Date/Time: Sun, 24 Nov 2024 11:42:38 +0000
oco order question
View Count: 1221
[2013-11-03 15:56:48] |
User021827 - Posts: 174 |
I dont completely understand this error when trying to configure oco orders Trade Order Error: Parent price (95.000000) is more than 25% different than original Attached order price (9379.000000). Attached Order not modified. Internal order ID: 82 | 2013-11-03 15:54:34 how can I change the 25% setting ? thank you shane |
[2013-11-04 08:33:55] |
The percentage is not adjustable. This indicates that the order prices you have submitted are significantly off or when there was an order fill of the parent, the order price given back from the trading server is significantly off. What symbol is this for? And were all of the order prices you submitted correct? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
