Date/Time: Thu, 23 Jan 2025 05:12:47 +0000
Sierra Chart not connecting says
View Count: 643
[2018-11-13 13:53:40]
User619 - Posts: 6
I thought yesterday it was because it was a holiday, but apparently, the market was still open and my Sierra Chart just wasn't working. I disconnected and reconnected, started the software up again, still no luck. Please advise.
Nick
LOGS:
Reading Internal Order ID file. | 2018-11-13 07:20:05
Reading Trade Orders file. | 2018-11-13 07:20:06
Reading Trade Positions file. | 2018-11-13 07:20:06
Listening on UDP port 22903. | 2018-11-13 07:20:06
Software version: 1733 64-bit | 2018-11-13 07:20:06
Usage end date: 2018-12-14 | 2018-11-13 07:20:06
Enabled for: Advanced Features. | 2018-11-13 07:20:06
Enabled for: Sierra Chart Historical Data Service. | 2018-11-13 07:20:06
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-11-13 07:20:06
Current selected Data/Trading service: Rithmic Trading | 2018-11-13 07:20:06
Chart Update Interval: 500 | 2018-11-13 07:20:06
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-11-13 07:20:06
2018-11-13 07:20:05 Local computer time | 2018-11-13 07:20:06
2018-11-13 13:20:05 Local computer time in UTC | 2018-11-13 07:20:06
2018-11-13 07:20:05 Local computer time in SC Time Zone | 2018-11-13 07:20:06
2018-11-13 13:19:56 Server time in UTC | 2018-11-13 07:20:06
Local computer UTC time and Server UTC time difference: 2 seconds. | 2018-11-13 07:20:06
Program path: C:\SierraChart\ | 2018-11-13 07:20:06
Data Files path: C:\SierraChart\Data\ | 2018-11-13 07:20:06
OS Version Number: 10.0 | 2018-11-13 07:20:06
Locale Setting: C | 2018-11-13 07:20:06
Checking for new symbol settings for service code rithmic.trading | 2018-11-13 07:20:06
HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-13 07:20:06
HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-11-13 07:20:06
Received 5 login tokens. | 2018-11-13 07:20:06
Symbol settings are up-to-date for rithmic.trading | 2018-11-13 07:20:07
HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-11-13 07:20:08
HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-11-13 07:20:08
Rithmic Trading | Port for executable: 59807 | 2018-11-13 07:20:11
Listening socket (1096). Port 59807 | Closed. | 2018-11-13 07:20:11
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:11
HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-13 07:20:11
HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-13 07:20:11
HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-11-13 07:20:11
HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-13 07:20:11
HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-11-13 07:20:11
HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-13 07:20:12
HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-11-13 07:20:12
HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-11-13 07:20:12
HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-13 07:20:12
HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-11-13 07:20:12
HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-11-13 07:20:13
HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-11-13 07:20:13
HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-11-13 07:20:13
HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-13 07:20:13
HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-11-13 07:20:13
Rithmic Trading | Bridge process is running. | 2018-11-13 07:20:13
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59807 | 2018-11-13 07:20:13
DTC Client socket (6) | Creating socket. | 2018-11-13 07:20:13
DTC Client socket (6) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:13
DTC Client socket (6) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:20:14 *
DTC Client socket (6) | Initiating close of socket by core. | 2018-11-13 07:20:14
DTC Client socket (6) | Closed. | 2018-11-13 07:20:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:14
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:14
Rithmic Trading | Disconnected. | 2018-11-13 07:20:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:14
Rithmic Trading | Port for executable: 59814 | 2018-11-13 07:20:16
Listening socket (1224). Port 59814 | Closed. | 2018-11-13 07:20:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:16
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:20:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59814 | 2018-11-13 07:20:19
DTC Client socket (7) | Creating socket. | 2018-11-13 07:20:19
DTC Client socket (7) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:19
DTC Client socket (7) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:20:20 *
DTC Client socket (7) | Initiating close of socket by core. | 2018-11-13 07:20:20
DTC Client socket (7) | Closed. | 2018-11-13 07:20:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:20
Rithmic Trading | Disconnected. | 2018-11-13 07:20:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:20
Rithmic Trading | Port for executable: 59835 | 2018-11-13 07:20:22
Listening socket (648). Port 59835 | Closed. | 2018-11-13 07:20:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:22
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:20:24
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59835 | 2018-11-13 07:20:24
DTC Client socket (8) | Creating socket. | 2018-11-13 07:20:24
DTC Client socket (8) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:24
DTC Client socket (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:20:25 *
DTC Client socket (8) | Initiating close of socket by core. | 2018-11-13 07:20:25
DTC Client socket (8) | Closed. | 2018-11-13 07:20:25
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:25
Rithmic Trading | Disconnected. | 2018-11-13 07:20:25
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:25
Rithmic Trading | Port for executable: 59864 | 2018-11-13 07:20:27
Listening socket (1256). Port 59864 | Closed. | 2018-11-13 07:20:27
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:27
Rithmic Trading | Bridge process is running. | 2018-11-13 07:20:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59864 | 2018-11-13 07:20:29
DTC Client socket (9) | Creating socket. | 2018-11-13 07:20:29
DTC Client socket (9) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:29
Rithmic Trading | Connected to server. | 2018-11-13 07:20:29
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:20:29
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:20:29
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:20:29
Rithmic Trading | Sending logon request message. | 2018-11-13 07:20:29
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:20:29
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:20:29
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:20:29
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:20:30
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:20:30
Rithmic Trading | Received logon response. | 2018-11-13 07:20:30
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:20:30
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:20:30
Rithmic Trading | Logon error received from server | 2018-11-13 07:20:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:30
DTC Client socket (9) | Initiating close of socket by core. | 2018-11-13 07:20:30
DTC Client socket (9) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:20:30
Rithmic Trading | Disconnected. | 2018-11-13 07:20:30
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:30
Rithmic Trading | Port for executable: 59882 | 2018-11-13 07:20:32
Listening socket (1232). Port 59882 | Closed. | 2018-11-13 07:20:32
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:32
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:20:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59882 | 2018-11-13 07:20:34
DTC Client socket (10) | Creating socket. | 2018-11-13 07:20:34
DTC Client socket (10) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:34
DTC Client socket (10) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:20:35 *
DTC Client socket (10) | Initiating close of socket by core. | 2018-11-13 07:20:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:35
DTC Client socket (10) | Closed. | 2018-11-13 07:20:35
Rithmic Trading | Disconnected. | 2018-11-13 07:20:35
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:35
Rithmic Trading | Port for executable: 59885 | 2018-11-13 07:20:37
Listening socket (1232). Port 59885 | Closed. | 2018-11-13 07:20:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:37
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:20:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59885 | 2018-11-13 07:20:39
DTC Client socket (11) | Creating socket. | 2018-11-13 07:20:39
DTC Client socket (11) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:39
DTC Client socket (11) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:20:40 *
DTC Client socket (11) | Initiating close of socket by core. | 2018-11-13 07:20:40
DTC Client socket (11) | Closed. | 2018-11-13 07:20:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:40
Rithmic Trading | Disconnected. | 2018-11-13 07:20:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:40
Rithmic Trading | Port for executable: 59889 | 2018-11-13 07:20:42
Listening socket (1232). Port 59889 | Closed. | 2018-11-13 07:20:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:42
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:20:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59889 | 2018-11-13 07:20:44
DTC Client socket (12) | Creating socket. | 2018-11-13 07:20:44
DTC Client socket (12) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:44
DTC Client socket (12) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:20:45 *
DTC Client socket (12) | Initiating close of socket by core. | 2018-11-13 07:20:45
DTC Client socket (12) | Closed. | 2018-11-13 07:20:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:45
Rithmic Trading | Disconnected. | 2018-11-13 07:20:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:45
Rithmic Trading | Port for executable: 59893 | 2018-11-13 07:20:47
Listening socket (1096). Port 59893 | Closed. | 2018-11-13 07:20:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:47
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:20:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59893 | 2018-11-13 07:20:49
DTC Client socket (13) | Creating socket. | 2018-11-13 07:20:49
DTC Client socket (13) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:49
DTC Client socket (13) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:20:50 *
DTC Client socket (13) | Initiating close of socket by core. | 2018-11-13 07:20:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:50
DTC Client socket (13) | Closed. | 2018-11-13 07:20:50
Rithmic Trading | Disconnected. | 2018-11-13 07:20:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:50
DTC Client socket (9) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:20:52 *
DTC Client socket (9) | Socket gracefully closed by remote side. | 2018-11-13 07:20:52
DTC Client socket (9) | Closed. | 2018-11-13 07:20:52
