15 10:19:57 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:19:57 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:19:57 HD Request # 16 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:19:59 HD Request # 16 | Download start date-time: 2018-11-15 10:19:50.000 | 2018-11-15 10:19:59 HD Request # 16 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:19:59 Socket (4) | Creating socket. | 2018-11-15 10:19:59 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:19:59 HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-11-15 10:20:00 HD Request # 16 | Sending historical data logon request message. | 2018-11-15 10:20:00 HD Request # 16 | Requesting Intraday data. Start date-time: 2018-11-15 10:19:50. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:20:00 HD Request # 16 | Decompressing data. | 2018-11-15 10:20:01 HD Request # 16 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:19:50 | 2018-11-15 10:20:01 HD Request # 16 | Timestamp of first Intraday data file record written: 2018-11-15 10:19:52 | 2018-11-15 10:20:01 Socket (4) | Signaling to core to close socket | 2018-11-15 10:20:01 Historical data download thread signaled to stop. | 2018-11-15 10:20:01 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:20:01 HD Request # 16 | Received 81 records from 2018-11-15 10:19:50 to 2018-11-15 10:19:59 (9.0 seconds) and wrote 60 records for XBTUSD-BMEX | 2018-11-15 10:20:01 HD Request # 16 | Completion time: 1s | 2018-11-15 10:20:01 HD Request # 16 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 15 | 2018-11-15 10:20:01 Removed historical data download ID 15 | 2018-11-15 10:20:01 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:20:01 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:20:01 HD Request # 17 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:20:01 HD Request # 17 | Download start date-time: 2018-11-15 10:19:48.000 | 2018-11-15 10:20:01 HD Request # 17 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:20:01 Socket (5) | Creating socket. | 2018-11-15 10:20:01 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:20:01 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:20:01 Socket (4) | Closed. | 2018-11-15 10:20:01 HD Request # 17 | Setting DTC encoding to Binary VLS | 2018-11-15 10:20:01 HD Request # 17 | Sending historical data logon request message. | 2018-11-15 10:20:01 HD Request # 17 | Requesting Intraday data. Start date-time: 2018-11-15 10:19:48. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:20:02 HD Request # 17 | Decompressing data. | 2018-11-15 10:20:02 HD Request # 17 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:19:48 | 2018-11-15 10:20:02 HD Request # 17 | Timestamp of first Intraday data file record written: 2018-11-15 10:19:51 | 2018-11-15 10:20:02 Socket (5) | Signaling to core to close socket | 2018-11-15 10:20:02 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:20:02 Historical data download thread signaled to stop. | 2018-11-15 10:20:02 HD Request # 17 | Received 7 records from 2018-11-15 10:19:48 to 2018-11-15 10:19:58 (10.0 seconds) and wrote 6 records for ETHUSD-BMEX | 2018-11-15 10:20:02 HD Request # 17 | Completion time: 0s | 2018-11-15 10:20:02 HD Request # 17 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 16 | 2018-11-15 10:20:02 Removed historical data download ID 16 | 2018-11-15 10:20:02 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:20:02 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:20:02 HD Request # 18 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:20:02 HD Request # 18 | Download start date-time: 2018-11-15 10:19:45.000 | 2018-11-15 10:20:02 HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:20:02 Socket (4) | Creating socket. | 2018-11-15 10:20:02 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:20:02 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:20:02 Socket (5) | Closed. | 2018-11-15 10:20:02 HD Request # 18 | Setting DTC encoding to Binary VLS | 2018-11-15 10:20:03 HD Request # 18 | Sending historical data logon request message. | 2018-11-15 10:20:03 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:20:03 HD Request # 18 | Requesting Intraday data. Start date-time: 2018-11-15 10:19:45. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:20:03 HD Request # 18 | Decompressing data. | 2018-11-15 10:20:03 HD Request # 18 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:19:45 | 2018-11-15 10:20:03 Socket (4) | Signaling to core to close socket | 2018-11-15 10:20:03 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:20:03 Historical data download thread signaled to stop. | 2018-11-15 10:20:03 HD Request # 18 | Received 2 records from 2018-11-15 10:19:45 to 2018-11-15 10:19:45 (0.0 seconds) and wrote 0 records for BTCUSD-BITFINEX | 2018-11-15 10:20:03 HD Request # 18 | Completion time: 2s | 2018-11-15 10:20:03 HD Request # 18 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 17 | 2018-11-15 10:20:03 Removed historical data download ID 17 | 2018-11-15 10:20:03 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:20:03 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:20:03 HD Request # 19 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:20:03 HD Request # 19 | Download start date-time: 2018-11-15 10:19:39.000 | 2018-11-15 10:20:03 HD Request # 19 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:20:03 Socket (5) | Creating socket. | 2018-11-15 10:20:03 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:20:03 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:20:04 Socket (4) | Closed. | 2018-11-15 10:20:04 HD Request # 19 | Setting DTC encoding to Binary VLS | 2018-11-15 10:20:04 HD Request # 19 | Sending historical data logon request message. | 2018-11-15 10:20:04 HD Request # 19 | Requesting Intraday data. Start date-time: 2018-11-15 10:19:39. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:20:04 HD Request # 19 | Decompressing data. | 2018-11-15 10:20:04 HD Request # 19 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:19:39 | 2018-11-15 10:20:04 Socket (5) | Signaling to core to close socket | 2018-11-15 10:20:04 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:20:04 Historical data download thread signaled to stop. | 2018-11-15 10:20:04 HD Request # 19 | Received 1 record from 2018-11-15 10:19:39 to 2018-11-15 10:19:39 (0.0 seconds) and wrote 0 records for XBTZ18-BMEX | 2018-11-15 10:20:04 HD Request # 19 | Completion time: 0s | 2018-11-15 10:20:04 HD Request # 19 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 18 | 2018-11-15 10:20:04 Removed historical data download ID 18 | 2018-11-15 10:20:04 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:20:04 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:20:04 HD Request # 20 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:20:04 HD Request # 20 | Download start date-time: 2018-11-15 10:19:49.000 | 2018-11-15 10:20:04 HD Request # 20 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:20:04 Socket (4) | Creating socket. | 2018-11-15 10:20:04 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:20:04 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:20:05 Socket (5) | Closed. | 2018-11-15 10:20:05 HD Request # 20 | Setting DTC encoding to Binary VLS | 2018-11-15 10:20:05 HD Request # 20 | Sending historical data logon request message. | 2018-11-15 10:20:05 HD Request # 20 | Requesting Intraday data. Start date-time: 2018-11-15 10:19:49. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:20:05 HD Request # 20 | Decompressing data. | 2018-11-15 10:20:06 HD Request # 20 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:19:49 | 2018-11-15 10:20:06 HD Request # 20 | Timestamp of first Intraday data file record written: 2018-11-15 10:19:51 | 2018-11-15 10:20:06 Socket (4) | Signaling to core to close socket | 2018-11-15 10:20:06 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:20:06 Historical data download thread signaled to stop. | 2018-11-15 10:20:06 HD Request # 20 | Received 16 records from 2018-11-15 10:19:49 to 2018-11-15 10:20:00 (11.0 seconds) and wrote 15 records for ETHUSD-BITFINEX | 2018-11-15 10:20:06 Added 1 Time and Sales records to Intraday data file for ETHUSD-BITFINEX after download. | 2018-11-15 10:20:06 HD Request # 20 | Completion time: 0s | 2018-11-15 10:20:06 HD Request # 20 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 19 | 2018-11-15 10:20:06 Removed historical data download ID 19 | 2018-11-15 10:20:06 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:20:06 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:20:06 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:20:06 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:20:06 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:20:06 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:20:06 Socket (4) | Closed. | 2018-11-15 10:20:06 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:20:06 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:20:06 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:20:09 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:20:09 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:20:12 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 10:23:52 HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:23:52 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:23:52 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:23:52 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 10:23:52 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:25:33 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 34.249.83.22. | 2018-11-15 10:25:33 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX is currently unavailable. | 2018-11-15 10:26:09 SC DTC Data with Market Depth | Real-time data for symbol XBTZ18-BMEX is currently unavailable. | 2018-11-15 10:26:09 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX is currently unavailable. | 2018-11-15 10:26:09 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:26:20 SC DTC Data with Market Depth | Real-time data for symbol XBTZ18-BMEX has been restored. | 2018-11-15 10:26:20 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:26:20 HD Request # 21 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:26:20 HD Request # 21 | Download start date-time: 2018-11-15 10:26:03.000 | 2018-11-15 10:26:20 HD Request # 21 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:26:20 Socket (4) | Creating socket. | 2018-11-15 10:26:20 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:26:20 HD Request # 21 | Setting DTC encoding to Binary VLS | 2018-11-15 10:26:20 HD Request # 21 | Sending historical data logon request message. | 2018-11-15 10:26:20 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:26:20 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:26:20 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:26:20 SC DTC Data with Market Depth | Real-time data for symbol ETHUSD-BMEX has been restored. | 2018-11-15 10:26:20 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:26:20 HD Request # 21 | Requesting Intraday data. Start date-time: 2018-11-15 10:26:03. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:26:20 HD Request # 21 | Decompressing data. | 2018-11-15 10:26:21 HD Request # 21 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:26:03 | 2018-11-15 10:26:21 HD Request # 21 | Timestamp of first Intraday data file record written: 2018-11-15 10:26:03 | 2018-11-15 10:26:21 Socket (4) | Signaling to core to close socket | 2018-11-15 10:26:21 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:26:21 Historical data download thread signaled to stop. | 2018-11-15 10:26:21 HD Request # 21 | Received 56 records from 2018-11-15 10:26:03 to 2018-11-15 10:26:14 (11.0 seconds) and wrote 50 records for XBTZ18-BMEX | 2018-11-15 10:26:21 HD Request # 21 | Completion time: 1s | 2018-11-15 10:26:21 HD Request # 21 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 20 | 2018-11-15 10:26:21 Removed historical data download ID 20 | 2018-11-15 10:26:21 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:26:21 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:26:21 HD Request # 22 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:26:21 HD Request # 22 | Download start date-time: 2018-11-15 10:26:03.000 | 2018-11-15 10:26:21 HD Request # 22 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:26:21 Socket (5) | Creating socket. | 2018-11-15 10:26:21 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:26:21 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:26:21 Socket (4) | Closed. | 2018-11-15 10:26:21 HD Request # 22 | Setting DTC encoding to Binary VLS | 2018-11-15 10:26:21 HD Request # 22 | Sending historical data logon request message. | 2018-11-15 10:26:21 HD Request # 22 | Requesting Intraday data. Start date-time: 2018-11-15 10:26:03. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:26:22 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:26:22 SC DTC Data with Market Depth | Real-time data for symbol XBTUSD-BMEX has been restored. | 2018-11-15 10:26:22 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:26:22 HD Request # 22 | Decompressing data. | 2018-11-15 10:26:22 HD Request # 22 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:26:03 | 2018-11-15 10:26:22 HD Request # 22 | Timestamp of first Intraday data file record written: 2018-11-15 10:26:04 | 2018-11-15 10:26:22 Socket (5) | Signaling to core to close socket | 2018-11-15 10:26:22 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:26:22 Historical data download thread signaled to stop. | 2018-11-15 10:26:22 HD Request # 22 | Received 38 records from 2018-11-15 10:26:03 to 2018-11-15 10:26:14 (11.0 seconds) and wrote 37 records for ETHUSD-BMEX | 2018-11-15 10:26:22 HD Request # 22 | Completion time: 0s | 2018-11-15 10:26:22 HD Request # 22 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 21 | 2018-11-15 10:26:22 Removed historical data download ID 21 | 2018-11-15 10:26:22 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:26:22 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:26:22 HD Request # 23 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:26:22 HD Request # 23 | Download start date-time: 2018-11-15 10:26:03.000 | 2018-11-15 10:26:22 HD Request # 23 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:26:22 Socket (4) | Creating socket. | 2018-11-15 10:26:22 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:26:22 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:26:22 Socket (5) | Closed. | 2018-11-15 10:26:22 HD Request # 23 | Setting DTC encoding to Binary VLS | 2018-11-15 10:26:22 HD Request # 23 | Sending historical data logon request message. | 2018-11-15 10:26:22 HD Request # 23 | Requesting Intraday data. Start date-time: 2018-11-15 10:26:03. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:26:23 HD Request # 23 | Decompressing data. | 2018-11-15 10:26:23 HD Request # 23 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:26:03 | 2018-11-15 10:26:23 HD Request # 23 | Timestamp of first Intraday data file record written: 2018-11-15 10:26:03 | 2018-11-15 10:26:23 Socket (4) | Signaling to core to close socket | 2018-11-15 10:26:23 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:26:23 Historical data download thread signaled to stop. | 2018-11-15 10:26:23 HD Request # 23 | Received 657 records from 2018-11-15 10:26:03 to 2018-11-15 10:26:18 (15.0 seconds) and wrote 654 records for XBTUSD-BMEX | 2018-11-15 10:26:23 HD Request # 23 | Completion time: 2s | 2018-11-15 10:26:23 HD Request # 23 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 22 | 2018-11-15 10:26:23 Removed historical data download ID 22 | 2018-11-15 10:26:23 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:26:23 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:26:23 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:26:23 Socket (4) | Closed. | 2018-11-15 10:26:23 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:26:24 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:26:27 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:26:27 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:26:27 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:27:24 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:27:24 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:27:24 BitMEX WebSocket | Network socket for WebSocket has been closed by remote side. | 2018-11-15 10:27:24 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:27:24 Connection to the external service has been lost. | 2018-11-15 10:27:24 BitMEX WebSocket socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:27:24 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:27:24 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:27:24 HTTPS www.bitmex.com:443 (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:27:24 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:27:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:27:24 HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:27:25 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 10:27:25 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:27:27 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:27:27 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:27:27 BitMEX WebSocket socket (1) | Connecting to IP: 54.171.8.37. | 2018-11-15 10:27:27 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:27:28 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:27:28 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:27:28 GMT | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=qL0eDn8nHwhWQyrtoVlw2/3mupDXMkHZwIbjuUJQWbJGQeF1Tff+KEvmfzn4/Sh20GWoRxJthH5rvZwQkGQTHhbZXNaOfdlQSFKylpD5Nt8CdEafOmIdJWX6z8Qd; Expires=Wed, 21 Nov 2018 23:27:28 GMT; Path=/ | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: jnZrKTp0Vwi9sphtM4thB0gD4KU= | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:27:29 BitMEX WebSocket | Header line. | 2018-11-15 10:27:29 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:27:29 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:27:29 DTC Client socket (3) | Signaling to core to close socket | 2018-11-15 10:27:29 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 1 | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 10048 | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 1 | 2018-11-15 10:27:29 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:27:29 DTC Client socket (2) | Creating socket. | 2018-11-15 10:27:29 DTC Client socket (2) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:27:29 Delaying start of download for ETHUSD-BITFINEX | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:27:29 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:27:29 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:27:29 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 4 | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 4 | 2018-11-15 10:27:29 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:27:29 DTC Client socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:27:29 DTC Client socket (3) | Closed. | 2018-11-15 10:27:29 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:27:29 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:27:29 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:27:30 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:27:31 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:27:31 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:27:31 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:27:31 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:27:34 HTTPS www.bitmex.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-11-15 10:27:34 HTTPS www.bitmex.com:443 (3) | Connecting to IP: 54.171.8.37. | 2018-11-15 10:27:34 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:27:34 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:27:34 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:27:34 HD Request # 24 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:27:34 HD Request # 24 | Download start date-time: 2018-11-15 10:27:22.000 | 2018-11-15 10:27:34 HD Request # 24 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:27:34 Socket (4) | Creating socket. | 2018-11-15 10:27:34 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:27:34 HD Request # 24 | Setting DTC encoding to Binary VLS | 2018-11-15 10:27:35 HD Request # 24 | Sending historical data logon request message. | 2018-11-15 10:27:35 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:27:35 HD Request # 24 | Requesting Intraday data. Start date-time: 2018-11-15 10:27:22. