Date/Time: Thu, 23 Jan 2025 05:16:26 +0000
[User Discussion] - What Study is this?
View Count: 764
[2018-11-14 20:49:32] |
User371906 - Posts: 141 |
Hello, Can someone please tell me what study this is on the attached Renko chart. Doesn't seem to be a fractal. Yellow dot on the high/low mostly were there is a trend change, looking to find an indicator similar that plots change of trend. Thank you Regards g |
Attachment Deleted. Renko Study..JPG / V - Attached On 2018-11-14 20:43:09 UTC - Size: 108.22 KB - 1091 views |
[2018-11-16 17:23:50] |
Xfanman1 - Posts: 320 |
G, I believe I was using the Swing High/Swing Low study there. I don't use it any longer but I'm pretty sure that's what I had on there at the time of that post. -- Scott |
[2018-11-17 08:35:57] |
Scott, Once again Thank You for info. Kudos Kindly g |
