Date/Time: Sun, 24 Nov 2024 13:46:58 +0000
Buffy template
View Count: 1739
[2013-11-03 20:33:12] |
User70152 - Posts: 20 |
I am a new user and using sierra charts version 1040 on windows 7 through tdameritrade. I dont see buffy template which was mentioned in this link http://www.sierrachart.com/supportboard/showthread.php?t=20336 I have downloaded buffy.stdycollct from additional files in this supportboard, placed in data folder,now study appears on analysis dropdown but gives an error message which reads below. couple indicators do work but most dont. Error loading custom studies DLL: C:\SierraChart\Data\es.dll. Windows error code 126: The specified module could not be found. | 2013-11-03 15:19:30 |
[2013-11-04 17:20:03] |
We will update the study collection to solve this.
[2013-11-05 01:48:31] |
Here is the updated Buffy study collection: http://www.sierrachart.com/AdditionalFiles/Buffy.stdycollct Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-06 00:52:38] |
still not working, error message is related to missing es.dll file in data folder. See below error message. Transact Futures: Requesting Trade positions data. | 2013-11-05 19:45:58 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-05 16:36:00. Current Date Time: 2013-11-05 16:24:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\TFZ3.scid | 2013-11-05 19:46:57 Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-05 16:38:00. Current Date Time: 2013-11-05 16:24:00. Filename: C:\SierraChart\SierraChartTransActMA\Data\TFZ3.scid | 2013-11-05 19:46:57 Error loading custom studies DLL: C:\SierraChart\SierraChartTransActMA\Data\es.dll. Windows error code 126: The specified module could not be found. | 2013-11-05 19:47:19 Error loading custom studies DLL: C:\SierraChart\SierraChartTransActMA\Data\es.dll. Windows error code 126: The specified module could not be found. | 2013-11-05 19:47:19 |
[2013-11-06 07:48:32] |
For help with the out of order timestamps messages, refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails63.html We get no errors when opening this study collection: http://www.sierrachart.com/AdditionalFiles/Buffy.stdycollct Try downloading it and saving it again. And also update to the latest prerelease with Help >> Download Prerelease. You should not need thee latest prerelease but it does do a conversion from an old DLL file name to the new one, if necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-06 07:49:01
[2013-11-06 16:14:52] |
Prerelease download worked.