Rithmic Trading | Port for executable: 59897 | 2018-11-13 07:20:52
Listening socket (1052). Port 59897 | Closed. | 2018-11-13 07:20:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:52
Rithmic Trading | Bridge process is running. | 2018-11-13 07:20:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59897 | 2018-11-13 07:20:54
DTC Client socket (14) | Creating socket. | 2018-11-13 07:20:54
DTC Client socket (14) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:54
Rithmic Trading | Connected to server. | 2018-11-13 07:20:54
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:20:54
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:20:54
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:20:54
Rithmic Trading | Sending logon request message. | 2018-11-13 07:20:54
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:20:54
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:20:54
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:20:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:20:55
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:20:55
Rithmic Trading | Received logon response. | 2018-11-13 07:20:55
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:20:55
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:20:55
Rithmic Trading | Logon error received from server | 2018-11-13 07:20:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:20:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:55
DTC Client socket (14) | Initiating close of socket by core. | 2018-11-13 07:20:55
DTC Client socket (14) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:20:55
Rithmic Trading | Disconnected. | 2018-11-13 07:20:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:20:55
Rithmic Trading | Port for executable: 59912 | 2018-11-13 07:20:57
Listening socket (1096). Port 59912 | Closed. | 2018-11-13 07:20:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:20:57
DTC Client socket (14) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:20:57 *
DTC Client socket (14) | Socket gracefully closed by remote side. | 2018-11-13 07:20:57
DTC Client socket (14) | Closed. | 2018-11-13 07:20:57
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:20:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59912 | 2018-11-13 07:20:59
DTC Client socket (16) | Creating socket. | 2018-11-13 07:20:59
DTC Client socket (16) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:20:59
DTC Client socket (16) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:21:00 *
DTC Client socket (16) | Initiating close of socket by core. | 2018-11-13 07:21:00
DTC Client socket (16) | Closed. | 2018-11-13 07:21:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:00
Rithmic Trading | Disconnected. | 2018-11-13 07:21:00
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:00
Rithmic Trading | Port for executable: 59918 | 2018-11-13 07:21:02
Listening socket (1292). Port 59918 | Closed. | 2018-11-13 07:21:02
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:02
Rithmic Trading | Bridge process is running. | 2018-11-13 07:21:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59918 | 2018-11-13 07:21:04
DTC Client socket (17) | Creating socket. | 2018-11-13 07:21:04
DTC Client socket (17) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:04
Rithmic Trading | Connected to server. | 2018-11-13 07:21:04
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:21:04
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:21:04
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:21:04
Rithmic Trading | Sending logon request message. | 2018-11-13 07:21:04
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:21:04
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:21:04
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:21:04
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:21:05
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:21:05
Rithmic Trading | Received logon response. | 2018-11-13 07:21:05
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:21:05
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:21:05
Rithmic Trading | Logon error received from server | 2018-11-13 07:21:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:05
DTC Client socket (17) | Initiating close of socket by core. | 2018-11-13 07:21:05
DTC Client socket (17) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:21:05
Rithmic Trading | Disconnected. | 2018-11-13 07:21:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:05
Rithmic Trading | Port for executable: 59928 | 2018-11-13 07:21:07
Listening socket (1296). Port 59928 | Closed. | 2018-11-13 07:21:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:07
DTC Client socket (17) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:21:07 *
DTC Client socket (17) | Socket gracefully closed by remote side. | 2018-11-13 07:21:07
DTC Client socket (17) | Closed. | 2018-11-13 07:21:07
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:21:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59928 | 2018-11-13 07:21:09
DTC Client socket (18) | Creating socket. | 2018-11-13 07:21:09
DTC Client socket (18) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:09
DTC Client socket (18) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:21:10 *
DTC Client socket (18) | Initiating close of socket by core. | 2018-11-13 07:21:10
DTC Client socket (18) | Closed. | 2018-11-13 07:21:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:10
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:10
Rithmic Trading | Disconnected. | 2018-11-13 07:21:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:10
Rithmic Trading | Port for executable: 59932 | 2018-11-13 07:21:12
Listening socket (1304). Port 59932 | Closed. | 2018-11-13 07:21:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:12
Rithmic Trading | Bridge process is running. | 2018-11-13 07:21:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59932 | 2018-11-13 07:21:14
DTC Client socket (19) | Creating socket. | 2018-11-13 07:21:14
DTC Client socket (19) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:14
Rithmic Trading | Connected to server. | 2018-11-13 07:21:14
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:21:14
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:21:14
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:21:14
Rithmic Trading | Sending logon request message. | 2018-11-13 07:21:14
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:21:14
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:21:14
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:21:14
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:21:14
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:21:14
Rithmic Trading | Received logon response. | 2018-11-13 07:21:14
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:21:14
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:21:14
Rithmic Trading | Logon error received from server | 2018-11-13 07:21:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:14
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:14
DTC Client socket (19) | Initiating close of socket by core. | 2018-11-13 07:21:14
Rithmic Trading | Disconnected. | 2018-11-13 07:21:14
DTC Client socket (19) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:21:14
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:14
Rithmic Trading | Port for executable: 59946 | 2018-11-13 07:21:16
Listening socket (1096). Port 59946 | Closed. | 2018-11-13 07:21:16
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:16
DTC Client socket (19) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:21:17 *
DTC Client socket (19) | Socket gracefully closed by remote side. | 2018-11-13 07:21:17
DTC Client socket (19) | Closed. | 2018-11-13 07:21:17
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:21:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59946 | 2018-11-13 07:21:19
DTC Client socket (20) | Creating socket. | 2018-11-13 07:21:19
DTC Client socket (20) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:19
DTC Client socket (20) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:21:20 *
DTC Client socket (20) | Initiating close of socket by core. | 2018-11-13 07:21:20
DTC Client socket (20) | Closed. | 2018-11-13 07:21:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:20
Rithmic Trading | Disconnected. | 2018-11-13 07:21:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:20
Rithmic Trading | Port for executable: 59952 | 2018-11-13 07:21:22
Listening socket (1276). Port 59952 | Closed. | 2018-11-13 07:21:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:22
Rithmic Trading | Bridge process is running. | 2018-11-13 07:21:24
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59952 | 2018-11-13 07:21:24
DTC Client socket (21) | Creating socket. | 2018-11-13 07:21:24
DTC Client socket (21) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:24
Rithmic Trading | Connected to server. | 2018-11-13 07:21:24
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:21:24
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:21:24
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:21:24
Rithmic Trading | Sending logon request message. | 2018-11-13 07:21:24
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:21:24
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:21:24
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:21:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:21:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:21:24
Rithmic Trading | Received logon response. | 2018-11-13 07:21:24
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:21:24
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:21:24
Rithmic Trading | Logon error received from server | 2018-11-13 07:21:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:24
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:24
DTC Client socket (21) | Initiating close of socket by core. | 2018-11-13 07:21:24
DTC Client socket (21) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:21:24
Rithmic Trading | Disconnected. | 2018-11-13 07:21:24
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:24
Rithmic Trading | Port for executable: 59965 | 2018-11-13 07:21:26
Listening socket (1308). Port 59965 | Closed. | 2018-11-13 07:21:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:26
DTC Client socket (21) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:21:27 *
DTC Client socket (21) | Socket gracefully closed by remote side. | 2018-11-13 07:21:27
DTC Client socket (21) | Closed. | 2018-11-13 07:21:27
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:21:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59965 | 2018-11-13 07:21:28
DTC Client socket (22) | Creating socket. | 2018-11-13 07:21:28
DTC Client socket (22) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:28
DTC Client socket (22) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:21:29 *
DTC Client socket (22) | Initiating close of socket by core. | 2018-11-13 07:21:29
DTC Client socket (22) | Closed. | 2018-11-13 07:21:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:29
