Date/Time: Thu, 23 Jan 2025 05:16:13 +0000
Using Spreasheets to draw extended rectangles
View Count: 1590
[2018-11-14 11:55:07] |
phlapjack - Posts: 7 |
Support, I have looked through posts that reference the Spreadsheet study and found some older information, but without creating ACSIL custom studies is there a easy way to create a spreadsheet with multiple high and low levels that will populate a chart with an extended rectangle zones, IE 2700.00 - 2698.50
[2018-11-14 14:14:05] |
Sawtooth - Posts: 4162 |
Here is a link to an old support board thread with examples: https://www.sierrachart.com/supportboard/showthread.php?t=40825&highlight=rectangle You'll need to let the program auto-convert the spreadsheet to the new version. Note: there are significant limitations when using a spreadsheet study to do this. |
[2018-11-14 20:37:17] |
You can certainly do this by using two different formula columns for the high and low range and then use the Top and Bottom fill draw styles: Chart Studies: Subgraphs Tab >> Draw Style Or you can use ACSIL for this: Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL)) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
