Date/Time: Thu, 23 Jan 2025 05:04:18 +0000
[User Discussion] - SuperTrend Stop Alert?
View Count: 845
[2018-11-14 23:24:07] |
User344276 - Posts: 68 |
I have enabled the alert for the SuperTrend Stop indicator and I hear the sound of a bell when the indicator goes from up to down and vise versa. Is there anyway to set up a sound alert where I can hear the words "up" or "down" instead of the bell sound?
[2018-11-15 02:10:36] |
Sawtooth - Posts: 4162 |
You would need to create two .wav files and then put them in your Sierra Chart \AlertSounds folder, then assign them to two alert numbers. This also means that you'll need two separate alert formulas, one for each direction change. https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#Tab_General3 |