Rithmic Trading | Disconnected. | 2018-11-13 07:21:29
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:29
Rithmic Trading | Port for executable: 59969 | 2018-11-13 07:21:31
Listening socket (1096). Port 59969 | Closed. | 2018-11-13 07:21:31
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:31
Rithmic Trading | Bridge process is running. | 2018-11-13 07:21:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59969 | 2018-11-13 07:21:33
DTC Client socket (23) | Creating socket. | 2018-11-13 07:21:33
DTC Client socket (23) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:33
Rithmic Trading | Connected to server. | 2018-11-13 07:21:33
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:21:33
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:21:33
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:21:33
Rithmic Trading | Sending logon request message. | 2018-11-13 07:21:33
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:21:33
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:21:33
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:21:33
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:21:34
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:21:34
Rithmic Trading | Received logon response. | 2018-11-13 07:21:34
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:21:34
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:21:34
Rithmic Trading | Logon error received from server | 2018-11-13 07:21:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:34
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:34
DTC Client socket (23) | Initiating close of socket by core. | 2018-11-13 07:21:34
DTC Client socket (23) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:21:34
Rithmic Trading | Disconnected. | 2018-11-13 07:21:34
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:34
Rithmic Trading | Port for executable: 59984 | 2018-11-13 07:21:36
Listening socket (1328). Port 59984 | Closed. | 2018-11-13 07:21:36
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:36
DTC Client socket (23) | Socket gracefully closed by remote side. | 2018-11-13 07:21:36
DTC Client socket (23) | Closed. | 2018-11-13 07:21:36
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:21:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 59984 | 2018-11-13 07:21:38
DTC Client socket (24) | Creating socket. | 2018-11-13 07:21:38
DTC Client socket (24) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:38
DTC Client socket (24) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:21:39 *
DTC Client socket (24) | Initiating close of socket by core. | 2018-11-13 07:21:39
DTC Client socket (24) | Closed. | 2018-11-13 07:21:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:39
Rithmic Trading | Disconnected. | 2018-11-13 07:21:39
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:39
Rithmic Trading | Port for executable: 60003 | 2018-11-13 07:21:41
Listening socket (1284). Port 60003 | Closed. | 2018-11-13 07:21:41
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:41
Rithmic Trading | Bridge process is running. | 2018-11-13 07:21:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60003 | 2018-11-13 07:21:43
DTC Client socket (25) | Creating socket. | 2018-11-13 07:21:43
DTC Client socket (25) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:43
Rithmic Trading | Connected to server. | 2018-11-13 07:21:43
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:21:43
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:21:43
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:21:43
Rithmic Trading | Sending logon request message. | 2018-11-13 07:21:43
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:21:43
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:21:43
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:21:43
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:21:44
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:21:44
Rithmic Trading | Received logon response. | 2018-11-13 07:21:44
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:21:44
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:21:44
Rithmic Trading | Logon error received from server | 2018-11-13 07:21:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:44
DTC Client socket (25) | Initiating close of socket by core. | 2018-11-13 07:21:44
DTC Client socket (25) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:21:44
Rithmic Trading | Disconnected. | 2018-11-13 07:21:44
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:44
Rithmic Trading | Port for executable: 60017 | 2018-11-13 07:21:46
Listening socket (1316). Port 60017 | Closed. | 2018-11-13 07:21:46
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:46
DTC Client socket (25) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:21:46 *
DTC Client socket (25) | Socket gracefully closed by remote side. | 2018-11-13 07:21:46
DTC Client socket (25) | Closed. | 2018-11-13 07:21:46
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:21:48
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60017 | 2018-11-13 07:21:48
DTC Client socket (26) | Creating socket. | 2018-11-13 07:21:48
DTC Client socket (26) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:48
DTC Client socket (26) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:21:49 *
DTC Client socket (26) | Initiating close of socket by core. | 2018-11-13 07:21:49
DTC Client socket (26) | Closed. | 2018-11-13 07:21:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:49
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:49
Rithmic Trading | Disconnected. | 2018-11-13 07:21:49
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:49
Rithmic Trading | Port for executable: 60020 | 2018-11-13 07:21:51
Listening socket (1332). Port 60020 | Closed. | 2018-11-13 07:21:51
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:51
Rithmic Trading | Bridge process is running. | 2018-11-13 07:21:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60020 | 2018-11-13 07:21:53
DTC Client socket (27) | Creating socket. | 2018-11-13 07:21:53
DTC Client socket (27) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:53
Rithmic Trading | Connected to server. | 2018-11-13 07:21:53
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:21:53
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:21:53
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:21:53
Rithmic Trading | Sending logon request message. | 2018-11-13 07:21:53
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:21:53
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:21:53
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:21:53
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:21:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:21:54
Rithmic Trading | Received logon response. | 2018-11-13 07:21:54
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:21:54
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:21:54
Rithmic Trading | Logon error received from server | 2018-11-13 07:21:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:54
DTC Client socket (27) | Initiating close of socket by core. | 2018-11-13 07:21:54
Rithmic Trading | Disconnected. | 2018-11-13 07:21:54
DTC Client socket (27) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:21:54
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:54
Rithmic Trading | Port for executable: 60034 | 2018-11-13 07:21:56
Listening socket (1320). Port 60034 | Closed. | 2018-11-13 07:21:56
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:21:56
DTC Client socket (27) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:21:56 *
DTC Client socket (27) | Socket gracefully closed by remote side. | 2018-11-13 07:21:56
DTC Client socket (27) | Closed. | 2018-11-13 07:21:56
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:21:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60034 | 2018-11-13 07:21:58
DTC Client socket (28) | Creating socket. | 2018-11-13 07:21:58
DTC Client socket (28) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:21:58
DTC Client socket (28) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:21:59 *
DTC Client socket (28) | Initiating close of socket by core. | 2018-11-13 07:21:59
DTC Client socket (28) | Closed. | 2018-11-13 07:21:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:21:59
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:59
Rithmic Trading | Disconnected. | 2018-11-13 07:21:59
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:21:59
Rithmic Trading | Port for executable: 60039 | 2018-11-13 07:22:01
Listening socket (1304). Port 60039 | Closed. | 2018-11-13 07:22:01
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:01
Rithmic Trading | Bridge process is running. | 2018-11-13 07:22:03
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60039 | 2018-11-13 07:22:03
DTC Client socket (30) | Creating socket. | 2018-11-13 07:22:03
DTC Client socket (30) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:03
Rithmic Trading | Connected to server. | 2018-11-13 07:22:03
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:22:03
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:22:03
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:22:03
Rithmic Trading | Sending logon request message. | 2018-11-13 07:22:03
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:22:03
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:22:03
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:22:03
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:22:03
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:22:03
Rithmic Trading | Received logon response. | 2018-11-13 07:22:03
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:22:03
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:22:03
Rithmic Trading | Logon error received from server | 2018-11-13 07:22:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:03
DTC Client socket (30) | Initiating close of socket by core. | 2018-11-13 07:22:03
DTC Client socket (30) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:22:03
Rithmic Trading | Disconnected. | 2018-11-13 07:22:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:03
Rithmic Trading | Port for executable: 60049 | 2018-11-13 07:22:05
Listening socket (1332). Port 60049 | Closed. | 2018-11-13 07:22:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:05
DTC Client socket (30) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:22:06 *
DTC Client socket (30) | Socket gracefully closed by remote side. | 2018-11-13 07:22:06
DTC Client socket (30) | Closed. | 2018-11-13 07:22:06
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:22:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60049 | 2018-11-13 07:22:07
DTC Client socket (31) | Creating socket. | 2018-11-13 07:22:07
DTC Client socket (31) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:07
DTC Client socket (31) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:22:08 *
DTC Client socket (31) | Initiating close of socket by core. | 2018-11-13 07:22:08