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:27:35 HD Request # 24 | Decompressing data. | 2018-11-15 10:27:36 HD Request # 24 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:27:22 | 2018-11-15 10:27:36 HD Request # 24 | Timestamp of first Intraday data file record written: 2018-11-15 10:27:28 | 2018-11-15 10:27:36 Socket (4) | Signaling to core to close socket | 2018-11-15 10:27:36 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:27:36 Historical data download thread signaled to stop. | 2018-11-15 10:27:36 HD Request # 24 | Received 6 records from 2018-11-15 10:27:22 to 2018-11-15 10:27:31 (9.0 seconds) and wrote 4 records for ETHUSD-BITFINEX | 2018-11-15 10:27:36 Added 4 Time and Sales records to Intraday data file for ETHUSD-BITFINEX after download. | 2018-11-15 10:27:36 HD Request # 24 | Completion time: 0s | 2018-11-15 10:27:36 HD Request # 24 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 23 | 2018-11-15 10:27:36 Removed historical data download ID 23 | 2018-11-15 10:27:36 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:27:36 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:27:36 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:27:36 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:27:36 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:27:36 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:27:36 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:27:36 Socket (4) | Closed. | 2018-11-15 10:27:36 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:27:36 HD Request # 25 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:27:36 HD Request # 25 | Download start date-time: 2018-11-15 10:27:27.000 | 2018-11-15 10:27:36 HD Request # 25 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:27:36 Socket (4) | Creating socket. | 2018-11-15 10:27:36 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:27:36 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:27:36 HD Request # 25 | Setting DTC encoding to Binary VLS | 2018-11-15 10:27:37 HD Request # 25 | Sending historical data logon request message. | 2018-11-15 10:27:37 HD Request # 25 | Requesting Intraday data. Start date-time: 2018-11-15 10:27:27. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:27:37 HD Request # 25 | Decompressing data. | 2018-11-15 10:27:37 HD Request # 25 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:27:27 | 2018-11-15 10:27:37 HD Request # 25 | Timestamp of first Intraday data file record written: 2018-11-15 10:27:27 | 2018-11-15 10:27:37 Socket (4) | Signaling to core to close socket | 2018-11-15 10:27:37 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:27:37 Historical data download thread signaled to stop. | 2018-11-15 10:27:37 HD Request # 25 | Received 49 records from 2018-11-15 10:27:27 to 2018-11-15 10:27:34 (7.0 seconds) and wrote 44 records for XBTUSD-BMEX | 2018-11-15 10:27:37 Added 18 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:27:37 HD Request # 25 | Completion time: 0s | 2018-11-15 10:27:37 HD Request # 25 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 24 | 2018-11-15 10:27:37 Removed historical data download ID 24 | 2018-11-15 10:27:37 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:27:37 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:27:37 HD Request # 26 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:27:37 HD Request # 26 | Download start date-time: 2018-11-15 10:27:25.000 | 2018-11-15 10:27:37 HD Request # 26 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:27:37 Socket (5) | Creating socket. | 2018-11-15 10:27:37 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:27:37 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:27:38 Socket (4) | Closed. | 2018-11-15 10:27:38 HD Request # 26 | Setting DTC encoding to Binary VLS | 2018-11-15 10:27:38 HD Request # 26 | Sending historical data logon request message. | 2018-11-15 10:27:38 HD Request # 26 | Requesting Intraday data. Start date-time: 2018-11-15 10:27:25. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:27:38 HD Request # 26 | Decompressing data. | 2018-11-15 10:27:39 HD Request # 26 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:27:25 | 2018-11-15 10:27:39 HD Request # 26 | Timestamp of first Intraday data file record written: 2018-11-15 10:27:28 | 2018-11-15 10:27:39 Socket (5) | Signaling to core to close socket | 2018-11-15 10:27:39 Historical data download thread signaled to stop. | 2018-11-15 10:27:39 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:27:39 HD Request # 26 | Received 5 records from 2018-11-15 10:27:25 to 2018-11-15 10:27:34 (9.0 seconds) and wrote 4 records for BTCUSD-BITFINEX | 2018-11-15 10:27:39 Added 1 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:27:39 HD Request # 26 | Completion time: 0s | 2018-11-15 10:27:39 HD Request # 26 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 25 | 2018-11-15 10:27:39 Removed historical data download ID 25 | 2018-11-15 10:27:39 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:27:39 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:27:39 HD Request # 27 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:27:39 HD Request # 27 | Download start date-time: 2018-11-15 10:27:24.000 | 2018-11-15 10:27:39 HD Request # 27 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:27:39 Socket (4) | Creating socket. | 2018-11-15 10:27:39 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:27:39 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:27:39 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:27:39 Socket (5) | Closed. | 2018-11-15 10:27:39 HD Request # 27 | Setting DTC encoding to Binary VLS | 2018-11-15 10:27:39 HD Request # 27 | Sending historical data logon request message. | 2018-11-15 10:27:39 HD Request # 27 | Requesting Intraday data. Start date-time: 2018-11-15 10:27:24. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:27:40 HD Request # 27 | Decompressing data. | 2018-11-15 10:27:40 HD Request # 27 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:27:24 | 2018-11-15 10:27:40 HD Request # 27 | Timestamp of first Intraday data file record written: 2018-11-15 10:27:34 | 2018-11-15 10:27:40 Socket (4) | Signaling to core to close socket | 2018-11-15 10:27:40 Historical data download thread signaled to stop. | 2018-11-15 10:27:40 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:27:40 HD Request # 27 | Received 17 records from 2018-11-15 10:27:24 to 2018-11-15 10:27:36 (12.0 seconds) and wrote 16 records for ETHUSD-BMEX | 2018-11-15 10:27:40 Added 1 Time and Sales records to Intraday data file for ETHUSD-BMEX after download. | 2018-11-15 10:27:40 HD Request # 27 | Completion time: 0s | 2018-11-15 10:27:40 HD Request # 27 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 26 | 2018-11-15 10:27:40 Removed historical data download ID 26 | 2018-11-15 10:27:40 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:27:40 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:27:40 HD Request # 28 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:27:40 HD Request # 28 | Download start date-time: 2018-11-15 10:27:25.000 | 2018-11-15 10:27:40 HD Request # 28 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:27:40 Socket (5) | Creating socket. | 2018-11-15 10:27:40 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:27:40 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:27:40 Socket (4) | Closed. | 2018-11-15 10:27:40 HD Request # 28 | Setting DTC encoding to Binary VLS | 2018-11-15 10:27:41 HD Request # 28 | Sending historical data logon request message. | 2018-11-15 10:27:41 HD Request # 28 | Requesting Intraday data. Start date-time: 2018-11-15 10:27:25. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:27:41 HD Request # 28 | Decompressing data. | 2018-11-15 10:27:41 HD Request # 28 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:27:25 | 2018-11-15 10:27:41 HD Request # 28 | Timestamp of first Intraday data file record written: 2018-11-15 10:27:30 | 2018-11-15 10:27:41 Socket (5) | Signaling to core to close socket | 2018-11-15 10:27:41 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:27:41 Historical data download thread signaled to stop. | 2018-11-15 10:27:41 HD Request # 28 | Received 5 records from 2018-11-15 10:27:25 to 2018-11-15 10:27:35 (10.0 seconds) and wrote 4 records for XBTZ18-BMEX | 2018-11-15 10:27:41 HD Request # 28 | Completion time: 2s | 2018-11-15 10:27:41 HD Request # 28 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 27 | 2018-11-15 10:27:41 Removed historical data download ID 27 | 2018-11-15 10:27:41 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:27:41 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:27:41 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:27:42 Socket (5) | Closed. | 2018-11-15 10:27:42 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:27:42 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:27:42 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:27:42 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:29:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:30:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:30:14 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:30:38 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:30:38 Connection to the external service has been lost. | 2018-11-15 10:30:38 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:30:38 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:30:38 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:30:38 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:30:38 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:30:38 HTTPS www.bitmex.com:443 (3) | Signaling to core to close socket | 2018-11-15 10:30:38 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:30:38 HTTPS www.bitmex.com:443 (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:30:38 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:30:38 HTTPS www.bitmex.com:443 (3) | Socket gracefully closed by remote side. | 2018-11-15 10:30:38 HTTPS www.bitmex.com:443 (3) | Closed. | 2018-11-15 10:30:38 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:30:39 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:39 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:30:39 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:30:39 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:30:41 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:30:41 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:30:41 BitMEX WebSocket socket (1) | Connecting to IP: 34.248.216.179. | 2018-11-15 10:30:41 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:30:41 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:30:41 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:30:41 GMT | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=Oc1h9Fu8YEbM6SpoIZoBk/pBK+rtSBJIUHANE22Hnd7KdiOtl6dlVMRIT4JBmTxzTKd1zkm+rVGsrw4bd7W53sT/vJzZkgYI2C1VjNT05Hxk814Ogd+4dXyVbvHI; Expires=Wed, 21 Nov 2018 23:30:41 GMT; Path=/ | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: rqnrEQqdbVKt2O6KPnbXBWA/xm4= | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:30:42 BitMEX WebSocket | Header line. | 2018-11-15 10:30:42 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:30:42 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:30:42 DTC Client socket (2) | Signaling to core to close socket | 2018-11-15 10:30:42 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 1 | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 1 | 2018-11-15 10:30:42 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:30:42 DTC Client socket (3) | Creating socket. | 2018-11-15 10:30:42 DTC Client socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:30:42 Delaying start of download for ETHUSD-BMEX | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:30:42 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:30:42 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:30:42 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:30:42 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:30:43 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:30:43 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:30:43 DTC Client socket (2) | Closed. | 2018-11-15 10:30:43 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:30:43 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:30:43 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:30:44 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:30:44 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:30:44 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:30:45 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:30:45 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:30:45 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:30:45 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:30:46 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:30:46 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:30:46 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:30:47 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 34.248.216.179. | 2018-11-15 10:30:47 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:30:47 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:30:48 HD Request # 29 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:30:48 HD Request # 29 | Download start date-time: 2018-11-15 10:30:40.000 | 2018-11-15 10:30:48 HD Request # 29 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:30:48 Socket (4) | Creating socket. | 2018-11-15 10:30:48 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:30:48 HD Request # 29 | Setting DTC encoding to Binary VLS | 2018-11-15 10:30:49 HD Request # 29 | Sending historical data logon request message. | 2018-11-15 10:30:49 HD Request # 29 | Requesting Intraday data. Start date-time: 2018-11-15 10:30:40. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:30:49 HD Request # 29 | Decompressing data. | 2018-11-15 10:30:50 HD Request # 29 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:30:40 | 2018-11-15 10:30:50 HD Request # 29 | Timestamp of first Intraday data file record written: 2018-11-15 10:30:43 | 2018-11-15 10:30:50 Socket (4) | Signaling to core to close socket | 2018-11-15 10:30:50 Historical data download thread signaled to stop. | 2018-11-15 10:30:50 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:50 HD Request # 29 | Received 12 records from 2018-11-15 10:30:40 to 2018-11-15 10:30:43 (3.0 seconds) and wrote 7 records for ETHUSD-BMEX | 2018-11-15 10:30:50 HD Request # 29 | Completion time: 0s | 2018-11-15 10:30:50 HD Request # 29 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 28 | 2018-11-15 10:30:50 Removed historical data download ID 28 | 2018-11-15 10:30:50 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:30:50 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:30:50 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:30:50 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:30:50 Socket (4) | Closed. | 2018-11-15 10:30:50 HD Request # 30 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:30:50 HD Request # 30 | Download start date-time: 2018-11-15 10:30:41.000 | 2018-11-15 10:30:50 HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:30:50 Socket (4) | Creating socket. | 2018-11-15 10:30:50 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:30:50 HD Request # 30 | Setting DTC encoding to Binary VLS | 2018-11-15 10:30:51 HD Request # 30 | Sending historical data logon request message. | 2018-11-15 10:30:51 HD Request # 30 | Requesting Intraday data. Start date-time: 2018-11-15 10:30:41. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:30:52 HD Request # 30 | Decompressing data. | 2018-11-15 10:30:52 HD Request # 30 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:30:41 | 2018-11-15 10:30:52 HD Request # 30 | Timestamp of first Intraday data file record written: 2018-11-15 10:30:42 | 2018-11-15 10:30:52 Socket (4) | Signaling to core to close socket | 2018-11-15 10:30:52 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:52 Historical data download thread signaled to stop. | 2018-11-15 10:30:52 HD Request # 30 | Received 40 records from 2018-11-15 10:30:41 to 2018-11-15 10:30:47 (6.0 seconds) and wrote 37 records for XBTUSD-BMEX | 2018-11-15 10:30:52 Added 27 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:30:52 HD Request # 30 | Completion time: 0s | 2018-11-15 10:30:52 HD Request # 30 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 29 | 2018-11-15 10:30:52 Removed historical data download ID 29 | 2018-11-15 10:30:52 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:30:52 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:30:52 HD Request # 31 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:30:52 HD Request # 31 | Download start date-time: 2018-11-15 10:30:40.000 | 2018-11-15 10:30:52 HD Request # 31 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:30:52 Socket (5) | Creating socket. | 2018-11-15 10:30:52 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:30:52 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:30:52 Socket (4) | Closed. | 2018-11-15 10:30:52 HD Request # 31 | Setting DTC encoding to Binary VLS | 2018-11-15 10:30:53 HD Request # 31 | Sending historical data logon request message. | 2018-11-15 10:30:53 HD Request # 31 | Requesting Intraday data. Start date-time: 2018-11-15 10:30:40. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:30:53 HD Request # 31 | Decompressing data. | 2018-11-15 10:30:53 HD Request # 31 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:30:40 | 2018-11-15 10:30:53 Socket (5) | Signaling to core to close socket | 2018-11-15 10:30:53 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:53 Historical data download thread signaled to stop. | 2018-11-15 10:30:53 HD Request # 31 | Received 1 record from 2018-11-15 10:30:40 to 2018-11-15 10:30:40 (0.0 seconds) and wrote 0 records for ETHUSD-BITFINEX | 2018-11-15 10:30:53 HD Request # 31 | Timestamp of first Intraday data file record written: 2018-11-15 10:30:49 | 2018-11-15 10:30:53 Added 23 Time and Sales records to Intraday data file for ETHUSD-BITFINEX after download. | 2018-11-15 10:30:53 HD Request # 31 | Completion time: 2s | 2018-11-15 10:30:53 HD Request # 31 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 30 | 2018-11-15 10:30:53 Removed historical data download ID 30 | 2018-11-15 10:30:53 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:30:53 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:30:53 HD Request # 32 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:30:53 HD Request # 32 | Download start date-time: 2018-11-15 10:30:39.000 | 2018-11-15 10:30:53 HD Request # 32 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:30:53 Socket (4) | Creating socket. | 2018-11-15 10:30:53 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:30:53 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:30:53 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:30:53 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:30:53 Socket (5) | Closed. | 2018-11-15 10:30:53 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:30:53 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:30:54 HD Request # 32 | Setting DTC encoding to Binary VLS | 2018-11-15 10:30:54 HD Request # 32 | Sending historical data logon request message. | 2018-11-15 10:30:54 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:30:54 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:30:54 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:30:54 HD Request # 32 | Requesting Intraday data. Start date-time: 2018-11-15 10:30:39. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:30:54 HD Request # 32 | Decompressing data. | 2018-11-15 10:30:55 HD Request # 32 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:30:39 | 2018-11-15 10:30:55 HD Request # 32 | Timestamp of first Intraday data file record written: 2018-11-15 10:30:43 | 2018-11-15 10:30:55 Socket (4) | Signaling to core to close socket | 2018-11-15 10:30:55 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:55 Historical data download thread signaled to stop. | 2018-11-15 10:30:55 HD Request # 32 | Received 86 records from 2018-11-15 10:30:39 to 2018-11-15 10:30:52 (13.0 seconds) and wrote 84 records for BTCUSD-BITFINEX | 2018-11-15 10:30:55 Added 3 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:30:55 HD Request # 32 | Completion time: 1s | 2018-11-15 10:30:55 HD Request # 32 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 31 | 2018-11-15 10:30:55 Removed historical data download ID 31 | 2018-11-15 10:30:55 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:30:55 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:30:55 HD Request # 33 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:30:55 HD Request # 33 | Download start date-time: 2018-11-15 10:30:40.000 | 2018-11-15 10:30:55 HD Request # 33 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:30:55 Socket (5) | Creating socket. | 2018-11-15 10:30:55 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:30:55 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:30:55 Socket (4) | Closed. | 2018-11-15 10:30:55 HD Request # 33 | Setting DTC encoding to Binary VLS | 2018-11-15 10:30:55 HD Request # 33 | Sending historical data logon request message. | 2018-11-15 10:30:55 HD Request # 33 | Requesting Intraday data. Start date-time: 2018-11-15 10:30:40. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:30:55 HD Request # 33 | Decompressing data. | 2018-11-15 10:30:56 HD Request # 33 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:30:40 | 2018-11-15 10:30:56 HD Request # 33 | Timestamp of first Intraday data file record written: 2018-11-15 10:30:42 | 2018-11-15 10:30:56 Socket (5) | Signaling to core to close socket | 2018-11-15 10:30:56 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:30:56 Historical data download thread signaled to stop. | 2018-11-15 10:30:56 HD Request # 33 | Received 13 records from 2018-11-15 10:30:40 to 2018-11-15 10:30:50 (10.0 seconds) and wrote 10 records for XBTZ18-BMEX | 2018-11-15 10:30:56 Added 8 Time and Sales records to Intraday data file for XBTZ18-BMEX after download. | 2018-11-15 10:30:56 HD Request # 33 | Completion time: 0s | 2018-11-15 10:30:56 HD Request # 33 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 32 | 2018-11-15 10:30:56 Removed historical data download ID 32 | 2018-11-15 10:30:56 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:30:56 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:30:56 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:30:56 Socket (5) | Closed. | 2018-11-15 10:30:56 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:30:57 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:30:57 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:31:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:32:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:32:34 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:32:59 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:32:59 Connection to the external service has been lost. | 2018-11-15 10:32:59 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:32:59 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:32:59 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:32:59 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:32:59 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:32:59 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:32:59 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:32:59 HTTPS www.bitmex.com:443 (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:32:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:32:59 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:33:00 HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:33:00 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 10:33:00 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:33:00 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:33:00 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:33:00 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:33:00 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:33:02 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:33:02 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:33:02 BitMEX WebSocket socket (1) | Connecting to IP: 34.249.83.22. | 2018-11-15 10:33:02 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:33:03 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:33:03 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:33:03 GMT | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=Np+NBgP6RsGqkZWHYfJjC1z17xMIEyZyZRhUgnjzt5KxuDhF0ozsweL3k56SkKM/lXg75wuazu1alAfGQw0laUh+NtKWYGWXrHvrZZXLfxOgZkycu+0fJugwt5cA; Expires=Wed, 21 Nov 2018 23:33:03 GMT; Path=/ | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: SsfEMPZ16WnjpPtHuS1rOaeCw/A= | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:33:04 BitMEX WebSocket | Header line. | 2018-11-15 10:33:04 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:33:04 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:33:04 DTC Client socket (3) | Signaling to core to close socket | 2018-11-15 10:33:04 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 1 | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 1 | 2018-11-15 10:33:04 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:33:04 DTC Client socket (2) | Creating socket. | 2018-11-15 10:33:04 DTC Client socket (2) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:33:04 Delaying start of download for ETHUSD-BITFINEX | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 2 | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 2 | 2018-11-15 10:33:04 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 3 | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 3 | 2018-11-15 10:33:04 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:33:04 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:33:04 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:33:04 DTC Client socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:33:04 DTC Client socket (3) | Closed. | 2018-11-15 10:33:04 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:33:04 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:33:04 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:33:05 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:33:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:33:06 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:33:06 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:33:06 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:33:07 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:33:07 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:33:07 HTTPS www.bitmex.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 10:33:09 HTTPS www.bitmex.com:443 (4) | Connecting to IP: 34.249.83.22. | 2018-11-15 10:33:09 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:33:09 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:33:09 HD Request # 34 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:33:09 HD Request # 34 | Download start date-time: 2018-11-15 10:33:02.000 | 2018-11-15 10:33:09 HD Request # 34 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:33:09 Socket (5) | Creating socket. | 2018-11-15 10:33:09 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:33:09 HD Request # 34 | Setting DTC encoding to Binary VLS | 2018-11-15 10:33:10 HD Request # 34 | Sending historical data logon request message. | 2018-11-15 10:33:10 HD Request # 34 | Requesting Intraday data. Start date-time: 2018-11-15 10:33:02. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:33:10 HD Request # 34 | Decompressing data. | 2018-11-15 10:33:11 HD Request # 34 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:33:02 | 2018-11-15 10:33:11 HD Request # 34 | Timestamp of first Intraday data file record written: 2018-11-15 10:33:03 | 2018-11-15 10:33:11 Socket (5) | Signaling to core to close socket | 2018-11-15 10:33:11 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:33:11 Historical data download thread signaled to stop. | 2018-11-15 10:33:11 HD Request # 34 | Received 21 records from 2018-11-15 10:33:02 to 2018-11-15 10:33:08 (6.0 seconds) and wrote 19 records for ETHUSD-BITFINEX | 2018-11-15 10:33:11 HD Request # 34 | Completion time: 0s | 2018-11-15 10:33:11 HD Request # 34 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 33 | 2018-11-15 10:33:11 Removed historical data download ID 33 | 2018-11-15 10:33:11 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:33:11 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:33:11 HD Request # 35 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:33:11 HD Request # 35 | Download start date-time: 2018-11-15 10:32:59.000 | 2018-11-15 10:33:11 HD Request # 35 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:33:11 Socket (6) | Creating socket. | 2018-11-15 10:33:11 Socket (6) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:33:11 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:33:11 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:33:11 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:33:11 Socket (5) | Closed. | 2018-11-15 10:33:11 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:33:11 HD Request # 35 | Setting DTC encoding to Binary VLS | 2018-11-15 10:33:11 HD Request # 35 | Sending historical data logon request message. | 2018-11-15 10:33:11 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:33:11 HD Request # 35 | Requesting Intraday data. Start date-time: 2018-11-15 10:32:59. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:33:12 HD Request # 35 | Decompressing data. | 2018-11-15 10:33:12 HD Request # 35 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:32:59 | 2018-11-15 10:33:12 HD Request # 35 | Timestamp of first Intraday data file record written: 2018-11-15 10:33:03 | 2018-11-15 10:33:12 Socket (6) | Signaling to core to close socket | 2018-11-15 10:33:12 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:33:12 Historical data download thread signaled to stop. | 2018-11-15 10:33:12 HD Request # 35 | Received 40 records from 2018-11-15 10:32:59 to 2018-11-15 10:33:07 (8.0 seconds) and wrote 39 records for ETHUSD-BMEX | 2018-11-15 10:33:12 Added 2 Time and Sales records to Intraday data file for ETHUSD-BMEX after download. | 2018-11-15 10:33:12 HD Request # 35 | Completion time: 1s | 2018-11-15 10:33:12 HD Request # 35 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 34 | 2018-11-15 10:33:12 Removed historical data download ID 34 | 2018-11-15 10:33:12 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:33:12 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:33:12 HD Request # 36 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:33:12 HD Request # 36 | Download start date-time: 2018-11-15 10:33:00.000 | 2018-11-15 10:33:12 HD Request # 36 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:33:12 Socket (5) | Creating socket. | 2018-11-15 10:33:12 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:33:12 Socket (6) | Socket gracefully closed by remote side. | 2018-11-15 10:33:12 Socket (6) | Closed. | 2018-11-15 10:33:12 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:33:12 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:33:12 HD Request # 36 | Setting DTC encoding to Binary VLS | 2018-11-15 10:33:13 HD Request # 36 | Sending historical data logon request message. | 2018-11-15 10:33:13 HD Request # 36 | Requesting Intraday data. Start date-time: 2018-11-15 10:33:00. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:33:13 HD Request # 36 | Decompressing data. | 2018-11-15 10:33:13 HD Request # 36 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:33:03 | 2018-11-15 10:33:13 HD Request # 36 | Timestamp of first Intraday data file record written: 2018-11-15 10:33:03 | 2018-11-15 10:33:13 Socket (5) | Signaling to core to close socket | 2018-11-15 10:33:13 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:33:13 Historical data download thread signaled to stop. | 2018-11-15 10:33:13 HD Request # 36 | Received 37 records from 2018-11-15 10:33:03 to 2018-11-15 10:33:07 (4.0 seconds) and wrote 37 records for XBTUSD-BMEX | 2018-11-15 10:33:13 Added 131 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:33:13 HD Request # 36 | Completion time: 2s | 2018-11-15 10:33:13 HD Request # 36 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 35 | 2018-11-15 10:33:13 Removed historical data download ID 35 | 2018-11-15 10:33:13 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:33:13 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:33:13 HD Request # 37 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:33:13 HD Request # 37 | Download start date-time: 2018-11-15 10:33:03.000 | 2018-11-15 10:33:13 HD Request # 37 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:33:13 Socket (6) | Creating socket. | 2018-11-15 10:33:13 Socket (6) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:33:13 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:33:14 Socket (5) | Closed. | 2018-11-15 10:33:14 HD Request # 37 | Setting DTC encoding to Binary VLS | 2018-11-15 10:33:14 HD Request # 37 | Sending historical data logon request message. | 2018-11-15 10:33:14 HD Request # 37 | Requesting Intraday data. Start date-time: 2018-11-15 10:33:03. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:33:14 HD Request # 37 | Decompressing data. | 2018-11-15 10:33:14 HD Request # 37 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:33:03 | 2018-11-15 10:33:14 HD Request # 37 | Timestamp of first Intraday data file record written: 2018-11-15 10:33:03 | 2018-11-15 10:33:14 Socket (6) | Signaling to core to close socket | 2018-11-15 10:33:14 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:33:14 Historical data download thread signaled to stop. | 2018-11-15 10:33:14 HD Request # 37 | Received 18 records from 2018-11-15 10:33:03 to 2018-11-15 10:33:09 (6.0 seconds) and wrote 17 records for BTCUSD-BITFINEX | 2018-11-15 10:33:14 Added 4 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:33:14 HD Request # 37 | Completion time: 1s | 2018-11-15 10:33:14 HD Request # 37 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 36 | 2018-11-15 10:33:14 Removed historical data download ID 36 | 2018-11-15 10:33:14 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:33:14 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:33:14 HD Request # 38 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:33:14 HD Request # 38 | Download start date-time: 2018-11-15 10:32:57.000 | 2018-11-15 10:33:14 HD Request # 38 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:33:14 Socket (3) | Creating socket. | 2018-11-15 10:33:14 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:33:14 Socket (6) | Socket gracefully closed by remote side. | 2018-11-15 10:33:15 Socket (6) | Closed. | 2018-11-15 10:33:15 HD Request # 38 | Setting DTC encoding to Binary VLS | 2018-11-15 10:33:15 HD Request # 38 | Sending historical data logon request message. | 2018-11-15 10:33:15 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:33:15 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:33:15 HD Request # 38 | Requesting Intraday data. Start date-time: 2018-11-15 10:32:57. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:33:15 HD Request # 38 | Decompressing data. | 2018-11-15 10:33:16 HD Request # 38 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:32:57 | 2018-11-15 10:33:16 HD Request # 38 | Timestamp of first Intraday data file record written: 2018-11-15 10:33:04 | 2018-11-15 10:33:16 Socket (3) | Signaling to core to close socket | 2018-11-15 10:33:16 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:33:16 Historical data download thread signaled to stop. | 2018-11-15 10:33:16 HD Request # 38 | Received 18 records from 2018-11-15 10:32:57 to 2018-11-15 10:33:12 (15.0 seconds) and wrote 11 records for XBTZ18-BMEX | 2018-11-15 10:33:16 Added 5 Time and Sales records to Intraday data file for XBTZ18-BMEX after download. | 2018-11-15 10:33:16 HD Request # 38 | Completion time: 1s | 2018-11-15 10:33:16 HD Request # 38 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 37 | 2018-11-15 10:33:16 Removed historical data download ID 37 | 2018-11-15 10:33:16 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:33:16 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:33:16 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:33:16 Socket (3) | Closed. | 2018-11-15 10:33:16 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:33:18 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:33:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:34:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:34:53 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:35:15 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:35:15 Connection to the external service has been lost. | 2018-11-15 10:35:15 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:35:15 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:35:15 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:35:15 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:35:15 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:35:15 HTTPS www.bitmex.com:443 (4) | Signaling to core to close socket | 2018-11-15 10:35:15 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:35:15 HTTPS www.bitmex.com:443 (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:35:15 HTTPS www.bitmex.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 10:35:15 HTTPS www.bitmex.com:443 (4) | Closed. | 2018-11-15 10:35:15 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:35:15 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:35:16 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:16 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:35:16 BitMEX WebSocket socket (1) | Still waiting for graceful close or receive error. | 2018-11-15 10:35:16 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:35:16 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:35:16 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:35:18 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:35:18 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:35:18 BitMEX WebSocket socket (1) | Connecting to IP: 54.76.59.84. | 2018-11-15 10:35:18 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:35:18 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:35:18 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:35:18 GMT | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=pmWIroQtf+urvqsHpM4IDXjH2oHPuOxGMDnFDzhpxw8jV9RNkmJpBwUu5wq2utGDP79yBMvlxf7bCNetaUIXk4D0bMpIYsQAbwK+IAitRJep344J87DMjNo753UX; Expires=Wed, 21 Nov 2018 23:35:18 GMT; Path=/ | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: e3epfj+GLw3j9+Px1JYe4ROJBt0= | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:35:19 BitMEX WebSocket | Header line. | 2018-11-15 10:35:19 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:35:19 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:35:19 DTC Client socket (2) | 60 bytes remaining in receive buffer when socket closed. | 2018-11-15 10:35:19 DTC Client socket (2) | Signaling to core to close socket | 2018-11-15 10:35:19 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 1 | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 1 | 2018-11-15 10:35:19 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:35:19 Delaying start of download for ETHUSD-BITFINEX | 2018-11-15 10:35:19 DTC Client socket (4) | Creating socket. | 2018-11-15 10:35:19 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 2 | 2018-11-15 10:35:19 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 3 | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 3 | 2018-11-15 10:35:19 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:35:19 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:35:20 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:35:20 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:35:20 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:35:20 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:35:20 DTC Client socket (2) | Closed. | 2018-11-15 10:35:20 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:35:20 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:35:22 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:35:22 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:35:22 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:35:22 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:35:22 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:35:23 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:35:23 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:35:23 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:35:23 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:35:23 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:35:24 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:35:24 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.76.59.84. | 2018-11-15 10:35:24 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:35:25 HD Request # 39 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:35:27 HD Request # 39 | Download start date-time: 2018-11-15 10:35:18.000 | 2018-11-15 10:35:27 HD Request # 39 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:35:27 Socket (3) | Creating socket. | 2018-11-15 10:35:27 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:35:27 HD Request # 39 | Setting DTC encoding to Binary VLS | 2018-11-15 10:35:28 HD Request # 39 | Sending historical data logon request message. | 2018-11-15 10:35:28 HD Request # 39 | Requesting Intraday data. Start date-time: 2018-11-15 10:35:18. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:35:28 HD Request # 39 | Decompressing data. | 2018-11-15 10:35:29 HD Request # 39 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:35:18 | 2018-11-15 10:35:29 HD Request # 39 | Timestamp of first Intraday data file record written: 2018-11-15 10:35:19 | 2018-11-15 10:35:29 Socket (3) | Signaling to core to close socket | 2018-11-15 10:35:29 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:29 Historical data download thread signaled to stop. | 2018-11-15 10:35:29 HD Request # 39 | Received 6 records from 2018-11-15 10:35:18 to 2018-11-15 10:35:22 (4.0 seconds) and wrote 5 records for ETHUSD-BITFINEX | 2018-11-15 10:35:29 HD Request # 39 | Completion time: 0s | 2018-11-15 10:35:29 HD Request # 39 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 38 | 2018-11-15 10:35:29 Removed historical data download ID 38 | 2018-11-15 10:35:29 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:35:29 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:35:29 HD Request # 40 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:35:29 HD Request # 40 | Download start date-time: 2018-11-15 10:35:17.000 | 2018-11-15 10:35:29 HD Request # 40 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:35:29 Socket (5) | Creating socket. | 2018-11-15 10:35:29 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:35:29 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:35:29 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:35:29 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:35:29 Socket (3) | Closed. | 2018-11-15 10:35:29 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:35:29 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:35:29 HD Request # 40 | Setting DTC encoding to Binary VLS | 2018-11-15 10:35:29 HD Request # 40 | Sending historical data logon request message. | 2018-11-15 10:35:29 HD Request # 40 | Requesting Intraday data. Start date-time: 2018-11-15 10:35:17. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:35:30 HD Request # 40 | Decompressing data. | 2018-11-15 10:35:30 HD Request # 40 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:35:17 | 2018-11-15 10:35:30 HD Request # 40 | Timestamp of first Intraday data file record written: 2018-11-15 10:35:18 | 2018-11-15 10:35:30 Socket (5) | Signaling to core to close socket | 2018-11-15 10:35:30 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:30 Historical data download thread signaled to stop. | 2018-11-15 10:35:30 HD Request # 40 | Received 40 records from 2018-11-15 10:35:17 to 2018-11-15 10:35:25 (8.0 seconds) and wrote 36 records for XBTUSD-BMEX | 2018-11-15 10:35:30 Added 2 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:35:30 HD Request # 40 | Completion time: 1s | 2018-11-15 10:35:30 HD Request # 40 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 39 | 2018-11-15 10:35:30 Removed historical data download ID 39 | 2018-11-15 10:35:30 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:35:30 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:35:30 HD Request # 41 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:35:30 HD Request # 41 | Download start date-time: 2018-11-15 10:35:17.000 | 2018-11-15 10:35:30 HD Request # 41 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:35:30 Socket (3) | Creating socket. | 2018-11-15 10:35:30 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:35:30 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:35:30 Socket (5) | Closed. | 2018-11-15 10:35:30 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:35:30 HD Request # 41 | Setting DTC encoding to Binary VLS | 2018-11-15 10:35:31 HD Request # 41 | Sending historical data logon request message. | 2018-11-15 10:35:31 HD Request # 41 | Requesting Intraday data. Start date-time: 2018-11-15 10:35:17. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:35:31 HD Request # 41 | Decompressing data. | 2018-11-15 10:35:31 HD Request # 41 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:35:17 | 2018-11-15 10:35:31 HD Request # 41 | Timestamp of first Intraday data file record written: 2018-11-15 10:35:18 | 2018-11-15 10:35:31 Socket (3) | Signaling to core to close socket | 2018-11-15 10:35:31 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:31 Historical data download thread signaled to stop. | 2018-11-15 10:35:31 HD Request # 41 | Received 30 records from 2018-11-15 10:35:17 to 2018-11-15 10:35:29 (12.0 seconds) and wrote 24 records for ETHUSD-BMEX | 2018-11-15 10:35:31 HD Request # 41 | Completion time: 2s | 2018-11-15 10:35:31 HD Request # 41 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 40 | 2018-11-15 10:35:31 Removed historical data download ID 40 | 2018-11-15 10:35:31 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:35:31 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:35:31 HD Request # 42 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:35:31 HD Request # 42 | Download start date-time: 2018-11-15 10:35:18.000 | 2018-11-15 10:35:31 HD Request # 42 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:35:31 Socket (5) | Creating socket. | 2018-11-15 10:35:31 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:35:31 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:35:31 Socket (3) | Closed. | 2018-11-15 10:35:31 HD Request # 42 | Setting DTC encoding to Binary VLS | 2018-11-15 10:35:32 HD Request # 42 | Sending historical data logon request message. | 2018-11-15 10:35:32 HD Request # 42 | Requesting Intraday data. Start date-time: 2018-11-15 10:35:18. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:35:32 HD Request # 42 | Decompressing data. | 2018-11-15 10:35:32 HD Request # 42 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:35:18 | 2018-11-15 10:35:32 HD Request # 42 | Timestamp of first Intraday data file record written: 2018-11-15 10:35:19 | 2018-11-15 10:35:32 Socket (5) | Signaling to core to close socket | 2018-11-15 10:35:32 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:32 Historical data download thread signaled to stop. | 2018-11-15 10:35:32 HD Request # 42 | Received 13 records from 2018-11-15 10:35:18 to 2018-11-15 10:35:26 (8.0 seconds) and wrote 12 records for BTCUSD-BITFINEX | 2018-11-15 10:35:32 HD Request # 42 | Completion time: 1s | 2018-11-15 10:35:32 HD Request # 42 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 41 | 2018-11-15 10:35:32 Removed historical data download ID 41 | 2018-11-15 10:35:32 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:35:32 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:35:32 HD Request # 43 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:35:32 HD Request # 43 | Download start date-time: 2018-11-15 10:35:12.000 | 2018-11-15 10:35:32 HD Request # 43 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:35:32 Socket (3) | Creating socket. | 2018-11-15 10:35:32 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:35:32 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:35:33 Socket (5) | Closed. | 2018-11-15 10:35:33 HD Request # 43 | Setting DTC encoding to Binary VLS | 2018-11-15 10:35:33 HD Request # 43 | Sending historical data logon request message. | 2018-11-15 10:35:33 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:35:33 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:35:33 HD Request # 43 | Requesting Intraday data. Start date-time: 2018-11-15 10:35:12. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:35:33 HD Request # 43 | Decompressing data. | 2018-11-15 10:35:34 HD Request # 43 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:35:12 | 2018-11-15 10:35:34 HD Request # 43 | Timestamp of first Intraday data file record written: 2018-11-15 10:35:20 | 2018-11-15 10:35:34 Socket (3) | Signaling to core to close socket | 2018-11-15 10:35:34 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:35:34 Historical data download thread signaled to stop. | 2018-11-15 10:35:34 HD Request # 43 | Received 7 records from 2018-11-15 10:35:12 to 2018-11-15 10:35:28 (16.0 seconds) and wrote 2 records for XBTZ18-BMEX | 2018-11-15 10:35:34 HD Request # 43 | Completion time: 1s | 2018-11-15 10:35:34 HD Request # 43 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 42 | 2018-11-15 10:35:34 Removed historical data download ID 42 | 2018-11-15 10:35:34 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:35:34 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:35:34 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:35:34 Socket (3) | Closed. | 2018-11-15 10:35:34 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:35:42 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:45 * Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:35:45 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:35:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:36:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:37:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:37:12 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:37:33 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:37:33 Connection to the external service has been lost. | 2018-11-15 10:37:33 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:37:33 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:37:33 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:37:33 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:37:33 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:37:33 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:37:33 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:37:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:37:33 HTTPS www.bitmex.com:443 (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:33 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:37:34 HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:37:34 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 10:37:34 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:37:34 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:34 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:37:34 BitMEX WebSocket socket (1) | Still waiting for graceful close or receive error. | 2018-11-15 10:37:34 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:37:34 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:37:34 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:37:36 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:37:36 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:37:37 BitMEX WebSocket socket (1) | Connecting to IP: 54.76.59.84. | 2018-11-15 10:37:37 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:37:37 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:37:37 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:37:37 GMT | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=ja9TmT9CNwFDvocNB/6kbyBdEFEAv/oG98utPdFyoaAqus04+DkmQW0YK16i2H888ePlhYj7ZA0phjkUq2o0hogo0BKElFwaF+j6JAGyYdb7/p/iGnBQTIvEVnre; Expires=Wed, 21 Nov 2018 23:37:37 GMT; Path=/ | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: 4XWW67+CHSTkLRi/6dmgGAxI3sU= | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:37:38 BitMEX WebSocket | Header line. | 2018-11-15 10:37:38 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:37:38 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:37:38 DTC Client socket (4) | Signaling to core to close socket | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:37:38 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:37:38 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:37:38 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:37:38 DTC Client socket (2) | Creating socket. | 2018-11-15 10:37:38 DTC Client socket (2) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:37:38 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 10:37:38 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 3 | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 3 | 2018-11-15 10:37:38 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 4 | 2018-11-15 10:37:38 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:37:38 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:37:38 DTC Client socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:37:38 DTC Client socket (4) | Closed. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 5 | 2018-11-15 10:37:38 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:37:38 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:37:39 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:37:40 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:37:40 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:37:40 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:37:40 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:37:41 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:37:41 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:37:41 HTTPS www.bitmex.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-11-15 10:37:43 HTTPS www.bitmex.com:443 (3) | Connecting to IP: 54.76.59.84. | 2018-11-15 10:37:43 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:37:43 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:37:43 HD Request # 44 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:37:45 HD Request # 44 | Download start date-time: 2018-11-15 10:37:35.000 | 2018-11-15 10:37:45 HD Request # 44 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:37:45 Socket (4) | Creating socket. | 2018-11-15 10:37:45 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:37:45 HD Request # 44 | Setting DTC encoding to Binary VLS | 2018-11-15 10:37:46 HD Request # 44 | Sending historical data logon request message. | 2018-11-15 10:37:46 HD Request # 44 | Requesting Intraday data. Start date-time: 2018-11-15 10:37:35. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:37:46 HD Request # 44 | Decompressing data. | 2018-11-15 10:37:47 HD Request # 44 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:37:35 | 2018-11-15 10:37:47 HD Request # 44 | Timestamp of first Intraday data file record written: 2018-11-15 10:37:36 | 2018-11-15 10:37:47 Socket (4) | Signaling to core to close socket | 2018-11-15 10:37:47 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:47 Historical data download thread signaled to stop. | 2018-11-15 10:37:47 HD Request # 44 | Received 215 records from 2018-11-15 10:37:35 to 2018-11-15 10:37:42 (7.1 seconds) and wrote 211 records for XBTUSD-BMEX | 2018-11-15 10:37:47 Added 148 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:37:47 HD Request # 44 | Completion time: 0s | 2018-11-15 10:37:47 HD Request # 44 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 43 | 2018-11-15 10:37:47 Removed historical data download ID 43 | 2018-11-15 10:37:47 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:37:47 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:37:47 HD Request # 45 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:37:47 HD Request # 45 | Download start date-time: 2018-11-15 10:37:34.000 | 2018-11-15 10:37:47 HD Request # 45 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:37:47 Socket (5) | Creating socket. | 2018-11-15 10:37:47 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:37:47 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:37:47 Socket (4) | Closed. | 2018-11-15 10:37:47 HD Request # 45 | Setting DTC encoding to Binary VLS | 2018-11-15 10:37:47 HD Request # 45 | Sending historical data logon request message. | 2018-11-15 10:37:47 HD Request # 45 | Requesting Intraday data. Start date-time: 2018-11-15 10:37:34. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:37:48 HD Request # 45 | Decompressing data. | 2018-11-15 10:37:48 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:37:48 HD Request # 45 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 09:37:33 | 2018-11-15 10:37:49 Socket (5) | Signaling to core to close socket | 2018-11-15 10:37:49 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:49 Historical data download thread signaled to stop. | 2018-11-15 10:37:49 HD Request # 45 | Received 4728 records from 2018-11-15 09:37:33 to 2018-11-15 10:37:33 (60.0 minutes) and wrote 0 records for ETHUSD-BITFINEX | 2018-11-15 10:37:49 HD Request # 45 | Timestamp of first Intraday data file record written: 2018-11-15 10:37:43 | 2018-11-15 10:37:49 Added 26 Time and Sales records to Intraday data file for ETHUSD-BITFINEX after download. | 2018-11-15 10:37:49 HD Request # 45 | Completion time: 2s | 2018-11-15 10:37:49 HD Request # 45 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 44 | 2018-11-15 10:37:49 Removed historical data download ID 44 | 2018-11-15 10:37:49 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:37:49 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:37:49 HD Request # 46 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:37:49 HD Request # 46 | Download start date-time: 2018-11-15 10:37:30.000 | 2018-11-15 10:37:49 HD Request # 46 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:37:49 Socket (4) | Creating socket. | 2018-11-15 10:37:49 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:37:49 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:37:49 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:37:49 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:37:49 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:37:49 Socket (5) | Closed. | 2018-11-15 10:37:49 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:37:49 HD Request # 46 | Setting DTC encoding to Binary VLS | 2018-11-15 10:37:49 HD Request # 46 | Sending historical data logon request message. | 2018-11-15 10:37:49 HD Request # 46 | Requesting Intraday data. Start date-time: 2018-11-15 10:37:30. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:37:50 HD Request # 46 | Decompressing data. | 2018-11-15 10:37:50 HD Request # 46 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:37:30 | 2018-11-15 10:37:50 HD Request # 46 | Timestamp of first Intraday data file record written: 2018-11-15 10:37:38 | 2018-11-15 10:37:50 Socket (4) | Signaling to core to close socket | 2018-11-15 10:37:50 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:50 Historical data download thread signaled to stop. | 2018-11-15 10:37:50 HD Request # 46 | Received 47 records from 2018-11-15 10:37:30 to 2018-11-15 10:37:45 (15.0 seconds) and wrote 43 records for ETHUSD-BMEX | 2018-11-15 10:37:50 HD Request # 46 | Completion time: 2s | 2018-11-15 10:37:50 HD Request # 46 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 45 | 2018-11-15 10:37:50 Removed historical data download ID 45 | 2018-11-15 10:37:50 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:37:50 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:37:50 HD Request # 47 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:37:50 HD Request # 47 | Download start date-time: 2018-11-15 10:37:30.000 | 2018-11-15 10:37:50 HD Request # 47 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:37:50 Socket (5) | Creating socket. | 2018-11-15 10:37:50 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:37:50 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:37:50 Socket (4) | Closed. | 2018-11-15 10:37:50 HD Request # 47 | Setting DTC encoding to Binary VLS | 2018-11-15 10:37:51 HD Request # 47 | Sending historical data logon request message. | 2018-11-15 10:37:51 HD Request # 47 | Requesting Intraday data. Start date-time: 2018-11-15 10:37:30. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:37:51 HD Request # 47 | Decompressing data. | 2018-11-15 10:37:51 HD Request # 47 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:37:30 | 2018-11-15 10:37:51 Socket (5) | Signaling to core to close socket | 2018-11-15 10:37:51 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:51 Historical data download thread signaled to stop. | 2018-11-15 10:37:51 HD Request # 47 | Received 1 record from 2018-11-15 10:37:30 to 2018-11-15 10:37:30 (0.0 seconds) and wrote 0 records for BTCUSD-BITFINEX | 2018-11-15 10:37:51 HD Request # 47 | Completion time: 1s | 2018-11-15 10:37:51 HD Request # 47 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 46 | 2018-11-15 10:37:51 Removed historical data download ID 46 | 2018-11-15 10:37:51 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:37:51 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:37:51 HD Request # 48 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:37:51 HD Request # 48 | Download start date-time: 2018-11-15 10:37:33.000 | 2018-11-15 10:37:51 HD Request # 48 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:37:51 Socket (4) | Creating socket. | 2018-11-15 10:37:51 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:37:51 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:37:51 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:37:51 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:37:51 Socket (5) | Closed. | 2018-11-15 10:37:51 HD Request # 48 | Setting DTC encoding to Binary VLS | 2018-11-15 10:37:52 HD Request # 48 | Sending historical data logon request message. | 2018-11-15 10:37:52 HD Request # 48 | Requesting Intraday data. Start date-time: 2018-11-15 10:37:33. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:37:52 HD Request # 48 | Decompressing data. | 2018-11-15 10:37:53 HD Request # 48 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:37:33 | 2018-11-15 10:37:53 HD Request # 48 | Timestamp of first Intraday data file record written: 2018-11-15 10:37:36 | 2018-11-15 10:37:53 Socket (4) | Signaling to core to close socket | 2018-11-15 10:37:53 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:37:53 Historical data download thread signaled to stop. | 2018-11-15 10:37:53 HD Request # 48 | Received 53 records from 2018-11-15 10:37:33 to 2018-11-15 10:37:47 (14.0 seconds) and wrote 50 records for XBTZ18-BMEX | 2018-11-15 10:37:53 Added 10 Time and Sales records to Intraday data file for XBTZ18-BMEX after download. | 2018-11-15 10:37:53 HD Request # 48 | Completion time: 0s | 2018-11-15 10:37:53 HD Request # 48 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 47 | 2018-11-15 10:37:53 Removed historical data download ID 47 | 2018-11-15 10:37:53 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:37:53 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:37:53 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:37:53 Socket (4) | Closed. | 2018-11-15 10:37:53 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:37:54 Opened cached Intraday file: C:\SierraChart\Data\XBTZ18-BMEX.scid | 2018-11-15 10:37:54 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:38:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:39:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:39:31 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:39:55 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:39:55 Connection to the external service has been lost. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:39:55 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:39:55 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:39:55 HTTPS www.bitmex.com:443 (3) | Signaling to core to close socket | 2018-11-15 10:39:55 HTTPS www.bitmex.com:443 (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:39:55 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:39:55 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:39:55 HTTPS www.bitmex.com:443 (3) | Socket gracefully closed by remote side. | 2018-11-15 10:39:55 HTTPS www.bitmex.com:443 (3) | Closed. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Still waiting for graceful close or receive error. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:39:55 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:39:55 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:39:58 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:39:58 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:39:58 BitMEX WebSocket socket (1) | Connecting to IP: 54.76.31.170. | 2018-11-15 10:39:58 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:39:58 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:39:58 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:39:58 GMT | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=v+MXbtaSDOXg4d07uMU5WVFtrYpAn8+wUbUGv9DP4uMkYBmdB5biV8En/MAaqF6fjK2vuzdk1AYaPVkE1LKOfYyXO+h8PoLmrf+SDIFM2+nwPW5zyu5i0bufAxym; Expires=Wed, 21 Nov 2018 23:39:58 GMT; Path=/ | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: hkSxGHIsTeByDaEQu+nZgtF6i/k= | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:39:59 BitMEX WebSocket | Header line. | 2018-11-15 10:39:59 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:39:59 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:39:59 DTC Client socket (2) | Signaling to core to close socket | 2018-11-15 10:39:59 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 1 | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 1 | 2018-11-15 10:39:59 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:39:59 DTC Client socket (3) | Creating socket. | 2018-11-15 10:39:59 DTC Client socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:39:59 Delaying start of download for BTCUSD-BITFINEX | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BMEX. ID: 2 | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BMEX. ID: 2 | 2018-11-15 10:39:59 Intraday data recording state for symbol ETHUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 3 | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 3 | 2018-11-15 10:39:59 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:39:59 Requesting market depth updates for: ETHUSD-BMEX if supported. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTZ18-BMEX. ID: 4 | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Requesting security definition data for: XBTZ18-BMEX. ID: 4 | 2018-11-15 10:39:59 Intraday data recording state for symbol XBTZ18-BMEX is set to download 'Pending'. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 5 | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 5 | 2018-11-15 10:39:59 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:39:59 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:39:59 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:39:59 DTC Client socket (2) | Closed. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:39:59 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BMEX | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTZ18-BMEX | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:40:00 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:40:01 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BMEX | 2018-11-15 10:40:01 SC DTC Data with Market Depth | Clearing market depth for ETHUSD-BMEX. | 2018-11-15 10:40:02 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\ETHUSD-BMEX.2018-11-14.depth | 2018-11-15 10:40:02 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:40:02 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:40:02 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:40:03 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTZ18-BMEX.2018-11-14.depth | 2018-11-15 10:40:03 SC DTC Data with Market Depth | Received security definition for symbol XBTZ18-BMEX | 2018-11-15 10:40:03 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:40:04 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.76.31.170. | 2018-11-15 10:40:04 Requesting market depth updates for: XBTZ18-BMEX if supported. | 2018-11-15 10:40:04 SC DTC Data with Market Depth | Clearing market depth for XBTZ18-BMEX. | 2018-11-15 10:40:04 HD Request # 49 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:40:05 HD Request # 49 | Download start date-time: 2018-11-15 10:39:56.000 | 2018-11-15 10:40:05 HD Request # 49 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:40:05 Socket (4) | Creating socket. | 2018-11-15 10:40:05 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:40:05 HD Request # 49 | Setting DTC encoding to Binary VLS | 2018-11-15 10:40:06 HD Request # 49 | Sending historical data logon request message. | 2018-11-15 10:40:06 HD Request # 49 | Requesting Intraday data. Start date-time: 2018-11-15 10:39:56. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:40:06 HD Request # 49 | Decompressing data. | 2018-11-15 10:40:07 HD Request # 49 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:39:56 | 2018-11-15 10:40:07 HD Request # 49 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:00 | 2018-11-15 10:40:07 Socket (4) | Signaling to core to close socket | 2018-11-15 10:40:07 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:40:07 Historical data download thread signaled to stop. | 2018-11-15 10:40:07 HD Request # 49 | Received 5 records from 2018-11-15 10:39:56 to 2018-11-15 10:40:02 (6.0 seconds) and wrote 4 records for BTCUSD-BITFINEX | 2018-11-15 10:40:07 Added 2 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:40:07 HD Request # 49 | Completion time: 2s | 2018-11-15 10:40:07 HD Request # 49 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 48 | 2018-11-15 10:40:07 Removed historical data download ID 48 | 2018-11-15 10:40:07 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:40:07 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:40:07 HD Request # 50 | Downloading Intraday chart data for ETHUSD-BMEX to the file ETHUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:40:07 HD Request # 50 | Download start date-time: 2018-11-15 10:39:57.000 | 2018-11-15 10:40:07 HD Request # 50 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:40:07 Socket (6) | Creating socket. | 2018-11-15 10:40:07 Socket (6) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:40:07 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:40:07 Socket (4) | Closed. | 2018-11-15 10:40:07 HD Request # 50 | Setting DTC encoding to Binary VLS | 2018-11-15 10:40:08 HD Request # 50 | Sending historical data logon request message. | 2018-11-15 10:40:08 HD Request # 50 | Requesting Intraday data. Start date-time: 2018-11-15 10:39:57. Record interval: 0. Symbol: ETHUSD-BMEX | 2018-11-15 10:40:08 HD Request # 50 | Decompressing data. | 2018-11-15 10:40:08 HD Request # 50 | Receiving Intraday data for ETHUSD-BMEX starting at 2018-11-15 10:39:57 | 2018-11-15 10:40:08 HD Request # 50 | Timestamp of first Intraday data file record written: 2018-11-15 10:39:58 | 2018-11-15 10:40:08 Socket (6) | Signaling to core to close socket | 2018-11-15 10:40:08 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:40:08 Historical data download thread signaled to stop. | 2018-11-15 10:40:08 HD Request # 50 | Received 6 records from 2018-11-15 10:39:57 to 2018-11-15 10:40:05 (8.0 seconds) and wrote 5 records for ETHUSD-BMEX | 2018-11-15 10:40:08 HD Request # 50 | Completion time: 1s | 2018-11-15 10:40:08 HD Request # 50 | Intraday data download complete for ETHUSD-BMEX. Unique request ID: 49 | 2018-11-15 10:40:08 Removed historical data download ID 49 | 2018-11-15 10:40:08 Real-time Intraday chart data file updates started for ETHUSD-BMEX | 2018-11-15 10:40:08 Intraday chart data file opened for ETHUSD-BMEX | 2018-11-15 10:40:08 HD Request # 51 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:40:08 HD Request # 51 | Download start date-time: 2018-11-15 10:39:58.000 | 2018-11-15 10:40:08 HD Request # 51 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:40:08 Socket (4) | Creating socket. | 2018-11-15 10:40:08 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:40:08 Socket (6) | Socket gracefully closed by remote side. | 2018-11-15 10:40:09 Socket (6) | Closed. | 2018-11-15 10:40:09 HD Request # 51 | Setting DTC encoding to Binary VLS | 2018-11-15 10:40:09 HD Request # 51 | Sending historical data logon request message. | 2018-11-15 10:40:09 HD Request # 51 | Requesting Intraday data. Start date-time: 2018-11-15 10:39:58. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:40:09 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:40:09 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BMEX.scid | 2018-11-15 10:40:09 HD Request # 51 | Decompressing data. | 2018-11-15 10:40:10 HD Request # 51 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:39:58 | 2018-11-15 10:40:10 HD Request # 51 | Timestamp of first Intraday data file record written: 2018-11-15 10:39:58 | 2018-11-15 10:40:10 Socket (4) | Signaling to core to close socket | 2018-11-15 10:40:10 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:40:10 Historical data download thread signaled to stop. | 2018-11-15 10:40:10 HD Request # 51 | Received 88 records from 2018-11-15 10:39:58 to 2018-11-15 10:40:05 (7.1 seconds) and wrote 87 records for XBTUSD-BMEX | 2018-11-15 10:40:10 Added 4 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:40:10 HD Request # 51 | Completion time: 1s | 2018-11-15 10:40:10 HD Request # 51 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 50 | 2018-11-15 10:40:10 Removed historical data download ID 50 | 2018-11-15 10:40:10 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:40:10 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:40:10 HD Request # 52 | Downloading Intraday chart data for XBTZ18-BMEX to the file XBTZ18-BMEX.scid. Service: bitmex | 2018-11-15 10:40:10 HD Request # 52 | Download start date-time: 2018-11-15 10:39:54.000 | 2018-11-15 10:40:10 HD Request # 52 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:40:10 Socket (6) | Creating socket. | 2018-11-15 10:40:10 Socket (6) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:40:10 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:40:10 Socket (4) | Closed. | 2018-11-15 10:40:10 HD Request # 52 | Setting DTC encoding to Binary VLS | 2018-11-15 10:40:10 HD Request # 52 | Sending historical data logon request message. | 2018-11-15 10:40:10 HD Request # 52 | Requesting Intraday data. Start date-time: 2018-11-15 10:39:54. Record interval: 0. Symbol: XBTZ18-BMEX | 2018-11-15 10:40:11 HD Request # 52 | Decompressing data. | 2018-11-15 10:40:11 HD Request # 52 | Receiving Intraday data for XBTZ18-BMEX starting at 2018-11-15 10:39:54 | 2018-11-15 10:40:11 Socket (6) | Signaling to core to close socket | 2018-11-15 10:40:11 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:40:11 Historical data download thread signaled to stop. | 2018-11-15 10:40:11 HD Request # 52 | Received 1 record from 2018-11-15 10:39:54 to 2018-11-15 10:39:54 (0.0 seconds) and wrote 0 records for XBTZ18-BMEX | 2018-11-15 10:40:11 HD Request # 52 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:07 | 2018-11-15 10:40:11 Added 3 Time and Sales records to Intraday data file for XBTZ18-BMEX after download. | 2018-11-15 10:40:11 HD Request # 52 | Completion time: 2s | 2018-11-15 10:40:11 HD Request # 52 | Intraday data download complete for XBTZ18-BMEX. Unique request ID: 51 | 2018-11-15 10:40:11 Removed historical data download ID 51 | 2018-11-15 10:40:11 Real-time Intraday chart data file updates started for XBTZ18-BMEX | 2018-11-15 10:40:11 Intraday chart data file opened for XBTZ18-BMEX | 2018-11-15 10:40:11 HD Request # 53 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:40:11 HD Request # 53 | Download start date-time: 2018-11-15 10:39:45.000 | 2018-11-15 10:40:11 HD Request # 53 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:40:11 Socket (4) | Creating socket. | 2018-11-15 10:40:11 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:40:11 Socket (6) | Socket gracefully closed by remote side. | 2018-11-15 10:40:11 Socket (6) | Closed. | 2018-11-15 10:40:11 HD Request # 53 | Setting DTC encoding to Binary VLS | 2018-11-15 10:40:12 HD Request # 53 | Sending historical data logon request message. | 2018-11-15 10:40:12 HD Request # 53 | Requesting Intraday data. Start date-time: 2018-11-15 10:39:45. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:40:12 HD Request # 53 | Decompressing data. | 2018-11-15 10:40:12 HD Request # 53 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:39:45 | 2018-11-15 10:40:12 Socket (4) | Signaling to core to close socket | 2018-11-15 10:40:12 Historical data download thread signaled to stop. | 2018-11-15 10:40:12 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:40:12 HD Request # 53 | Received 1 record from 2018-11-15 10:39:45 to 2018-11-15 10:39:45 (0.0 seconds) and wrote 0 records for ETHUSD-BITFINEX | 2018-11-15 10:40:12 HD Request # 53 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:10 | 2018-11-15 10:40:12 Added 5 Time and Sales records to Intraday data file for ETHUSD-BITFINEX after download. | 2018-11-15 10:40:12 HD Request # 53 | Completion time: 0s | 2018-11-15 10:40:12 HD Request # 53 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 52 | 2018-11-15 10:40:12 Removed historical data download ID 52 | 2018-11-15 10:40:12 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:40:12 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:40:12 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:40:12 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:40:12 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:40:12 Socket (4) | Closed. | 2018-11-15 10:40:12 ETHUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex ETH.Cht | 2018-11-15 10:40:12 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:40:12 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:40:13 Program is exiting. | 2018-11-15 10:40:23 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:40:23 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:40:23 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:40:23 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:40:23 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:40:23 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:40:23 BitMEX Trading Direct | HTTP response not complete. Request was canceled. | 2018-11-15 10:40:23 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:40:23 HTTPS www.bitmex.com:443 (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:40:23 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:40:23 DTC Client socket (3) | 564 bytes remaining in receive buffer when socket closed. | 2018-11-15 10:40:23 DTC Client socket (3) | Signaling to core to close socket | 2018-11-15 10:40:23 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:40:23 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:40:23 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:40:23 This is the last line for the message log because it is being deleted in ExitInstance. | 2018-11-15 10:40:23 |
[2018-11-15 08:18:40] |
Andrew Ton - Posts: 28 |
Additional message log from 10AM onwards Reading Internal Order ID file. | 2018-11-15 10:41:06 Reading Trade Orders file. | 2018-11-15 10:41:06 Reading Trade Positions and Account Balance file. | 2018-11-15 10:41:06 Listening on UDP port 22904. | 2018-11-15 10:41:06 Software version: 1815 64-bit | 2018-11-15 10:41:06 Usage end date: 2018-11-24 | 2018-11-15 10:41:06 Enabled for: Advanced Features. | 2018-11-15 10:41:06 Enabled for: Advanced Features 2. | 2018-11-15 10:41:06 Enabled for: Sierra Chart Historical Data Service. | 2018-11-15 10:41:06 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-11-15 10:41:06 Current selected Data/Trading service: BitMEX Trading Direct | 2018-11-15 10:41:06 Chart Update Interval: 500 | 2018-11-15 10:41:06 Time Zone: +11:00:00 (AEST+10AEDT+01,M10.1.0/02:00,M4.1.0/03:00) | 2018-11-15 10:41:06 2018-11-15 10:41:06 Local computer time | 2018-11-15 10:41:06 2018-11-14 23:41:06 Local computer time in UTC | 2018-11-15 10:41:06 2018-11-15 10:41:06 Local computer time in SC Time Zone | 2018-11-15 10:41:06 2018-11-14 23:41:03 Server time in UTC | 2018-11-15 10:41:06 Local computer UTC time and Server UTC time difference: 2 seconds. | 2018-11-15 10:41:06 Program path: C:\SierraChart\ | 2018-11-15 10:41:06 Data Files path: C:\SierraChart\Data\ | 2018-11-15 10:41:06 OS Version Number: 10.0 | 2018-11-15 10:41:06 Locale Setting: C | 2018-11-15 10:41:06 Checking for new symbol settings for service code bitmex.exchange.trading | 2018-11-15 10:41:06 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:06 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-11-15 10:41:06 Received 5 login tokens. | 2018-11-15 10:41:08 Symbol settings are up-to-date for bitmex.exchange.trading | 2018-11-15 10:41:08 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:08 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-11-15 10:41:08 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-11-15 10:41:09 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-11-15 10:41:13 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:41:13 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:41:13 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:13 BitMEX WebSocket socket (1) | Connecting to IP: 54.77.38.28. | 2018-11-15 10:41:13 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:41:13 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:41:13 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:41:13 GMT | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=RrPQNwFLTTaThWg0BNWj3J+HNVSJEHX29PRR3LI2C7NIay8TNU5hDVPp5q5qReG0UGTAjgvnwHybIGF1yYU9BtHPEiEnQQjCR7B3FBwiW43T4Q2AbsujWY4+4Vf0; Expires=Wed, 21 Nov 2018 23:41:13 GMT; Path=/ | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: 2ulMmDdAaC9jaLDNM6vNv9Ext+c= | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. | 2018-11-15 10:41:14 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:41:14 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:41:14 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-11-15 10:41:15 XBTUSD-BMEX 1 Min #2 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 15 Min #4 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 10 Sec #1 | Reloading chart. | 2018-11-15 10:41:15 ETHUSD-BITFINEX 1 Min #5 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 1 Min #6 | Reloading chart. | 2018-11-15 10:41:15 BTCUSD-BITFINEX 1 Min #7 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 5 Min #8 | Reloading chart. | 2018-11-15 10:41:16 BTCUSD-BITFINEX 5 Min #9 | Reloading chart. | 2018-11-15 10:41:16 XBTUSD-BMEX #10 | Reloading chart. | 2018-11-15 10:41:16 + Loading market depth data. | 2018-11-15 10:41:17 Loaded depth data records for XBTUSD-BMEX 2018-10-30 from 2018-10-31 10:40:22 to 2018-10-31 10:59:59. | 2018-11-15 10:41:17 XBTUSD-BMEX 10 Sec #3 | Reloading chart. | 2018-11-15 10:41:17 XBTUSD-BMEX 1 Min #11 | Reloading chart. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2018-11-15 10:41:18 DTC Client socket (2) | Creating socket. | 2018-11-15 10:41:18 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:41:18 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:41:18 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:41:18 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 10:41:18 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:41:18 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:41:18 + Loading market depth data. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:41:19 Loaded depth data records for XBTUSD-BMEX 2018-10-31 from 2018-10-31 11:00:03 to 2018-11-01 10:59:59. | 2018-11-15 10:41:19 HTTPS www.bitmex.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:19 HTTPS www.bitmex.com:443 (3) | Connecting to IP: 54.77.38.28. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:41:20 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:41:20 Loaded depth data records for XBTUSD-BMEX 2018-10-10 from 2018-10-11 00:00:04 to 2018-10-11 10:59:59. | 2018-11-15 10:41:20 Loaded depth data records for XBTUSD-BMEX 2018-11-01 from 2018-11-01 11:00:03 to 2018-11-02 10:59:59. | 2018-11-15 10:41:21 Loaded depth data records for XBTUSD-BMEX 2018-10-11 from 2018-10-11 11:00:04 to 2018-10-12 10:59:58. | 2018-11-15 10:41:23 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:41:23 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:41:23 Loaded depth data records for XBTUSD-BMEX 2018-11-02 from 2018-11-02 11:00:03 to 2018-11-03 10:59:59. | 2018-11-15 10:41:24 HD Request # 2 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:41:24 HD Request # 2 | Download start date-time: 2018-11-15 10:40:22.000 | 2018-11-15 10:41:24 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:41:24 Socket (4) | Creating socket. | 2018-11-15 10:41:24 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:41:24 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:25 HD Request # 2 | Sending historical data logon request message. | 2018-11-15 10:41:25 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-11-15 10:40:22. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:41:25 HD Request # 2 | Decompressing data. | 2018-11-15 10:41:25 HD Request # 2 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:40:22 | 2018-11-15 10:41:25 HD Request # 2 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:22 | 2018-11-15 10:41:25 Socket (4) | Signaling to core to close socket | 2018-11-15 10:41:25 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:41:25 Historical data download thread signaled to stop. | 2018-11-15 10:41:25 HD Request # 2 | Received 606 records from 2018-11-15 10:40:22 to 2018-11-15 10:41:22 (60.0 seconds) and wrote 605 records for XBTUSD-BMEX | 2018-11-15 10:41:25 Added 10 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:41:25 HD Request # 2 | Completion time: 0s | 2018-11-15 10:41:25 HD Request # 2 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 1 | 2018-11-15 10:41:25 Loaded depth data records for XBTUSD-BMEX 2018-11-03 from 2018-11-03 11:00:04 to 2018-11-04 10:59:59. | 2018-11-15 10:41:25 Removed historical data download ID 1 | 2018-11-15 10:41:25 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:41:25 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:41:25 HD Request # 3 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:41:25 HD Request # 3 | Download start date-time: 2018-11-15 10:40:21.000 | 2018-11-15 10:41:25 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:41:25 Socket (5) | Creating socket. | 2018-11-15 10:41:25 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:41:25 Loaded depth data records for XBTUSD-BMEX 2018-10-12 from 2018-10-12 11:00:00 to 2018-10-13 10:59:59. | 2018-11-15 10:41:26 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:41:26 Socket (4) | Closed. | 2018-11-15 10:41:26 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:26 HD Request # 3 | Sending historical data logon request message. | 2018-11-15 10:41:26 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-11-15 10:40:21. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:41:26 HD Request # 3 | Decompressing data. | 2018-11-15 10:41:27 HD Request # 3 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:40:21 | 2018-11-15 10:41:27 HD Request # 3 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:23 | 2018-11-15 10:41:27 Socket (5) | Signaling to core to close socket | 2018-11-15 10:41:27 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:41:27 Historical data download thread signaled to stop. | 2018-11-15 10:41:27 HD Request # 3 | Received 66 records from 2018-11-15 10:40:21 to 2018-11-15 10:41:23 (62.0 seconds) and wrote 58 records for ETHUSD-BITFINEX | 2018-11-15 10:41:27 Added 2 Time and Sales records to Intraday data file for ETHUSD-BITFINEX after download. | 2018-11-15 10:41:27 HD Request # 3 | Completion time: 0s | 2018-11-15 10:41:27 HD Request # 3 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 2 | 2018-11-15 10:41:27 Removed historical data download ID 2 | 2018-11-15 10:41:27 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:41:27 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:41:27 HD Request # 4 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:41:27 HD Request # 4 | Download start date-time: 2018-11-15 10:40:11.000 | 2018-11-15 10:41:27 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:41:27 Socket (4) | Creating socket. | 2018-11-15 10:41:27 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:41:27 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:41:27 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:41:27 Socket (5) | Closed. | 2018-11-15 10:41:27 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:41:27 Loaded depth data records for XBTUSD-BMEX 2018-11-04 from 2018-11-04 11:00:02 to 2018-11-05 10:59:59. | 2018-11-15 10:41:27 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:27 HD Request # 4 | Sending historical data logon request message. | 2018-11-15 10:41:27 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:41:27 Loaded depth data records for XBTUSD-BMEX 2018-10-13 from 2018-10-13 11:00:03 to 2018-10-14 10:59:59. | 2018-11-15 10:41:28 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-11-15 10:40:11. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:41:28 HD Request # 4 | Decompressing data. | 2018-11-15 10:41:28 HD Request # 4 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:40:11 | 2018-11-15 10:41:28 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:27 | 2018-11-15 10:41:28 Socket (4) | Signaling to core to close socket | 2018-11-15 10:41:28 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:41:28 Historical data download thread signaled to stop. | 2018-11-15 10:41:28 HD Request # 4 | Received 60 records from 2018-11-15 10:40:11 to 2018-11-15 10:41:26 (75.0 seconds) and wrote 59 records for BTCUSD-BITFINEX | 2018-11-15 10:41:28 Added 4 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:41:28 HD Request # 4 | Completion time: 2s | 2018-11-15 10:41:28 HD Request # 4 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 3 | 2018-11-15 10:41:28 Removed historical data download ID 3 | 2018-11-15 10:41:28 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:41:28 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:41:28 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:41:28 Socket (4) | Closed. | 2018-11-15 10:41:28 Loaded depth data records for XBTUSD-BMEX 2018-10-14 from 2018-10-14 11:00:03 to 2018-10-14 23:59:59. | 2018-11-15 10:41:28 Loaded depth data records for XBTUSD-BMEX 2018-11-05 from 2018-11-05 11:00:03 to 2018-11-06 10:59:59. | 2018-11-15 10:41:29 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:41:30 Loaded depth data records for XBTUSD-BMEX 2018-11-06 from 2018-11-06 11:00:05 to 2018-11-07 10:59:59. | 2018-11-15 10:41:31 Loaded depth data records for XBTUSD-BMEX 2018-11-07 from 2018-11-07 11:00:00 to 2018-11-08 10:59:59. | 2018-11-15 10:41:33 Loaded depth data records for XBTUSD-BMEX 2018-11-08 from 2018-11-08 11:00:03 to 2018-11-09 10:59:59. | 2018-11-15 10:41:35 Loaded depth data records for XBTUSD-BMEX 2018-11-09 from 2018-11-09 11:00:04 to 2018-11-09 23:38:03. | 2018-11-15 10:41:35 Loaded depth data records for XBTUSD-BMEX 2018-11-10 from 2018-11-10 13:50:48 to 2018-11-11 10:59:59. | 2018-11-15 10:41:36 Loaded depth data records for XBTUSD-BMEX 2018-11-11 from 2018-11-11 11:00:04 to 2018-11-12 10:59:59. | 2018-11-15 10:41:39 Loaded depth data records for XBTUSD-BMEX 2018-11-12 from 2018-11-12 11:00:00 to 2018-11-13 10:59:59. | 2018-11-15 10:41:41 Loaded depth data records for XBTUSD-BMEX 2018-11-13 from 2018-11-13 11:00:04 to 2018-11-14 10:59:59. | 2018-11-15 10:41:42 Loaded depth data records for XBTUSD-BMEX 2018-11-14 from 2018-11-14 11:00:00 to 2018-11-15 10:40:20. | 2018-11-15 10:41:44 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:41:48 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:36 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:43:00 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:43:00 Connection to the external service has been lost. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:43:00 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:43:00 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Signaling to core to close socket | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:00 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:43:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Socket gracefully closed by remote side. | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Closed. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Still waiting for graceful close or receive error. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:43:01 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:43:03 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:43:03 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:43:03 BitMEX WebSocket socket (1) | Connecting to IP: 52.49.24.30. | 2018-11-15 10:43:03 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:43:03 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:43:03 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:43:04 GMT | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=NTpWtYs76hRzAicXnYFqrSRPM4TU7gkaB+iW3SYWzImASvOGe/QT1RydK2ncFrsnLjAfuM7uTRX23qYM+5MJjcr+pukG1i2cRRuMNi/c8TWZMnI0v1T4kIzUmGZU; Expires=Wed, 21 Nov 2018 23:43:04 GMT; Path=/ | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: 1cAtP4L8vDzDXAgJKtmSol9CnYg= | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. | 2018-11-15 10:43:04 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:43:04 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:43:04 DTC Client socket (2) | Signaling to core to close socket | 2018-11-15 10:43:04 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:43:04 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:43:04 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:43:04 DTC Client socket (3) | Creating socket. | 2018-11-15 10:43:04 DTC Client socket (3) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:43:04 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:43:05 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:43:05 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:43:05 DTC Client socket (2) | Closed. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:43:05 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:43:06 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:43:06 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:43:06 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:43:07 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:43:08 HTTPS www.bitmex.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 10:43:09 HTTPS www.bitmex.com:443 (4) | Connecting to IP: 52.49.24.30. | 2018-11-15 10:43:09 HD Request # 5 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:43:11 HD Request # 5 | Download start date-time: 2018-11-15 10:43:02.000 | 2018-11-15 10:43:11 HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:43:11 Socket (5) | Creating socket. | 2018-11-15 10:43:11 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:43:11 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:11 HD Request # 5 | Sending historical data logon request message. | 2018-11-15 10:43:11 HD Request # 5 | Requesting Intraday data. Start date-time: 2018-11-15 10:43:02. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:43:12 HD Request # 5 | Decompressing data. | 2018-11-15 10:43:12 HD Request # 5 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:43:02 | 2018-11-15 10:43:12 HD Request # 5 | Timestamp of first Intraday data file record written: 2018-11-15 10:43:02 | 2018-11-15 10:43:12 Socket (5) | Signaling to core to close socket | 2018-11-15 10:43:12 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:12 Historical data download thread signaled to stop. | 2018-11-15 10:43:12 HD Request # 5 | Received 53 records from 2018-11-15 10:43:02 to 2018-11-15 10:43:05 (3.0 seconds) and wrote 46 records for XBTUSD-BMEX | 2018-11-15 10:43:12 Added 23 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:43:12 HD Request # 5 | Completion time: 0s | 2018-11-15 10:43:12 HD Request # 5 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 4 | 2018-11-15 10:43:12 Removed historical data download ID 4 | 2018-11-15 10:43:12 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:43:12 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:43:12 HD Request # 6 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:43:12 HD Request # 6 | Download start date-time: 2018-11-15 10:43:03.000 | 2018-11-15 10:43:12 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:43:12 Socket (2) | Creating socket. | 2018-11-15 10:43:12 Socket (2) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:43:12 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:43:12 Socket (5) | Closed. | 2018-11-15 10:43:12 HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:13 HD Request # 6 | Sending historical data logon request message. | 2018-11-15 10:43:13 HD Request # 6 | Requesting Intraday data. Start date-time: 2018-11-15 10:43:03. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:43:13 HD Request # 6 | Decompressing data. | 2018-11-15 10:43:13 HD Request # 6 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:43:03 | 2018-11-15 10:43:13 HD Request # 6 | Timestamp of first Intraday data file record written: 2018-11-15 10:43:04 | 2018-11-15 10:43:13 Socket (2) | Signaling to core to close socket | 2018-11-15 10:43:13 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:13 Historical data download thread signaled to stop. | 2018-11-15 10:43:13 HD Request # 6 | Received 28 records from 2018-11-15 10:43:03 to 2018-11-15 10:43:10 (7.0 seconds) and wrote 20 records for BTCUSD-BITFINEX | 2018-11-15 10:43:13 Added 1 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:43:13 HD Request # 6 | Completion time: 2s | 2018-11-15 10:43:13 HD Request # 6 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 5 | 2018-11-15 10:43:13 Removed historical data download ID 5 | 2018-11-15 10:43:13 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:43:13 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:43:13 HD Request # 7 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:43:13 HD Request # 7 | Download start date-time: 2018-11-15 10:43:02.000 | 2018-11-15 10:43:13 HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:43:13 Socket (5) | Creating socket. | 2018-11-15 10:43:13 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:43:13 Socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:43:14 Socket (2) | Closed. | 2018-11-15 10:43:14 HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:14 HD Request # 7 | Sending historical data logon request message. | 2018-11-15 10:43:14 HD Request # 7 | Requesting Intraday data. Start date-time: 2018-11-15 10:43:02. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:43:14 HD Request # 7 | Decompressing data. | 2018-11-15 10:43:15 HD Request # 7 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:43:02 | 2018-11-15 10:43:15 HD Request # 7 | Timestamp of first Intraday data file record written: 2018-11-15 10:43:05 | 2018-11-15 10:43:15 Socket (5) | Signaling to core to close socket | 2018-11-15 10:43:15 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:15 Historical data download thread signaled to stop. | 2018-11-15 10:43:15 HD Request # 7 | Received 4 records from 2018-11-15 10:43:02 to 2018-11-15 10:43:08 (6.0 seconds) and wrote 3 records for ETHUSD-BITFINEX | 2018-11-15 10:43:15 HD Request # 7 | Completion time: 1s | 2018-11-15 10:43:15 HD Request # 7 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 6 | 2018-11-15 10:43:15 Removed historical data download ID 6 | 2018-11-15 10:43:15 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:43:15 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:43:15 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:43:15 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:43:15 Socket (5) | Closed. | 2018-11-15 10:43:15 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:43:15 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:43:15 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:43:15 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:43:18 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:55 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:45:17 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:45:17 Connection to the external service has been lost. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:45:17 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:45:17 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Signaling to core to close socket | 2018-11-15 10:45:17 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Closed. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Still waiting for graceful close or receive error. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:45:18 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:45:20 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:45:20 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:45:20 BitMEX WebSocket socket (1) | Connecting to IP: 54.194.47.253. | 2018-11-15 10:45:20 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:45:20 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:45:20 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:45:21 GMT | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=X2boDA3fkMT+bo9KASSgaPtHCgvEaexeG77fUq70gao75rbbQp2uBeiHzgxiU32Pbt+XSs1RWeZOfnI4I2YAbGTh41/EBrFr9hOin9WaE/WsRjtsOd/SNE6rGh5b; Expires=Wed, 21 Nov 2018 23:45:21 GMT; Path=/ | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: XwoWBMNBmaqo/57bvoinYaeQIcs= | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. | 2018-11-15 10:45:21 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:45:21 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:45:21 DTC Client socket (3) | Signaling to core to close socket | 2018-11-15 10:45:21 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:45:21 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:45:21 DTC Client socket (4) | Creating socket. | 2018-11-15 10:45:21 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:45:21 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:45:21 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:45:22 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:45:22 DTC Client socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:45:22 DTC Client socket (3) | Closed. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:45:22 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:45:23 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:45:23 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:45:23 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:45:25 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:45:25 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:45:26 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.194.47.253. | 2018-11-15 10:45:26 HD Request # 8 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:45:28 HD Request # 8 | Download start date-time: 2018-11-15 10:45:18.000 | 2018-11-15 10:45:28 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:45:28 Socket (3) | Creating socket. | 2018-11-15 10:45:28 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:45:28 HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:28 HD Request # 8 | Sending historical data logon request message. | 2018-11-15 10:45:28 HD Request # 8 | Requesting Intraday data. Start date-time: 2018-11-15 10:45:18. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:45:29 HD Request # 8 | Decompressing data. | 2018-11-15 10:45:29 HD Request # 8 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:45:18 | 2018-11-15 10:45:29 HD Request # 8 | Timestamp of first Intraday data file record written: 2018-11-15 10:45:19 | 2018-11-15 10:45:29 Socket (3) | Signaling to core to close socket | 2018-11-15 10:45:29 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:29 Historical data download thread signaled to stop. | 2018-11-15 10:45:29 HD Request # 8 | Received 105 records from 2018-11-15 10:45:18 to 2018-11-15 10:45:27 (9.0 seconds) and wrote 99 records for XBTUSD-BMEX | 2018-11-15 10:45:29 Added 2 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:45:29 HD Request # 8 | Completion time: 2s | 2018-11-15 10:45:29 HD Request # 8 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 7 | 2018-11-15 10:45:29 Removed historical data download ID 7 | 2018-11-15 10:45:29 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:45:29 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:45:29 HD Request # 9 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:45:29 HD Request # 9 | Download start date-time: 2018-11-15 10:45:20.000 | 2018-11-15 10:45:29 HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:45:29 Socket (5) | Creating socket. | 2018-11-15 10:45:29 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:45:29 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:45:29 Socket (3) | Closed. | 2018-11-15 10:45:29 HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:30 HD Request # 9 | Sending historical data logon request message. | 2018-11-15 10:45:30 HD Request # 9 | Requesting Intraday data. Start date-time: 2018-11-15 10:45:20. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:45:30 HD Request # 9 | Decompressing data. | 2018-11-15 10:45:30 HD Request # 9 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:45:20 | 2018-11-15 10:45:30 HD Request # 9 | Timestamp of first Intraday data file record written: 2018-11-15 10:45:22 | 2018-11-15 10:45:30 Socket (5) | Signaling to core to close socket | 2018-11-15 10:45:30 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:30 Historical data download thread signaled to stop. | 2018-11-15 10:45:30 HD Request # 9 | Received 9 records from 2018-11-15 10:45:20 to 2018-11-15 10:45:25 (5.0 seconds) and wrote 7 records for BTCUSD-BITFINEX | 2018-11-15 10:45:30 Added 2 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:45:30 HD Request # 9 | Completion time: 0s | 2018-11-15 10:45:30 HD Request # 9 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 8 | 2018-11-15 10:45:30 Removed historical data download ID 8 | 2018-11-15 10:45:30 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:45:30 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:45:30 HD Request # 10 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:45:30 HD Request # 10 | Download start date-time: 2018-11-15 10:45:18.000 | 2018-11-15 10:45:30 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:45:30 Socket (3) | Creating socket. | 2018-11-15 10:45:30 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:45:30 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:45:31 Socket (5) | Closed. | 2018-11-15 10:45:31 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:45:31 HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:31 HD Request # 10 | Sending historical data logon request message. | 2018-11-15 10:45:31 HD Request # 10 | Requesting Intraday data. Start date-time: 2018-11-15 10:45:18. