Date/Time: Fri, 24 Jan 2025 01:29:20 +0000
Trading Locked - attached Child orderes not works
View Count: 926
[2018-11-14 18:16:55] |
TedMar - Posts: 190 |
Hi, if i place an Limit (entry)order with attached orders (Child-Client) and do Trade Locked mode on. Child order are no set after Main order is filled. ;(
[2018-11-14 18:40:44] |
Yes this does make sense. You do not want to do that. Locking means that trading is locked.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-14 18:40:52
[2018-11-14 19:12:15] |
I want Locking trading for NEW orderes, but not allready pending orderes (child orderes too) If it's locked, nothing can happen to me by accident. (wrong mouse click or key..) |
[2018-12-19 23:45:06] |
Usermb - Posts: 126 |
Allowing child orders to be executed makes a lot of sense to me too, so I'd love to see this supported somehow. Could you at least give us the options to allow child orders when buy/sell limits with attached stops/targets get processed? I'd love to be able to lock trading for new orders, helps a lot with preventing mistakes, especially if somebody else is using the computer. |
[2018-12-20 04:25:58] |
Indirectly this is going to come once we put out our new TT based order routing solution.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-20 04:26:11
