Date/Time: Thu, 23 Jan 2025 04:55:49 +0000
Percentage Change Tool
View Count: 1788
[2018-11-14 16:57:17] |
skelcap - Posts: 139 |
Please can you add a tool which allows you to draw the percentage change between two arbitrary points? (not just since the close, which you currently have)
[2018-11-14 18:11:02] |
The Chart Calculator gives you this ability: Chart Drawing Tools: Chart Calculator Refer to the section for Labels >> Percent Change here: Chart Drawing Tools: Chart Calculator Configuration And make sure you disable snapping if that is enabled if it is causing a problem: Chart Drawing Tools: Automatic Snapping of Chart Drawing Ends to Open, High, Low or Close Bar Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-14 18:13:00