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:45:31 HD Request # 10 | Decompressing data. | 2018-11-15 10:45:32 HD Request # 10 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:45:18 | 2018-11-15 10:45:32 HD Request # 10 | Timestamp of first Intraday data file record written: 2018-11-15 10:45:21 | 2018-11-15 10:45:32 Socket (3) | Signaling to core to close socket | 2018-11-15 10:45:32 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:32 Historical data download thread signaled to stop. | 2018-11-15 10:45:32 HD Request # 10 | Received 15 records from 2018-11-15 10:45:18 to 2018-11-15 10:45:26 (8.0 seconds) and wrote 13 records for ETHUSD-BITFINEX | 2018-11-15 10:45:32 HD Request # 10 | Completion time: 1s | 2018-11-15 10:45:32 HD Request # 10 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 9 | 2018-11-15 10:45:32 Removed historical data download ID 9 | 2018-11-15 10:45:32 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:45:32 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:45:32 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:45:32 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:45:32 Socket (3) | Closed. | 2018-11-15 10:45:32 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:45:32 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:45:37 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:45:37 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 10:45:49 * BitMEX Trading Direct | Parse buffer: <html> <head><title>502 Bad Gateway</title></head> <body bgcolor="white"> <center><h1>502 Bad Gateway</h1></center> </body> </html> | 2018-11-15 10:45:49 * HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 10:48:49 The message log has been sent to support. | 2018-11-15 10:58:56 * HTTPS www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:58:56 HTTPS www.sierrachart.com:443 (2) | Connecting to IP: 204.15.192.108. | 2018-11-15 10:58:56 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2018-11-15 10:59:00 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-11-15 10:59:05 Reading Internal Order ID file. | 2018-11-15 10:41:06 Reading Trade Orders file. | 2018-11-15 10:41:06 Reading Trade Positions and Account Balance file. | 2018-11-15 10:41:06 Listening on UDP port 22904. | 2018-11-15 10:41:06 Software version: 1815 64-bit | 2018-11-15 10:41:06 Usage end date: 2018-11-24 | 2018-11-15 10:41:06 Enabled for: Advanced Features. | 2018-11-15 10:41:06 Enabled for: Advanced Features 2. | 2018-11-15 10:41:06 Enabled for: Sierra Chart Historical Data Service. | 2018-11-15 10:41:06 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-11-15 10:41:06 Current selected Data/Trading service: BitMEX Trading Direct | 2018-11-15 10:41:06 Chart Update Interval: 500 | 2018-11-15 10:41:06 Time Zone: +11:00:00 (AEST+10AEDT+01,M10.1.0/02:00,M4.1.0/03:00) | 2018-11-15 10:41:06 2018-11-15 10:41:06 Local computer time | 2018-11-15 10:41:06 2018-11-14 23:41:06 Local computer time in UTC | 2018-11-15 10:41:06 2018-11-15 10:41:06 Local computer time in SC Time Zone | 2018-11-15 10:41:06 2018-11-14 23:41:03 Server time in UTC | 2018-11-15 10:41:06 Local computer UTC time and Server UTC time difference: 2 seconds. | 2018-11-15 10:41:06 Program path: C:\SierraChart\ | 2018-11-15 10:41:06 Data Files path: C:\SierraChart\Data\ | 2018-11-15 10:41:06 OS Version Number: 10.0 | 2018-11-15 10:41:06 Locale Setting: C | 2018-11-15 10:41:06 Checking for new symbol settings for service code bitmex.exchange.trading | 2018-11-15 10:41:06 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:06 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-11-15 10:41:06 Received 5 login tokens. | 2018-11-15 10:41:08 Symbol settings are up-to-date for bitmex.exchange.trading | 2018-11-15 10:41:08 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:08 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-11-15 10:41:08 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:09 HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-11-15 10:41:09 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:13 HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-11-15 10:41:13 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:41:13 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:41:13 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:13 BitMEX WebSocket socket (1) | Connecting to IP: 54.77.38.28. | 2018-11-15 10:41:13 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:41:13 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:41:13 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:41:13 GMT | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=RrPQNwFLTTaThWg0BNWj3J+HNVSJEHX29PRR3LI2C7NIay8TNU5hDVPp5q5qReG0UGTAjgvnwHybIGF1yYU9BtHPEiEnQQjCR7B3FBwiW43T4Q2AbsujWY4+4Vf0; Expires=Wed, 21 Nov 2018 23:41:13 GMT; Path=/ | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: 2ulMmDdAaC9jaLDNM6vNv9Ext+c= | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:41:14 BitMEX WebSocket | Header line. | 2018-11-15 10:41:14 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:41:14 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:41:14 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:41:15 HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-11-15 10:41:15 XBTUSD-BMEX 1 Min #2 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 15 Min #4 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 10 Sec #1 | Reloading chart. | 2018-11-15 10:41:15 ETHUSD-BITFINEX 1 Min #5 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 1 Min #6 | Reloading chart. | 2018-11-15 10:41:15 BTCUSD-BITFINEX 1 Min #7 | Reloading chart. | 2018-11-15 10:41:15 XBTUSD-BMEX 5 Min #8 | Reloading chart. | 2018-11-15 10:41:16 BTCUSD-BITFINEX 5 Min #9 | Reloading chart. | 2018-11-15 10:41:16 XBTUSD-BMEX #10 | Reloading chart. | 2018-11-15 10:41:16 + Loading market depth data. | 2018-11-15 10:41:17 Loaded depth data records for XBTUSD-BMEX 2018-10-30 from 2018-10-31 10:40:22 to 2018-10-31 10:59:59. | 2018-11-15 10:41:17 XBTUSD-BMEX 10 Sec #3 | Reloading chart. | 2018-11-15 10:41:17 XBTUSD-BMEX 1 Min #11 | Reloading chart. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2018-11-15 10:41:18 DTC Client socket (2) | Creating socket. | 2018-11-15 10:41:18 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:41:18 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:41:18 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:41:18 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 2 | 2018-11-15 10:41:18 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 3 | 2018-11-15 10:41:18 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:18 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:41:18 + Loading market depth data. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:41:19 Loaded depth data records for XBTUSD-BMEX 2018-10-31 from 2018-10-31 11:00:03 to 2018-11-01 10:59:59. | 2018-11-15 10:41:19 HTTPS www.bitmex.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-11-15 10:41:19 HTTPS www.bitmex.com:443 (3) | Connecting to IP: 54.77.38.28. | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:41:19 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:41:20 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:41:20 Loaded depth data records for XBTUSD-BMEX 2018-10-10 from 2018-10-11 00:00:04 to 2018-10-11 10:59:59. | 2018-11-15 10:41:20 Loaded depth data records for XBTUSD-BMEX 2018-11-01 from 2018-11-01 11:00:03 to 2018-11-02 10:59:59. | 2018-11-15 10:41:21 Loaded depth data records for XBTUSD-BMEX 2018-10-11 from 2018-10-11 11:00:04 to 2018-10-12 10:59:58. | 2018-11-15 10:41:23 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:41:23 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:41:23 Loaded depth data records for XBTUSD-BMEX 2018-11-02 from 2018-11-02 11:00:03 to 2018-11-03 10:59:59. | 2018-11-15 10:41:24 HD Request # 2 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:41:24 HD Request # 2 | Download start date-time: 2018-11-15 10:40:22.000 | 2018-11-15 10:41:24 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:41:24 Socket (4) | Creating socket. | 2018-11-15 10:41:24 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:41:24 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:25 HD Request # 2 | Sending historical data logon request message. | 2018-11-15 10:41:25 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-11-15 10:40:22. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:41:25 HD Request # 2 | Decompressing data. | 2018-11-15 10:41:25 HD Request # 2 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:40:22 | 2018-11-15 10:41:25 HD Request # 2 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:22 | 2018-11-15 10:41:25 Socket (4) | Signaling to core to close socket | 2018-11-15 10:41:25 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:41:25 Historical data download thread signaled to stop. | 2018-11-15 10:41:25 HD Request # 2 | Received 606 records from 2018-11-15 10:40:22 to 2018-11-15 10:41:22 (60.0 seconds) and wrote 605 records for XBTUSD-BMEX | 2018-11-15 10:41:25 Added 10 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:41:25 HD Request # 2 | Completion time: 0s | 2018-11-15 10:41:25 HD Request # 2 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 1 | 2018-11-15 10:41:25 Loaded depth data records for XBTUSD-BMEX 2018-11-03 from 2018-11-03 11:00:04 to 2018-11-04 10:59:59. | 2018-11-15 10:41:25 Removed historical data download ID 1 | 2018-11-15 10:41:25 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:41:25 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:41:25 HD Request # 3 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:41:25 HD Request # 3 | Download start date-time: 2018-11-15 10:40:21.000 | 2018-11-15 10:41:25 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:41:25 Socket (5) | Creating socket. | 2018-11-15 10:41:25 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:41:25 Loaded depth data records for XBTUSD-BMEX 2018-10-12 from 2018-10-12 11:00:00 to 2018-10-13 10:59:59. | 2018-11-15 10:41:26 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:41:26 Socket (4) | Closed. | 2018-11-15 10:41:26 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:26 HD Request # 3 | Sending historical data logon request message. | 2018-11-15 10:41:26 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-11-15 10:40:21. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:41:26 HD Request # 3 | Decompressing data. | 2018-11-15 10:41:27 HD Request # 3 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:40:21 | 2018-11-15 10:41:27 HD Request # 3 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:23 | 2018-11-15 10:41:27 Socket (5) | Signaling to core to close socket | 2018-11-15 10:41:27 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:41:27 Historical data download thread signaled to stop. | 2018-11-15 10:41:27 HD Request # 3 | Received 66 records from 2018-11-15 10:40:21 to 2018-11-15 10:41:23 (62.0 seconds) and wrote 58 records for ETHUSD-BITFINEX | 2018-11-15 10:41:27 Added 2 Time and Sales records to Intraday data file for ETHUSD-BITFINEX after download. | 2018-11-15 10:41:27 HD Request # 3 | Completion time: 0s | 2018-11-15 10:41:27 HD Request # 3 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 2 | 2018-11-15 10:41:27 Removed historical data download ID 2 | 2018-11-15 10:41:27 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:41:27 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:41:27 HD Request # 4 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:41:27 HD Request # 4 | Download start date-time: 2018-11-15 10:40:11.000 | 2018-11-15 10:41:27 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:41:27 Socket (4) | Creating socket. | 2018-11-15 10:41:27 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:41:27 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:41:27 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:41:27 Socket (5) | Closed. | 2018-11-15 10:41:27 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:41:27 Loaded depth data records for XBTUSD-BMEX 2018-11-04 from 2018-11-04 11:00:02 to 2018-11-05 10:59:59. | 2018-11-15 10:41:27 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-11-15 10:41:27 HD Request # 4 | Sending historical data logon request message. | 2018-11-15 10:41:27 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:41:27 Loaded depth data records for XBTUSD-BMEX 2018-10-13 from 2018-10-13 11:00:03 to 2018-10-14 10:59:59. | 2018-11-15 10:41:28 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-11-15 10:40:11. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:41:28 HD Request # 4 | Decompressing data. | 2018-11-15 10:41:28 HD Request # 4 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:40:11 | 2018-11-15 10:41:28 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-11-15 10:40:27 | 2018-11-15 10:41:28 Socket (4) | Signaling to core to close socket | 2018-11-15 10:41:28 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:41:28 Historical data download thread signaled to stop. | 2018-11-15 10:41:28 HD Request # 4 | Received 60 records from 2018-11-15 10:40:11 to 2018-11-15 10:41:26 (75.0 seconds) and wrote 59 records for BTCUSD-BITFINEX | 2018-11-15 10:41:28 Added 4 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:41:28 HD Request # 4 | Completion time: 2s | 2018-11-15 10:41:28 HD Request # 4 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 3 | 2018-11-15 10:41:28 Removed historical data download ID 3 | 2018-11-15 10:41:28 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:41:28 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:41:28 Socket (4) | Socket gracefully closed by remote side. | 2018-11-15 10:41:28 Socket (4) | Closed. | 2018-11-15 10:41:28 Loaded depth data records for XBTUSD-BMEX 2018-10-14 from 2018-10-14 11:00:03 to 2018-10-14 23:59:59. | 2018-11-15 10:41:28 Loaded depth data records for XBTUSD-BMEX 2018-11-05 from 2018-11-05 11:00:03 to 2018-11-06 10:59:59. | 2018-11-15 10:41:29 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:41:30 Loaded depth data records for XBTUSD-BMEX 2018-11-06 from 2018-11-06 11:00:05 to 2018-11-07 10:59:59. | 2018-11-15 10:41:31 Loaded depth data records for XBTUSD-BMEX 2018-11-07 from 2018-11-07 11:00:00 to 2018-11-08 10:59:59. | 2018-11-15 10:41:33 Loaded depth data records for XBTUSD-BMEX 2018-11-08 from 2018-11-08 11:00:03 to 2018-11-09 10:59:59. | 2018-11-15 10:41:35 Loaded depth data records for XBTUSD-BMEX 2018-11-09 from 2018-11-09 11:00:04 to 2018-11-09 23:38:03. | 2018-11-15 10:41:35 Loaded depth data records for XBTUSD-BMEX 2018-11-10 from 2018-11-10 13:50:48 to 2018-11-11 10:59:59. | 2018-11-15 10:41:36 Loaded depth data records for XBTUSD-BMEX 2018-11-11 from 2018-11-11 11:00:04 to 2018-11-12 10:59:59. | 2018-11-15 10:41:39 Loaded depth data records for XBTUSD-BMEX 2018-11-12 from 2018-11-12 11:00:00 to 2018-11-13 10:59:59. | 2018-11-15 10:41:41 Loaded depth data records for XBTUSD-BMEX 2018-11-13 from 2018-11-13 11:00:04 to 2018-11-14 10:59:59. | 2018-11-15 10:41:42 Loaded depth data records for XBTUSD-BMEX 2018-11-14 from 2018-11-14 11:00:00 to 2018-11-15 10:40:20. | 2018-11-15 10:41:44 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:41:48 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:42:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:42:36 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:43:00 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:43:00 Connection to the external service has been lost. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:43:00 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:43:00 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Signaling to core to close socket | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:00 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:43:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Socket gracefully closed by remote side. | 2018-11-15 10:43:00 HTTPS www.bitmex.com:443 (3) | Closed. | 2018-11-15 10:43:00 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Still waiting for graceful close or receive error. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:43:01 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:43:01 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:43:03 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:43:03 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:43:03 BitMEX WebSocket socket (1) | Connecting to IP: 52.49.24.30. | 2018-11-15 10:43:03 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:43:03 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:43:03 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:43:04 GMT | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=NTpWtYs76hRzAicXnYFqrSRPM4TU7gkaB+iW3SYWzImASvOGe/QT1RydK2ncFrsnLjAfuM7uTRX23qYM+5MJjcr+pukG1i2cRRuMNi/c8TWZMnI0v1T4kIzUmGZU; Expires=Wed, 21 Nov 2018 23:43:04 GMT; Path=/ | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: 1cAtP4L8vDzDXAgJKtmSol9CnYg= | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:43:04 BitMEX WebSocket | Header line. | 2018-11-15 10:43:04 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:43:04 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:43:04 DTC Client socket (2) | Signaling to core to close socket | 2018-11-15 10:43:04 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:43:04 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:43:04 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:43:04 DTC Client socket (3) | Creating socket. | 2018-11-15 10:43:04 DTC Client socket (3) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:43:04 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:43:04 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:43:05 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:43:05 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:43:05 DTC Client socket (2) | Closed. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:43:05 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:43:05 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:43:06 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:43:06 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:43:06 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:43:07 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:43:08 HTTPS www.bitmex.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-15 10:43:09 HTTPS www.bitmex.com:443 (4) | Connecting to IP: 52.49.24.30. | 2018-11-15 10:43:09 HD Request # 5 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:43:11 HD Request # 5 | Download start date-time: 2018-11-15 10:43:02.000 | 2018-11-15 10:43:11 HD Request # 5 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:43:11 Socket (5) | Creating socket. | 2018-11-15 10:43:11 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:43:11 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:11 HD Request # 5 | Sending historical data logon request message. | 2018-11-15 10:43:11 HD Request # 5 | Requesting Intraday data. Start date-time: 2018-11-15 10:43:02. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:43:12 HD Request # 5 | Decompressing data. | 2018-11-15 10:43:12 HD Request # 5 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:43:02 | 2018-11-15 10:43:12 HD Request # 5 | Timestamp of first Intraday data file record written: 2018-11-15 10:43:02 | 2018-11-15 10:43:12 Socket (5) | Signaling to core to close socket | 2018-11-15 10:43:12 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:12 Historical data download thread signaled to stop. | 2018-11-15 10:43:12 HD Request # 5 | Received 53 records from 2018-11-15 10:43:02 to 2018-11-15 10:43:05 (3.0 seconds) and wrote 46 records for XBTUSD-BMEX | 2018-11-15 10:43:12 Added 23 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:43:12 HD Request # 5 | Completion time: 0s | 2018-11-15 10:43:12 HD Request # 5 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 4 | 2018-11-15 10:43:12 Removed historical data download ID 4 | 2018-11-15 10:43:12 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:43:12 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:43:12 HD Request # 6 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:43:12 HD Request # 6 | Download start date-time: 2018-11-15 10:43:03.000 | 2018-11-15 10:43:12 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:43:12 Socket (2) | Creating socket. | 2018-11-15 10:43:12 Socket (2) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:43:12 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:43:12 Socket (5) | Closed. | 2018-11-15 10:43:12 HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:13 HD Request # 6 | Sending historical data logon request message. | 2018-11-15 10:43:13 HD Request # 6 | Requesting Intraday data. Start date-time: 2018-11-15 10:43:03. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:43:13 HD Request # 6 | Decompressing data. | 2018-11-15 10:43:13 HD Request # 6 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:43:03 | 2018-11-15 10:43:13 HD Request # 6 | Timestamp of first Intraday data file record written: 2018-11-15 10:43:04 | 2018-11-15 10:43:13 Socket (2) | Signaling to core to close socket | 2018-11-15 10:43:13 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:13 Historical data download thread signaled to stop. | 2018-11-15 10:43:13 HD Request # 6 | Received 28 records from 2018-11-15 10:43:03 to 2018-11-15 10:43:10 (7.0 seconds) and wrote 20 records for BTCUSD-BITFINEX | 2018-11-15 10:43:13 Added 1 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:43:13 HD Request # 6 | Completion time: 2s | 2018-11-15 10:43:13 HD Request # 6 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 5 | 2018-11-15 10:43:13 Removed historical data download ID 5 | 2018-11-15 10:43:13 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:43:13 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:43:13 HD Request # 7 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:43:13 HD Request # 7 | Download start date-time: 2018-11-15 10:43:02.000 | 2018-11-15 10:43:13 HD Request # 7 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:43:13 Socket (5) | Creating socket. | 2018-11-15 10:43:13 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:43:13 Socket (2) | Socket gracefully closed by remote side. | 2018-11-15 10:43:14 Socket (2) | Closed. | 2018-11-15 10:43:14 HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-11-15 10:43:14 HD Request # 7 | Sending historical data logon request message. | 2018-11-15 10:43:14 HD Request # 7 | Requesting Intraday data. Start date-time: 2018-11-15 10:43:02. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:43:14 HD Request # 7 | Decompressing data. | 2018-11-15 10:43:15 HD Request # 7 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:43:02 | 2018-11-15 10:43:15 HD Request # 7 | Timestamp of first Intraday data file record written: 2018-11-15 10:43:05 | 2018-11-15 10:43:15 Socket (5) | Signaling to core to close socket | 2018-11-15 10:43:15 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:43:15 Historical data download thread signaled to stop. | 2018-11-15 10:43:15 HD Request # 7 | Received 4 records from 2018-11-15 10:43:02 to 2018-11-15 10:43:08 (6.0 seconds) and wrote 3 records for ETHUSD-BITFINEX | 2018-11-15 10:43:15 HD Request # 7 | Completion time: 1s | 2018-11-15 10:43:15 HD Request # 7 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 6 | 2018-11-15 10:43:15 Removed historical data download ID 6 | 2018-11-15 10:43:15 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:43:15 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:43:15 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:43:15 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:43:15 Socket (5) | Closed. | 2018-11-15 10:43:15 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:43:15 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:43:15 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:43:15 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:43:18 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:55 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:56 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:57 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:58 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:43:59 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:00 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:01 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:02 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:03 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:04 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:05 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:06 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:07 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:08 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:09 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:10 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:11 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:12 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:13 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:14 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:15 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:16 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:17 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:18 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:19 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:20 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:21 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:22 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:23 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:24 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:25 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:26 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:27 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:28 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:29 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:30 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:31 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:32 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:33 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:34 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:35 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:36 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:37 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:38 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:39 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:40 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:41 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:42 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:43 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:44 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:45 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:49 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:50 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:51 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:52 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:53 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:54 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:44:55 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:44:55 * BitMEX WebSocket | Timeout waiting for pong message from server. | 2018-11-15 10:45:17 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:45:17 Connection to the external service has been lost. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Adding bytes from final send buffer from buffered socket: 8 | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Signaling to core to close socket | 2018-11-15 10:45:17 BitMEX WebSocket | WebSocket closed. | 2018-11-15 10:45:17 BitMEX Trading Direct | WebSocket closed. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Signaling to core to close socket | 2018-11-15 10:45:17 BitMEX Trading Direct | Disconnected. | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Sending bytes from final send buffer: 8 | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-15 10:45:17 HTTPS www.bitmex.com:443 (4) | Closed. | 2018-11-15 10:45:17 BitMEX WebSocket socket (1) | Write has completed. Shutdown being performed. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Received socket Close event. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Still waiting for graceful close or receive error. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Socket gracefully closed by remote side. | 2018-11-15 10:45:18 BitMEX WebSocket socket (1) | Closed. | 2018-11-15 10:45:18 BitMEX Trading Direct | Connecting to URI www.bitmex.com/realtime/WebSocket | 2018-11-15 10:45:20 BitMEX WebSocket | Connecting to WebSocket server. | 2018-11-15 10:45:20 BitMEX WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2018-11-15 10:45:20 BitMEX WebSocket socket (1) | Connecting to IP: 54.194.47.253. | 2018-11-15 10:45:20 BitMEX WebSocket | Opening WebSocket. | 2018-11-15 10:45:20 BitMEX WebSocket | Sending WebSocket handshake. | 2018-11-15 10:45:20 BitMEX WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Date: Wed, 14 Nov 2018 23:45:21 GMT | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Connection: upgrade | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Set-Cookie: AWSALB=X2boDA3fkMT+bo9KASSgaPtHCgvEaexeG77fUq70gao75rbbQp2uBeiHzgxiU32Pbt+XSs1RWeZOfnI4I2YAbGTh41/EBrFr9hOin9WaE/WsRjtsOd/SNE6rGh5b; Expires=Wed, 21 Nov 2018 23:45:21 GMT; Path=/ | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Upgrade: websocket | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Sec-WebSocket-Accept: XwoWBMNBmaqo/57bvoinYaeQIcs= | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Sec-WebSocket-Version: 13 | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. WebSocket-Server: uWebSockets | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. Strict-Transport-Security: max-age=31536000; includeSubDomains | 2018-11-15 10:45:21 BitMEX WebSocket | Header line. | 2018-11-15 10:45:21 BitMEX WebSocket | Web socket state is now open. | 2018-11-15 10:45:21 BitMEX Trading Direct | Connected to data and trading server. | 2018-11-15 10:45:21 DTC Client socket (3) | Signaling to core to close socket | 2018-11-15 10:45:21 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Disconnected from the server. | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Starting real-time market data updates for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Requesting security definition data for: XBTUSD-BMEX. ID: 1 | 2018-11-15 10:45:21 Intraday data recording state for symbol XBTUSD-BMEX is set to download 'Pending'. | 2018-11-15 10:45:21 DTC Client socket (4) | Creating socket. | 2018-11-15 10:45:21 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:45:21 Delaying start of download for XBTUSD-BMEX | 2018-11-15 10:45:21 Requesting market depth updates for: XBTUSD-BMEX if supported. | 2018-11-15 10:45:21 SC DTC Data with Market Depth | Starting real-time market data updates for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Requesting security definition data for: BTCUSD-BITFINEX. ID: 2 | 2018-11-15 10:45:22 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:45:22 DTC Client socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:45:22 DTC Client socket (3) | Closed. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Connected to server. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Starting real-time market data updates for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Requesting security definition data for: ETHUSD-BITFINEX. ID: 3 | 2018-11-15 10:45:22 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Received logon response. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Successfully connected. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XBTUSD-BMEX | 2018-11-15 10:45:22 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-11-15 10:45:23 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-11-15 10:45:23 SC DTC Data with Market Depth | Received security definition for symbol XBTUSD-BMEX | 2018-11-15 10:45:23 SC DTC Data with Market Depth | Clearing market depth for XBTUSD-BMEX. | 2018-11-15 10:45:25 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-14.depth | 2018-11-15 10:45:25 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:45:26 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.194.47.253. | 2018-11-15 10:45:26 HD Request # 8 | Downloading Intraday chart data for XBTUSD-BMEX to the file XBTUSD-BMEX.scid. Service: bitmex | 2018-11-15 10:45:28 HD Request # 8 | Download start date-time: 2018-11-15 10:45:18.000 | 2018-11-15 10:45:28 HD Request # 8 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:45:28 Socket (3) | Creating socket. | 2018-11-15 10:45:28 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:45:28 HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:28 HD Request # 8 | Sending historical data logon request message. | 2018-11-15 10:45:28 HD Request # 8 | Requesting Intraday data. Start date-time: 2018-11-15 10:45:18. Record interval: 0. Symbol: XBTUSD-BMEX | 2018-11-15 10:45:29 HD Request # 8 | Decompressing data. | 2018-11-15 10:45:29 HD Request # 8 | Receiving Intraday data for XBTUSD-BMEX starting at 2018-11-15 10:45:18 | 2018-11-15 10:45:29 HD Request # 8 | Timestamp of first Intraday data file record written: 2018-11-15 10:45:19 | 2018-11-15 10:45:29 Socket (3) | Signaling to core to close socket | 2018-11-15 10:45:29 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:29 Historical data download thread signaled to stop. | 2018-11-15 10:45:29 HD Request # 8 | Received 105 records from 2018-11-15 10:45:18 to 2018-11-15 10:45:27 (9.0 seconds) and wrote 99 records for XBTUSD-BMEX | 2018-11-15 10:45:29 Added 2 Time and Sales records to Intraday data file for XBTUSD-BMEX after download. | 2018-11-15 10:45:29 HD Request # 8 | Completion time: 2s | 2018-11-15 10:45:29 HD Request # 8 | Intraday data download complete for XBTUSD-BMEX. Unique request ID: 7 | 2018-11-15 10:45:29 Removed historical data download ID 7 | 2018-11-15 10:45:29 Real-time Intraday chart data file updates started for XBTUSD-BMEX | 2018-11-15 10:45:29 Intraday chart data file opened for XBTUSD-BMEX | 2018-11-15 10:45:29 HD Request # 9 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:45:29 HD Request # 9 | Download start date-time: 2018-11-15 10:45:20.000 | 2018-11-15 10:45:29 HD Request # 9 | Using server: ds3.sierracharts.com port 10150 | 2018-11-15 10:45:29 Socket (5) | Creating socket. | 2018-11-15 10:45:29 Socket (5) | Connecting to IP: 65.182.172.42. | 2018-11-15 10:45:29 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:45:29 Socket (3) | Closed. | 2018-11-15 10:45:29 HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:30 HD Request # 9 | Sending historical data logon request message. | 2018-11-15 10:45:30 HD Request # 9 | Requesting Intraday data. Start date-time: 2018-11-15 10:45:20. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-11-15 10:45:30 HD Request # 9 | Decompressing data. | 2018-11-15 10:45:30 HD Request # 9 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-11-15 10:45:20 | 2018-11-15 10:45:30 HD Request # 9 | Timestamp of first Intraday data file record written: 2018-11-15 10:45:22 | 2018-11-15 10:45:30 Socket (5) | Signaling to core to close socket | 2018-11-15 10:45:30 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:30 Historical data download thread signaled to stop. | 2018-11-15 10:45:30 HD Request # 9 | Received 9 records from 2018-11-15 10:45:20 to 2018-11-15 10:45:25 (5.0 seconds) and wrote 7 records for BTCUSD-BITFINEX | 2018-11-15 10:45:30 Added 2 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-11-15 10:45:30 HD Request # 9 | Completion time: 0s | 2018-11-15 10:45:30 HD Request # 9 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 8 | 2018-11-15 10:45:30 Removed historical data download ID 8 | 2018-11-15 10:45:30 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-11-15 10:45:30 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-11-15 10:45:30 HD Request # 10 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-11-15 10:45:30 HD Request # 10 | Download start date-time: 2018-11-15 10:45:18.000 | 2018-11-15 10:45:30 HD Request # 10 | Using server: ds4.sierracharts.com port 10149 | 2018-11-15 10:45:30 Socket (3) | Creating socket. | 2018-11-15 10:45:30 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-11-15 10:45:30 Socket (5) | Socket gracefully closed by remote side. | 2018-11-15 10:45:31 Socket (5) | Closed. | 2018-11-15 10:45:31 Opened cached Intraday file: C:\SierraChart\Data\XBTUSD-BMEX.scid | 2018-11-15 10:45:31 HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-11-15 10:45:31 HD Request # 10 | Sending historical data logon request message. | 2018-11-15 10:45:31 HD Request # 10 | Requesting Intraday data. Start date-time: 2018-11-15 10:45:18. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-11-15 10:45:31 HD Request # 10 | Decompressing data. | 2018-11-15 10:45:32 HD Request # 10 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-11-15 10:45:18 | 2018-11-15 10:45:32 HD Request # 10 | Timestamp of first Intraday data file record written: 2018-11-15 10:45:21 | 2018-11-15 10:45:32 Socket (3) | Signaling to core to close socket | 2018-11-15 10:45:32 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-15 10:45:32 Historical data download thread signaled to stop. | 2018-11-15 10:45:32 HD Request # 10 | Received 15 records from 2018-11-15 10:45:18 to 2018-11-15 10:45:26 (8.0 seconds) and wrote 13 records for ETHUSD-BITFINEX | 2018-11-15 10:45:32 HD Request # 10 | Completion time: 1s | 2018-11-15 10:45:32 HD Request # 10 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 9 | 2018-11-15 10:45:32 Removed historical data download ID 9 | 2018-11-15 10:45:32 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-11-15 10:45:32 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-11-15 10:45:32 Chart #5 has tagged chart #2 for full recalculation. Chartbook: Bitmex.Cht | 2018-11-15 10:45:32 Socket (3) | Socket gracefully closed by remote side. | 2018-11-15 10:45:32 Socket (3) | Closed. | 2018-11-15 10:45:32 XBTUSD-BMEX [M] 1 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: Bitmex.Cht | 2018-11-15 10:45:32 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-11-15 10:45:37 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-11-15 10:45:37 BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:46 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:47 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'orderID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'clOrdID' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordStatus' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'symbol' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'side' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'orderQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'cumQty' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'ordType' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | No 'timeInForce' object in JSON message. | 2018-11-15 10:45:48 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 10:45:49 * BitMEX Trading Direct | Parse buffer: <html> <head><title>502 Bad Gateway</title></head> <body bgcolor="white"> <center><h1>502 Bad Gateway</h1></center> </body> </html> | 2018-11-15 10:45:49 * HTTPS www.bitmex.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Received socket Close event. | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:48:49 HTTPS www.bitmex.com:443 (2) | Closed. | 2018-11-15 10:48:49 The message log has been sent to support. | 2018-11-15 10:58:56 * HTTPS www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 10:58:56 HTTPS www.sierrachart.com:443 (2) | Connecting to IP: 204.15.192.108. | 2018-11-15 10:58:56 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2018-11-15 10:59:00 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-15 10:59:05 HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-11-15 10:59:05 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\XBTUSD-BMEX.2018-11-15.depth | 2018-11-15 11:00:01 HTTPS www.bitmex.com:443 (2) | Creating socket. Using TLS 1.2. | 2018-11-15 11:14:59 HTTPS www.bitmex.com:443 (2) | Connecting to IP: 54.246.214.15. | 2018-11-15 11:14:59 BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 11:15:00 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 11:15:00 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 11:15:00 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 11:15:00 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 11:15:16 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 11:15:16 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 11:15:16 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 11:15:16 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 11:15:19 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 11:15:19 * BitMEX Trading Direct | JSON parse error in HTTP2RequestCompleted response: Expect either an object or array at root | 2018-11-15 11:15:19 * BitMEX Trading Direct | Parse buffer: <html> <head><title>403 Forbidden</title></head> <body bgcolor="white"> <center><h1>403 Forbidden</h1></center> </body> </html> | 2018-11-15 11:15:19 * |
[2018-11-16 03:25:47] |
We've implemented a solution for this. It will be out in about a day. You are also running an older version and you should update now and when the new version comes out.
[2018-11-16 03:51:44] |
Andrew Ton - Posts: 28 |
Thank you. I have updated to version 1842. Will update as soon as the hotfix for this issue release.
[2018-11-18 00:14:02] |
Hello, is the solution for this out yet and which version should I download ? Thanks
[2018-11-19 05:01:51] |
Yes you can download prerelease 1843 now. Solutions to problems like these can only be implemented based upon the messages that we see in the log since BitMex does not use a properly designed API like the DTC Protocol. The use of REST and a websocket is a ridiculous mess that has been widely adopted. It is nothing more than a disorganized and inefficient mess. And we do not give a damn if the entire world disagrees with us. The simple fact remains, we are right about this. Some of the protocols that exist on the Internet are a mess. Plain and simple. We implemented one solution based upon what we saw. If there is anything else we need to see the messages that occur and then determine the right solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-19 05:04:34
[2018-11-19 05:35:55] |
Actually 1843 has a small issue we need to resolve first related to adding order fills to a chart for statistics processing. It has been removed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-19 05:36:24