DTC Client socket (31) | Closed. | 2018-11-13 07:22:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:08
Rithmic Trading | Disconnected. | 2018-11-13 07:22:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:08
Rithmic Trading | Port for executable: 60052 | 2018-11-13 07:22:10
Listening socket (1332). Port 60052 | Closed. | 2018-11-13 07:22:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:10
Rithmic Trading | Bridge process is running. | 2018-11-13 07:22:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60052 | 2018-11-13 07:22:12
DTC Client socket (32) | Creating socket. | 2018-11-13 07:22:12
DTC Client socket (32) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:12
Rithmic Trading | Connected to server. | 2018-11-13 07:22:12
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:22:12
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:22:12
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:22:12
Rithmic Trading | Sending logon request message. | 2018-11-13 07:22:12
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:22:12
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:22:12
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:22:12
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:22:13
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:22:13
Rithmic Trading | Received logon response. | 2018-11-13 07:22:13
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:22:13
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:22:13
Rithmic Trading | Logon error received from server | 2018-11-13 07:22:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:13
DTC Client socket (32) | Initiating close of socket by core. | 2018-11-13 07:22:13
DTC Client socket (32) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:22:13
Rithmic Trading | Disconnected. | 2018-11-13 07:22:13
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:13
Rithmic Trading | Port for executable: 60073 | 2018-11-13 07:22:15
Listening socket (1312). Port 60073 | Closed. | 2018-11-13 07:22:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:15
DTC Client socket (32) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:22:16 *
DTC Client socket (32) | Socket gracefully closed by remote side. | 2018-11-13 07:22:16
DTC Client socket (32) | Closed. | 2018-11-13 07:22:16
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:22:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60073 | 2018-11-13 07:22:17
DTC Client socket (33) | Creating socket. | 2018-11-13 07:22:17
DTC Client socket (33) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:17
DTC Client socket (33) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:22:18 *
DTC Client socket (33) | Initiating close of socket by core. | 2018-11-13 07:22:18
DTC Client socket (33) | Closed. | 2018-11-13 07:22:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:18
Rithmic Trading | Disconnected. | 2018-11-13 07:22:18
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:18
Rithmic Trading | Port for executable: 60075 | 2018-11-13 07:22:20
Listening socket (1332). Port 60075 | Closed. | 2018-11-13 07:22:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:20
Rithmic Trading | Bridge process is running. | 2018-11-13 07:22:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60075 | 2018-11-13 07:22:22
DTC Client socket (34) | Creating socket. | 2018-11-13 07:22:22
DTC Client socket (34) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:22
Rithmic Trading | Connected to server. | 2018-11-13 07:22:22
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:22:22
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:22:22
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:22:22
Rithmic Trading | Sending logon request message. | 2018-11-13 07:22:22
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:22:22
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:22:22
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:22:22
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:22:23
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:22:23
Rithmic Trading | Received logon response. | 2018-11-13 07:22:23
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:22:23
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:22:23
Rithmic Trading | Logon error received from server | 2018-11-13 07:22:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:23
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:23
DTC Client socket (34) | Initiating close of socket by core. | 2018-11-13 07:22:23
DTC Client socket (34) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:22:23
Rithmic Trading | Disconnected. | 2018-11-13 07:22:23
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:23
Rithmic Trading | Port for executable: 60085 | 2018-11-13 07:22:25
Listening socket (1312). Port 60085 | Closed. | 2018-11-13 07:22:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:25
DTC Client socket (34) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:22:26 *
DTC Client socket (34) | Socket gracefully closed by remote side. | 2018-11-13 07:22:26
DTC Client socket (34) | Closed. | 2018-11-13 07:22:26
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:22:27
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60085 | 2018-11-13 07:22:27
DTC Client socket (35) | Creating socket. | 2018-11-13 07:22:27
DTC Client socket (35) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:27
DTC Client socket (35) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:22:28 *
DTC Client socket (35) | Initiating close of socket by core. | 2018-11-13 07:22:28
DTC Client socket (35) | Closed. | 2018-11-13 07:22:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:28
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:28
Rithmic Trading | Disconnected. | 2018-11-13 07:22:28
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:28
Rithmic Trading | Port for executable: 60087 | 2018-11-13 07:22:30
Listening socket (1340). Port 60087 | Closed. | 2018-11-13 07:22:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:30
Rithmic Trading | Bridge process is running. | 2018-11-13 07:22:32
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60087 | 2018-11-13 07:22:32
DTC Client socket (36) | Creating socket. | 2018-11-13 07:22:32
DTC Client socket (36) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:32
Rithmic Trading | Connected to server. | 2018-11-13 07:22:32
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:22:32
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:22:32
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:22:32
Rithmic Trading | Sending logon request message. | 2018-11-13 07:22:32
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:22:32
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:22:32
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:22:32
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:22:33
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:22:33
Rithmic Trading | Received logon response. | 2018-11-13 07:22:33
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:22:33
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:22:33
Rithmic Trading | Logon error received from server | 2018-11-13 07:22:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:33
DTC Client socket (36) | Initiating close of socket by core. | 2018-11-13 07:22:33
DTC Client socket (36) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:22:33
Rithmic Trading | Disconnected. | 2018-11-13 07:22:33
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:33
Rithmic Trading | Port for executable: 60097 | 2018-11-13 07:22:35
Listening socket (1376). Port 60097 | Closed. | 2018-11-13 07:22:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:35
DTC Client socket (36) | Socket gracefully closed by remote side. | 2018-11-13 07:22:35
DTC Client socket (36) | Closed. | 2018-11-13 07:22:35
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:22:37
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60097 | 2018-11-13 07:22:37
DTC Client socket (37) | Creating socket. | 2018-11-13 07:22:37
DTC Client socket (37) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:37
DTC Client socket (37) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:22:38 *
DTC Client socket (37) | Initiating close of socket by core. | 2018-11-13 07:22:38
DTC Client socket (37) | Closed. | 2018-11-13 07:22:38
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:38
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:38
Rithmic Trading | Disconnected. | 2018-11-13 07:22:38
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:38
Rithmic Trading | Port for executable: 60104 | 2018-11-13 07:22:40
Listening socket (1332). Port 60104 | Closed. | 2018-11-13 07:22:40
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:40
Rithmic Trading | Bridge process is running. | 2018-11-13 07:22:42
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60104 | 2018-11-13 07:22:42
DTC Client socket (38) | Creating socket. | 2018-11-13 07:22:42
DTC Client socket (38) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:42
Rithmic Trading | Connected to server. | 2018-11-13 07:22:42
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:22:42
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:22:42
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:22:42
Rithmic Trading | Sending logon request message. | 2018-11-13 07:22:42
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:22:42
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:22:42
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:22:42
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:22:43
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:22:43
Rithmic Trading | Received logon response. | 2018-11-13 07:22:43
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:22:43
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:22:43
Rithmic Trading | Logon error received from server | 2018-11-13 07:22:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:43
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:43
DTC Client socket (38) | Initiating close of socket by core. | 2018-11-13 07:22:43
DTC Client socket (38) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:22:43
Rithmic Trading | Disconnected. | 2018-11-13 07:22:43
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:43
Rithmic Trading | Port for executable: 60117 | 2018-11-13 07:22:45
Listening socket (1368). Port 60117 | Closed. | 2018-11-13 07:22:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:45
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:22:47
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60117 | 2018-11-13 07:22:47
DTC Client socket (39) | Creating socket. | 2018-11-13 07:22:47
DTC Client socket (39) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:47
DTC Client socket (39) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:22:48 *
DTC Client socket (39) | Initiating close of socket by core. | 2018-11-13 07:22:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:48
DTC Client socket (39) | Closed. | 2018-11-13 07:22:48
Rithmic Trading | Disconnected. | 2018-11-13 07:22:48
