Date/Time: Sun, 24 Nov 2024 11:41:07 +0000
Enable Fix Logging with CTS
View Count: 1492
[2013-11-03 23:51:08] |
natanibz - Posts: 134 |
Hello i use CTS with Fix connection, and i would like to know if i have to enable "Enable Fix Logging" in Data Trade Service Setting. Thanks |
[2013-11-04 00:02:47] |
This is a good idea to enable if there is a problem with Orders and CTS requires the log file. Otherwise, there is no need for it.
