Date/Time: Thu, 23 Jan 2025 05:11:04 +0000
Cherry picking data from chart file
View Count: 600
[2018-11-14 00:02:51] |
User376341 - Posts: 37 |
Hi, Using a Spreadsheet for trading that has flatten orders selected at market close. Problem is July 4 was a half-day, and using Replay, a trade that carries into next day is skewing the statistics/results. How do I remove the 4th's data, or otherwise avoid carrying that daytrade overnight, please. |
[2018-11-14 06:30:23] |
Refer to this particular setting: Chart Settings: Set Dates To Exclude (Button) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