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:48
Rithmic Trading | Port for executable: 60122 | 2018-11-13 07:22:50
Listening socket (1300). Port 60122 | Closed. | 2018-11-13 07:22:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:50
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:22:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60122 | 2018-11-13 07:22:52
DTC Client socket (40) | Creating socket. | 2018-11-13 07:22:52
DTC Client socket (40) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:52
DTC Client socket (40) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:22:53 *
DTC Client socket (40) | Initiating close of socket by core. | 2018-11-13 07:22:53
DTC Client socket (40) | Closed. | 2018-11-13 07:22:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:53
Rithmic Trading | Disconnected. | 2018-11-13 07:22:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:53
Rithmic Trading | Port for executable: 60124 | 2018-11-13 07:22:55
Listening socket (1356). Port 60124 | Closed. | 2018-11-13 07:22:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:22:55
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:22:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60124 | 2018-11-13 07:22:57
DTC Client socket (41) | Creating socket. | 2018-11-13 07:22:57
DTC Client socket (41) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:22:57
DTC Client socket (41) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:22:58 *
DTC Client socket (41) | Initiating close of socket by core. | 2018-11-13 07:22:58
DTC Client socket (41) | Closed. | 2018-11-13 07:22:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:22:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:58
Rithmic Trading | Disconnected. | 2018-11-13 07:22:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:22:58
Rithmic Trading | Port for executable: 60131 | 2018-11-13 07:23:00
Listening socket (1312). Port 60131 | Closed. | 2018-11-13 07:23:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:00
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:23:02
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60131 | 2018-11-13 07:23:02
DTC Client socket (43) | Creating socket. | 2018-11-13 07:23:02
DTC Client socket (43) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:02
DTC Client socket (43) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:23:03 *
DTC Client socket (43) | Initiating close of socket by core. | 2018-11-13 07:23:03
DTC Client socket (43) | Closed. | 2018-11-13 07:23:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:03
Rithmic Trading | Disconnected. | 2018-11-13 07:23:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:03
DTC Client socket (38) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:23:05 *
DTC Client socket (38) | Socket gracefully closed by remote side. | 2018-11-13 07:23:05
DTC Client socket (38) | Closed. | 2018-11-13 07:23:05
Rithmic Trading | Port for executable: 60134 | 2018-11-13 07:23:05
Listening socket (1340). Port 60134 | Closed. | 2018-11-13 07:23:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:05
Rithmic Trading | Bridge process is running. | 2018-11-13 07:23:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60134 | 2018-11-13 07:23:07
DTC Client socket (44) | Creating socket. | 2018-11-13 07:23:07
DTC Client socket (44) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:07
Rithmic Trading | Connected to server. | 2018-11-13 07:23:07
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:23:07
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:23:07
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:23:07
Rithmic Trading | Sending logon request message. | 2018-11-13 07:23:07
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:23:07
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:23:07
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:23:07
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:23:08
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:23:08
Rithmic Trading | Received logon response. | 2018-11-13 07:23:08
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:23:08
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:23:08
Rithmic Trading | Logon error received from server | 2018-11-13 07:23:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:08
DTC Client socket (44) | Initiating close of socket by core. | 2018-11-13 07:23:08
DTC Client socket (44) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:23:08
Rithmic Trading | Disconnected. | 2018-11-13 07:23:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:08
Rithmic Trading | Port for executable: 60144 | 2018-11-13 07:23:10
Listening socket (1360). Port 60144 | Closed. | 2018-11-13 07:23:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:10
DTC Client socket (44) | Socket gracefully closed by remote side. | 2018-11-13 07:23:11
DTC Client socket (44) | Closed. | 2018-11-13 07:23:11
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:23:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60144 | 2018-11-13 07:23:12
DTC Client socket (45) | Creating socket. | 2018-11-13 07:23:12
DTC Client socket (45) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:12
DTC Client socket (45) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:23:13 *
DTC Client socket (45) | Initiating close of socket by core. | 2018-11-13 07:23:13
DTC Client socket (45) | Closed. | 2018-11-13 07:23:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:13
Rithmic Trading | Disconnected. | 2018-11-13 07:23:13
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:13
Rithmic Trading | Port for executable: 60147 | 2018-11-13 07:23:15
Listening socket (1356). Port 60147 | Closed. | 2018-11-13 07:23:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:15
Rithmic Trading | Bridge process is running. | 2018-11-13 07:23:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60147 | 2018-11-13 07:23:17
DTC Client socket (46) | Creating socket. | 2018-11-13 07:23:17
DTC Client socket (46) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:17
Rithmic Trading | Connected to server. | 2018-11-13 07:23:17
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:23:17
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:23:17
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:23:17
Rithmic Trading | Sending logon request message. | 2018-11-13 07:23:17
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:23:17
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:23:17
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:23:17
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:23:18
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:23:18
Rithmic Trading | Received logon response. | 2018-11-13 07:23:18
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:23:18
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:23:18
Rithmic Trading | Logon error received from server | 2018-11-13 07:23:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:18
DTC Client socket (46) | Initiating close of socket by core. | 2018-11-13 07:23:18
Rithmic Trading | Disconnected. | 2018-11-13 07:23:18
DTC Client socket (46) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:23:18
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:18
Rithmic Trading | Port for executable: 60158 | 2018-11-13 07:23:20
Listening socket (1340). Port 60158 | Closed. | 2018-11-13 07:23:20
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:20
DTC Client socket (46) | Socket gracefully closed by remote side. | 2018-11-13 07:23:20
DTC Client socket (46) | Closed. | 2018-11-13 07:23:20
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:23:22
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60158 | 2018-11-13 07:23:22
DTC Client socket (47) | Creating socket. | 2018-11-13 07:23:22
DTC Client socket (47) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:22
DTC Client socket (47) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:23:23 *
DTC Client socket (47) | Initiating close of socket by core. | 2018-11-13 07:23:23
DTC Client socket (47) | Closed. | 2018-11-13 07:23:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:23
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:23
Rithmic Trading | Disconnected. | 2018-11-13 07:23:23
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:23
Rithmic Trading | Port for executable: 60166 | 2018-11-13 07:23:25
Listening socket (1300). Port 60166 | Closed. | 2018-11-13 07:23:25
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:25
Rithmic Trading | Bridge process is running. | 2018-11-13 07:23:27
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60166 | 2018-11-13 07:23:27
DTC Client socket (48) | Creating socket. | 2018-11-13 07:23:27
DTC Client socket (48) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:27
Rithmic Trading | Connected to server. | 2018-11-13 07:23:27
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:23:27
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:23:27
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:23:27
Rithmic Trading | Sending logon request message. | 2018-11-13 07:23:27
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:23:27
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:23:27
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:23:27
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:23:28
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:23:28
Rithmic Trading | Received logon response. | 2018-11-13 07:23:28
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:23:28
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:23:28
Rithmic Trading | Logon error received from server | 2018-11-13 07:23:28
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:28
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:28
DTC Client socket (48) | Initiating close of socket by core. | 2018-11-13 07:23:28
DTC Client socket (48) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:23:28
Rithmic Trading | Disconnected. | 2018-11-13 07:23:28
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:28
Rithmic Trading | Port for executable: 60177 | 2018-11-13 07:23:30
Listening socket (1304). Port 60177 | Closed. | 2018-11-13 07:23:30
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:30
DTC Client socket (48) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:23:30 *
DTC Client socket (48) | Socket gracefully closed by remote side. | 2018-11-13 07:23:30
DTC Client socket (48) | Closed. | 2018-11-13 07:23:30
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:23:32
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60177 | 2018-11-13 07:23:32
DTC Client socket (49) | Creating socket. | 2018-11-13 07:23:32
DTC Client socket (49) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:32
DTC Client socket (49) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:23:33 *
DTC Client socket (49) | Initiating close of socket by core. | 2018-11-13 07:23:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:33
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:33
DTC Client socket (49) | Closed. | 2018-11-13 07:23:33
