Date/Time: Thu, 23 Jan 2025 05:15:25 +0000
chart prices on both axis
View Count: 594
[2018-11-13 14:46:45] |
User154308 - Posts: 7 |
where do I set the chart so that price scale is only on the right axis ?
Date Time Of Last Edit: 2018-11-13 14:47:22
[2018-11-13 18:28:01] |
Make sure this option is unchecked: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