Rithmic Trading | Disconnected. | 2018-11-13 07:23:33
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:33
Rithmic Trading | Port for executable: 60179 | 2018-11-13 07:23:35
Listening socket (1372). Port 60179 | Closed. | 2018-11-13 07:23:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:35
Rithmic Trading | Bridge process is running. | 2018-11-13 07:23:37
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60179 | 2018-11-13 07:23:37
DTC Client socket (50) | Creating socket. | 2018-11-13 07:23:37
DTC Client socket (50) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:37
Rithmic Trading | Connected to server. | 2018-11-13 07:23:37
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:23:37
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:23:37
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:23:37
Rithmic Trading | Sending logon request message. | 2018-11-13 07:23:37
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:23:37
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:23:37
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:23:37
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:23:37
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:23:37
Rithmic Trading | Received logon response. | 2018-11-13 07:23:37
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:23:37
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:23:37
Rithmic Trading | Logon error received from server | 2018-11-13 07:23:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:37
DTC Client socket (50) | Initiating close of socket by core. | 2018-11-13 07:23:37
DTC Client socket (50) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:23:37
Rithmic Trading | Disconnected. | 2018-11-13 07:23:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:37
Rithmic Trading | Port for executable: 60189 | 2018-11-13 07:23:39
Listening socket (1388). Port 60189 | Closed. | 2018-11-13 07:23:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:39
DTC Client socket (50) | Socket gracefully closed by remote side. | 2018-11-13 07:23:40
DTC Client socket (50) | Closed. | 2018-11-13 07:23:40
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:23:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60189 | 2018-11-13 07:23:41
DTC Client socket (51) | Creating socket. | 2018-11-13 07:23:41
DTC Client socket (51) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:41
DTC Client socket (51) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:23:42 *
DTC Client socket (51) | Initiating close of socket by core. | 2018-11-13 07:23:42
DTC Client socket (51) | Closed. | 2018-11-13 07:23:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:42
Rithmic Trading | Disconnected. | 2018-11-13 07:23:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:42
Rithmic Trading | Port for executable: 60193 | 2018-11-13 07:23:44
Listening socket (1356). Port 60193 | Closed. | 2018-11-13 07:23:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:44
Rithmic Trading | Bridge process is running. | 2018-11-13 07:23:46
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60193 | 2018-11-13 07:23:46
DTC Client socket (52) | Creating socket. | 2018-11-13 07:23:46
DTC Client socket (52) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:46
Rithmic Trading | Connected to server. | 2018-11-13 07:23:46
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:23:46
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:23:46
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:23:46
Rithmic Trading | Sending logon request message. | 2018-11-13 07:23:46
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:23:46
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:23:46
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:23:46
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:23:48
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:23:48
Rithmic Trading | Received logon response. | 2018-11-13 07:23:48
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:23:48
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:23:48
Rithmic Trading | Logon error received from server | 2018-11-13 07:23:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:48
DTC Client socket (52) | Initiating close of socket by core. | 2018-11-13 07:23:48
Rithmic Trading | Disconnected. | 2018-11-13 07:23:48
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:48
DTC Client socket (52) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:23:48
Rithmic Trading | Port for executable: 60207 | 2018-11-13 07:23:50
Listening socket (1384). Port 60207 | Closed. | 2018-11-13 07:23:50
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:50
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:23:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60207 | 2018-11-13 07:23:52
DTC Client socket (53) | Creating socket. | 2018-11-13 07:23:52
DTC Client socket (53) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:52
DTC Client socket (53) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:23:53 *
DTC Client socket (53) | Initiating close of socket by core. | 2018-11-13 07:23:53
DTC Client socket (53) | Closed. | 2018-11-13 07:23:53
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:53
Rithmic Trading | Disconnected. | 2018-11-13 07:23:53
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:53
Rithmic Trading | Port for executable: 60210 | 2018-11-13 07:23:55
Listening socket (1384). Port 60210 | Closed. | 2018-11-13 07:23:55
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:23:55
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:23:57
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60210 | 2018-11-13 07:23:57
DTC Client socket (54) | Creating socket. | 2018-11-13 07:23:57
DTC Client socket (54) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:23:57
DTC Client socket (54) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:23:58 *
DTC Client socket (54) | Initiating close of socket by core. | 2018-11-13 07:23:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:23:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:58
DTC Client socket (54) | Closed. | 2018-11-13 07:23:58
Rithmic Trading | Disconnected. | 2018-11-13 07:23:58
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:23:58
Rithmic Trading | Port for executable: 60213 | 2018-11-13 07:24:00
Listening socket (1276). Port 60213 | Closed. | 2018-11-13 07:24:00
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:24:00
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:24:02
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60213 | 2018-11-13 07:24:02
DTC Client socket (56) | Creating socket. | 2018-11-13 07:24:02
DTC Client socket (56) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:24:02
DTC Client socket (56) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:24:03 *
DTC Client socket (56) | Initiating close of socket by core. | 2018-11-13 07:24:03
DTC Client socket (56) | Closed. | 2018-11-13 07:24:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:24:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:03
Rithmic Trading | Disconnected. | 2018-11-13 07:24:03
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:03
Rithmic Trading | Port for executable: 60218 | 2018-11-13 07:24:05
Listening socket (1276). Port 60218 | Closed. | 2018-11-13 07:24:05
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:24:05
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:24:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60218 | 2018-11-13 07:24:07
DTC Client socket (57) | Creating socket. | 2018-11-13 07:24:07
DTC Client socket (57) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:24:07
DTC Client socket (57) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:24:08 *
DTC Client socket (57) | Initiating close of socket by core. | 2018-11-13 07:24:08
DTC Client socket (57) | Closed. | 2018-11-13 07:24:08
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:24:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:08
Rithmic Trading | Disconnected. | 2018-11-13 07:24:08
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:08
DTC Client socket (52) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:24:10 *
DTC Client socket (52) | Socket gracefully closed by remote side. | 2018-11-13 07:24:10
DTC Client socket (52) | Closed. | 2018-11-13 07:24:10
Rithmic Trading | Port for executable: 60220 | 2018-11-13 07:24:10
Listening socket (1276). Port 60220 | Closed. | 2018-11-13 07:24:10
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:24:10
Rithmic Trading | Bridge process is running. | 2018-11-13 07:24:12
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60220 | 2018-11-13 07:24:12
DTC Client socket (58) | Creating socket. | 2018-11-13 07:24:12
DTC Client socket (58) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:24:12
Rithmic Trading | Connected to server. | 2018-11-13 07:24:12
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:24:12
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:24:12
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:24:12
Rithmic Trading | Sending logon request message. | 2018-11-13 07:24:12
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:24:12
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:24:12
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:24:12
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:24:13
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:24:13
Rithmic Trading | Received logon response. | 2018-11-13 07:24:13
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:24:13
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:24:13
Rithmic Trading | Logon error received from server | 2018-11-13 07:24:13
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:24:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:13
DTC Client socket (58) | Initiating close of socket by core. | 2018-11-13 07:24:13
Rithmic Trading | Disconnected. | 2018-11-13 07:24:13
DTC Client socket (58) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:24:13
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:13
Rithmic Trading | Port for executable: 60230 | 2018-11-13 07:24:15
Listening socket (1300). Port 60230 | Closed. | 2018-11-13 07:24:15
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:24:15
DTC Client socket (58) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:24:15 *
DTC Client socket (58) | Socket gracefully closed by remote side. | 2018-11-13 07:24:15
DTC Client socket (58) | Closed. | 2018-11-13 07:24:15
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:24:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60230 | 2018-11-13 07:24:17
DTC Client socket (59) | Creating socket. | 2018-11-13 07:24:17
DTC Client socket (59) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:24:17
DTC Client socket (59) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:24:18 *
DTC Client socket (59) | Initiating close of socket by core. | 2018-11-13 07:24:18
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:24:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:18
DTC Client socket (59) | Closed. | 2018-11-13 07:24:18
Rithmic Trading | Disconnected. | 2018-11-13 07:24:18
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:24:18
Rithmic Trading | Port for executable: 60236 | 2018-11-13 07:26:18
Listening socket (1360). Port 60236 | Closed. | 2018-11-13 07:26:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:26:18
Rithmic Trading | Bridge process is running. | 2018-11-13 07:26:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60236 | 2018-11-13 07:26:20
DTC Client socket (62) | Creating socket. | 2018-11-13 07:26:20
DTC Client socket (62) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:26:20
Rithmic Trading | Connected to server. | 2018-11-13 07:26:20
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:26:20
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:26:20
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:26:20
Rithmic Trading | Sending logon request message. | 2018-11-13 07:26:20
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:26:20
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:26:20
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:26:20
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:26:20
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:26:21
Rithmic Trading | Received logon response. | 2018-11-13 07:26:21
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:26:21
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:26:21
Rithmic Trading | Logon error received from server | 2018-11-13 07:26:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:26:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:26:21
DTC Client socket (62) | Initiating close of socket by core. | 2018-11-13 07:26:21
DTC Client socket (62) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:26:21
Rithmic Trading | Disconnected. | 2018-11-13 07:26:21
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:26:21
DTC Client socket (62) | Socket gracefully closed by remote side. | 2018-11-13 07:26:23
DTC Client socket (62) | Closed. | 2018-11-13 07:26:23
Rithmic Trading | Port for executable: 60255 | 2018-11-13 07:28:21
Listening socket (1312). Port 60255 | Closed. | 2018-11-13 07:28:21
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:28:21
Rithmic Trading | Bridge process is running. | 2018-11-13 07:28:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60255 | 2018-11-13 07:28:23
DTC Client socket (65) | Creating socket. | 2018-11-13 07:28:23
DTC Client socket (65) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:28:23
Rithmic Trading | Connected to server. | 2018-11-13 07:28:23
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:28:23
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:28:23
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:28:23
Rithmic Trading | Sending logon request message. | 2018-11-13 07:28:23
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:28:23
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:28:23
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:28:23
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:28:23
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:28:23
Rithmic Trading | Received logon response. | 2018-11-13 07:28:23
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:28:23
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:28:23
Rithmic Trading | Logon error received from server | 2018-11-13 07:28:23
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:28:23
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:28:23
DTC Client socket (65) | Initiating close of socket by core. | 2018-11-13 07:28:23
DTC Client socket (65) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:28:23
Rithmic Trading | Disconnected. | 2018-11-13 07:28:23
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:28:23
DTC Client socket (65) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:28:26 *
DTC Client socket (65) | Socket gracefully closed by remote side. | 2018-11-13 07:28:26
DTC Client socket (65) | Closed. | 2018-11-13 07:28:26
CLZ8-NYMEX 2 Min #8 | Reloading chart. | 2018-11-13 07:29:30
6EZ8-CME 10 Min #1 | Reloading chart. | 2018-11-13 07:29:31
6CZ8-CME 5 Min #2 | Reloading chart. | 2018-11-13 07:29:31
NQZ8-CME 2 Min #3 | Reloading chart. | 2018-11-13 07:29:32
PLF9-NYMEX 10 Min #4 | Reloading chart. | 2018-11-13 07:29:33
RTYZ8-CME 2 Min #5 | Reloading chart. | 2018-11-13 07:29:34
YMZ8-CBOT 5 Min #6 | Reloading chart. | 2018-11-13 07:29:35
GCZ8-COMEX 5 Min #9 | Reloading chart. | 2018-11-13 07:29:36
HGZ8-COMEX 5 Min #10 | Reloading chart. | 2018-11-13 07:29:36
NGZ8-NYMEX 2 Min #11 | Reloading chart. | 2018-11-13 07:29:37
6JZ8-CME 2 Min #12 | Reloading chart. | 2018-11-13 07:29:39
6EZ8-CME 5 Min #7 | Reloading chart. | 2018-11-13 07:29:40
EMDZ8-CME 2 Min #13 | Reloading chart. | 2018-11-13 07:29:40
LEZ8-CME 2 Min #14 | Reloading chart. | 2018-11-13 07:29:40
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLZ8-NYMEX | 2018-11-13 07:29:42
Intraday data recording state for symbol CLZ8-NYMEX is set to download 'Pending'. | 2018-11-13 07:29:42
HD Request # 2 | Downloading Intraday chart data for CLZ8-NYMEX to the file CLZ8-NYMEX.scid. Service: nymex | 2018-11-13 07:29:42
HD Request # 2 | Download start date-time: 2018-11-12 07:21:10.000 | 2018-11-13 07:29:42
HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6EZ8-CME | 2018-11-13 07:29:42
Intraday data recording state for symbol 6EZ8-CME is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6CZ8-CME | 2018-11-13 07:29:42
Intraday data recording state for symbol 6CZ8-CME is set to download 'Pending'. | 2018-11-13 07:29:42
Socket (67) | Creating socket. | 2018-11-13 07:29:42
Socket (67) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQZ8-CME | 2018-11-13 07:29:42
Intraday data recording state for symbol NQZ8-CME is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: PLF9-NYMEX | 2018-11-13 07:29:42
Intraday data recording state for symbol PLF9-NYMEX is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYZ8-CME | 2018-11-13 07:29:42
Intraday data recording state for symbol RTYZ8-CME is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMZ8-CBOT | 2018-11-13 07:29:42
Intraday data recording state for symbol YMZ8-CBOT is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: GCZ8-COMEX | 2018-11-13 07:29:42
Intraday data recording state for symbol GCZ8-COMEX is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: HGZ8-COMEX | 2018-11-13 07:29:42
Intraday data recording state for symbol HGZ8-COMEX is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NGZ8-NYMEX | 2018-11-13 07:29:42
Intraday data recording state for symbol NGZ8-NYMEX is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: 6JZ8-CME | 2018-11-13 07:29:42
Intraday data recording state for symbol 6JZ8-CME is set to download 'Pending'. | 2018-11-13 07:29:42
HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:42
HD Request # 2 | Sending historical data logon request message. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: EMDZ8-CME | 2018-11-13 07:29:42
Intraday data recording state for symbol EMDZ8-CME is set to download 'Pending'. | 2018-11-13 07:29:42
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: LEZ8-CME | 2018-11-13 07:29:42
Intraday data recording state for symbol LEZ8-CME is set to download 'Pending'. | 2018-11-13 07:29:42
HD Request # 2 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:10. Record interval: 1. Symbol: CLZ18 | 2018-11-13 07:29:42
HD Request # 2 | Decompressing data. | 2018-11-13 07:29:42
HD Request # 2 | Receiving Intraday data for CLZ8-NYMEX starting at 2018-11-12 07:21:10 | 2018-11-13 07:29:42
HD Request # 2 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:10 | 2018-11-13 07:29:42
Socket (67) | Initiating close of socket by core. | 2018-11-13 07:29:42
Socket (67) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:42
HD Request # 2 | Historical data for CLZ8-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:42
Historical data download thread signaled to stop. | 2018-11-13 07:29:42
HD Request # 2 | Received 44065 records from 2018-11-12 07:21:10 to 2018-11-13 07:19:40 (24.0 hours) and wrote 44065 records for CLZ8-NYMEX | 2018-11-13 07:29:42
HD Request # 2 | Completion time: 1s | 2018-11-13 07:29:42
HD Request # 2 | Intraday data download complete for CLZ8-NYMEX. Unique request ID: 1 | 2018-11-13 07:29:42
Removed historical data download ID 1 | 2018-11-13 07:29:42
Rithmic Trading | Using primary service for historical data for CLZ8-NYMEX | 2018-11-13 07:29:42
Historical data service client indicated that downloads are not enabled. Symbol: CLZ8-NYMEX. Data Type: Intraday data | 2018-11-13 07:29:42
HD Request # 2 | Download from primary service not started due to error. | 2018-11-13 07:29:42
HD Request # 3 | Downloading Intraday chart data for 6EZ8-CME to the file 6EZ8-CME.scid. Service: cme | 2018-11-13 07:29:42
HD Request # 3 | Download start date-time: 2018-11-12 07:21:10.000 | 2018-11-13 07:29:42
HD Request # 3 | Using server: ds1.sierracharts.com port 10150 | 2018-11-13 07:29:42
Socket (67) | Socket gracefully closed by remote side. | 2018-11-13 07:29:42
Socket (67) | Closed. | 2018-11-13 07:29:42
Socket (68) | Creating socket. | 2018-11-13 07:29:42
Socket (68) | Connecting to IP: 8.18.161.135. | 2018-11-13 07:29:42
HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:42
HD Request # 3 | Sending historical data logon request message. | 2018-11-13 07:29:42
HD Request # 3 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:10. Record interval: 1. Symbol: 6EZ18 | 2018-11-13 07:29:43
HD Request # 3 | Decompressing data. | 2018-11-13 07:29:43
HD Request # 3 | Receiving Intraday data for 6EZ8-CME starting at 2018-11-12 07:21:10 | 2018-11-13 07:29:43
HD Request # 3 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:10 | 2018-11-13 07:29:43
Socket (68) | Initiating close of socket by core. | 2018-11-13 07:29:43
HD Request # 3 | Historical data for 6EZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:43
Socket (68) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:43
Historical data download thread signaled to stop. | 2018-11-13 07:29:43
HD Request # 3 | Received 21009 records from 2018-11-12 07:21:10 to 2018-11-13 07:19:41 (24.0 hours) and wrote 21009 records for 6EZ8-CME | 2018-11-13 07:29:43
HD Request # 3 | Completion time: 0s | 2018-11-13 07:29:43
HD Request # 3 | Intraday data download complete for 6EZ8-CME. Unique request ID: 2 | 2018-11-13 07:29:43
Removed historical data download ID 2 | 2018-11-13 07:29:43
Rithmic Trading | Using primary service for historical data for 6EZ8-CME | 2018-11-13 07:29:43
Historical data service client indicated that downloads are not enabled. Symbol: 6EZ8-CME. Data Type: Intraday data | 2018-11-13 07:29:43
HD Request # 3 | Download from primary service not started due to error. | 2018-11-13 07:29:43
HD Request # 4 | Downloading Intraday chart data for 6CZ8-CME to the file 6CZ8-CME.scid. Service: cme | 2018-11-13 07:29:43
HD Request # 4 | Download start date-time: 2018-11-12 07:21:01.000 | 2018-11-13 07:29:43
HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:29:43
Socket (69) | Creating socket. | 2018-11-13 07:29:43
Socket (69) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:29:43
Socket (68) | Socket gracefully closed by remote side. | 2018-11-13 07:29:43
Socket (68) | Closed. | 2018-11-13 07:29:43
HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:44
HD Request # 4 | Sending historical data logon request message. | 2018-11-13 07:29:44
HD Request # 4 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:01. Record interval: 1. Symbol: 6CZ18 | 2018-11-13 07:29:44
HD Request # 4 | Decompressing data. | 2018-11-13 07:29:44
HD Request # 4 | Receiving Intraday data for 6CZ8-CME starting at 2018-11-12 07:21:01 | 2018-11-13 07:29:44
HD Request # 4 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:01 | 2018-11-13 07:29:44
Socket (69) | Initiating close of socket by core. | 2018-11-13 07:29:44
Socket (69) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:44
HD Request # 4 | Historical data for 6CZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:44
Historical data download thread signaled to stop. | 2018-11-13 07:29:44
HD Request # 4 | Received 7509 records from 2018-11-12 07:21:01 to 2018-11-13 07:19:41 (24.0 hours) and wrote 7509 records for 6CZ8-CME | 2018-11-13 07:29:44
HD Request # 4 | Completion time: 0s | 2018-11-13 07:29:44
HD Request # 4 | Intraday data download complete for 6CZ8-CME. Unique request ID: 3 | 2018-11-13 07:29:44
Removed historical data download ID 3 | 2018-11-13 07:29:44
Rithmic Trading | Using primary service for historical data for 6CZ8-CME | 2018-11-13 07:29:44
Historical data service client indicated that downloads are not enabled. Symbol: 6CZ8-CME. Data Type: Intraday data | 2018-11-13 07:29:44
HD Request # 4 | Download from primary service not started due to error. | 2018-11-13 07:29:44
HD Request # 5 | Downloading Intraday chart data for NQZ8-CME to the file NQZ8-CME.scid. Service: cme | 2018-11-13 07:29:44
HD Request # 5 | Download start date-time: 2018-11-12 07:21:11.000 | 2018-11-13 07:29:44
HD Request # 5 | Using server: ds1.sierracharts.com port 10150 | 2018-11-13 07:29:44
Socket (70) | Creating socket. | 2018-11-13 07:29:44
Socket (70) | Connecting to IP: 8.18.161.135. | 2018-11-13 07:29:44
Socket (69) | Socket gracefully closed by remote side. | 2018-11-13 07:29:44
Socket (69) | Closed. | 2018-11-13 07:29:44
HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:44
HD Request # 5 | Sending historical data logon request message. | 2018-11-13 07:29:44
HD Request # 5 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:11. Record interval: 1. Symbol: NQZ18 | 2018-11-13 07:29:44
HD Request # 5 | Decompressing data. | 2018-11-13 07:29:44
HD Request # 5 | Receiving Intraday data for NQZ8-CME starting at 2018-11-12 07:21:11 | 2018-11-13 07:29:45
HD Request # 5 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:11 | 2018-11-13 07:29:45
HD Request # 5 | Historical data for NQZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:45
Socket (70) | Initiating close of socket by core. | 2018-11-13 07:29:45
Socket (70) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:45
Historical data download thread signaled to stop. | 2018-11-13 07:29:45
HD Request # 5 | Received 52964 records from 2018-11-12 07:21:11 to 2018-11-13 07:19:40 (24.0 hours) and wrote 52964 records for NQZ8-CME | 2018-11-13 07:29:45
HD Request # 5 | Completion time: 2s | 2018-11-13 07:29:45
HD Request # 5 | Intraday data download complete for NQZ8-CME. Unique request ID: 4 | 2018-11-13 07:29:45
Removed historical data download ID 4 | 2018-11-13 07:29:45
Rithmic Trading | Using primary service for historical data for NQZ8-CME | 2018-11-13 07:29:45
Historical data service client indicated that downloads are not enabled. Symbol: NQZ8-CME. Data Type: Intraday data | 2018-11-13 07:29:45
HD Request # 5 | Download from primary service not started due to error. | 2018-11-13 07:29:45
HD Request # 6 | Downloading Intraday chart data for PLF9-NYMEX to the file PLF9-NYMEX.scid. Service: nymex | 2018-11-13 07:29:45
HD Request # 6 | Download start date-time: 2018-11-12 07:21:06.000 | 2018-11-13 07:29:45
HD Request # 6 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:29:45
Socket (71) | Creating socket. | 2018-11-13 07:29:45
Socket (71) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:29:45
Socket (70) | Socket gracefully closed by remote side. | 2018-11-13 07:29:45
Socket (70) | Closed. | 2018-11-13 07:29:45
HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:45
HD Request # 6 | Sending historical data logon request message. | 2018-11-13 07:29:45
HD Request # 6 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:06. Record interval: 1. Symbol: PLF19 | 2018-11-13 07:29:46
HD Request # 6 | Decompressing data. | 2018-11-13 07:29:46
HD Request # 6 | Receiving Intraday data for PLF9-NYMEX starting at 2018-11-12 07:21:06 | 2018-11-13 07:29:46
HD Request # 6 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:06 | 2018-11-13 07:29:46
Socket (71) | Initiating close of socket by core. | 2018-11-13 07:29:46
Socket (71) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:46
HD Request # 6 | Historical data for PLF9-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:46
Historical data download thread signaled to stop. | 2018-11-13 07:29:46
HD Request # 6 | Received 4434 records from 2018-11-12 07:21:06 to 2018-11-13 07:19:09 (24.0 hours) and wrote 4434 records for PLF9-NYMEX | 2018-11-13 07:29:46
HD Request # 6 | Completion time: 0s | 2018-11-13 07:29:46
HD Request # 6 | Intraday data download complete for PLF9-NYMEX. Unique request ID: 5 | 2018-11-13 07:29:46
Removed historical data download ID 5 | 2018-11-13 07:29:46
Rithmic Trading | Using primary service for historical data for PLF9-NYMEX | 2018-11-13 07:29:46
Historical data service client indicated that downloads are not enabled. Symbol: PLF9-NYMEX. Data Type: Intraday data | 2018-11-13 07:29:46
HD Request # 6 | Download from primary service not started due to error. | 2018-11-13 07:29:46
HD Request # 7 | Downloading Intraday chart data for RTYZ8-CME to the file RTYZ8-CME.scid. Service: cme | 2018-11-13 07:29:46
HD Request # 7 | Download start date-time: 2018-11-12 07:21:08.000 | 2018-11-13 07:29:46
HD Request # 7 | Using server: ds1.sierracharts.com port 10150 | 2018-11-13 07:29:46
Socket (72) | Creating socket. | 2018-11-13 07:29:46
Socket (72) | Connecting to IP: 8.18.161.135. | 2018-11-13 07:29:46
Socket (71) | Socket gracefully closed by remote side. | 2018-11-13 07:29:46
Socket (71) | Closed. | 2018-11-13 07:29:46
HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:46
HD Request # 7 | Sending historical data logon request message. | 2018-11-13 07:29:46
HD Request # 7 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:08. Record interval: 1. Symbol: RTYZ18 | 2018-11-13 07:29:46
HD Request # 7 | Decompressing data. | 2018-11-13 07:29:46
HD Request # 7 | Receiving Intraday data for RTYZ8-CME starting at 2018-11-12 07:21:08 | 2018-11-13 07:29:47
HD Request # 7 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:08 | 2018-11-13 07:29:47
HD Request # 7 | Historical data for RTYZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:47
Socket (72) | Initiating close of socket by core. | 2018-11-13 07:29:47
Socket (72) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:47
Historical data download thread signaled to stop. | 2018-11-13 07:29:47
HD Request # 7 | Received 25478 records from 2018-11-12 07:21:08 to 2018-11-13 07:19:42 (24.0 hours) and wrote 25478 records for RTYZ8-CME | 2018-11-13 07:29:47
HD Request # 7 | Completion time: 0s | 2018-11-13 07:29:47
HD Request # 7 | Intraday data download complete for RTYZ8-CME. Unique request ID: 6 | 2018-11-13 07:29:47
Removed historical data download ID 6 | 2018-11-13 07:29:47
Rithmic Trading | Using primary service for historical data for RTYZ8-CME | 2018-11-13 07:29:47
Historical data service client indicated that downloads are not enabled. Symbol: RTYZ8-CME. Data Type: Intraday data | 2018-11-13 07:29:47
HD Request # 7 | Download from primary service not started due to error. | 2018-11-13 07:29:47
HD Request # 8 | Downloading Intraday chart data for YMZ8-CBOT to the file YMZ8-CBOT.scid. Service: cbot | 2018-11-13 07:29:47
HD Request # 8 | Download start date-time: 2018-11-12 07:21:12.000 | 2018-11-13 07:29:47
HD Request # 8 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:29:47
Socket (73) | Creating socket. | 2018-11-13 07:29:47
Socket (73) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:29:47
Socket (72) | Socket gracefully closed by remote side. | 2018-11-13 07:29:47
Socket (72) | Closed. | 2018-11-13 07:29:47
HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:47
HD Request # 8 | Sending historical data logon request message. | 2018-11-13 07:29:47
HD Request # 8 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:12. Record interval: 1. Symbol: YMZ18 | 2018-11-13 07:29:47
HD Request # 8 | Decompressing data. | 2018-11-13 07:29:47
HD Request # 8 | Receiving Intraday data for YMZ8-CBOT starting at 2018-11-12 07:21:12 | 2018-11-13 07:29:47
HD Request # 8 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:12 | 2018-11-13 07:29:47
HD Request # 8 | Historical data for YMZ8-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:47
Socket (73) | Initiating close of socket by core. | 2018-11-13 07:29:47
Socket (73) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:47
HD Request # 8 | Received 40737 records from 2018-11-12 07:21:12 to 2018-11-13 07:19:40 (24.0 hours) and wrote 40737 records for YMZ8-CBOT | 2018-11-13 07:29:47
HD Request # 8 | Completion time: 1s | 2018-11-13 07:29:47
HD Request # 8 | Intraday data download complete for YMZ8-CBOT. Unique request ID: 7 | 2018-11-13 07:29:47
Removed historical data download ID 7 | 2018-11-13 07:29:47
Rithmic Trading | Using primary service for historical data for YMZ8-CBOT | 2018-11-13 07:29:47
Historical data service client indicated that downloads are not enabled. Symbol: YMZ8-CBOT. Data Type: Intraday data | 2018-11-13 07:29:47
HD Request # 8 | Download from primary service not started due to error. | 2018-11-13 07:29:47
HD Request # 9 | Downloading Intraday chart data for GCZ8-COMEX to the file GCZ8-COMEX.scid. Service: comex | 2018-11-13 07:29:47
HD Request # 9 | Download start date-time: 2018-11-12 07:21:09.000 | 2018-11-13 07:29:47
HD Request # 9 | Using server: ds1.sierracharts.com port 10150 | 2018-11-13 07:29:47
Socket (74) | Creating socket. | 2018-11-13 07:29:47
Socket (74) | Connecting to IP: 8.18.161.135. | 2018-11-13 07:29:47
Socket (73) | Socket gracefully closed by remote side. | 2018-11-13 07:29:47
Socket (73) | Closed. | 2018-11-13 07:29:47
HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:47
HD Request # 9 | Sending historical data logon request message. | 2018-11-13 07:29:47
HD Request # 9 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:09. Record interval: 1. Symbol: GCZ18 | 2018-11-13 07:29:47
HD Request # 9 | Decompressing data. | 2018-11-13 07:29:47
HD Request # 9 | Receiving Intraday data for GCZ8-COMEX starting at 2018-11-12 07:21:09 | 2018-11-13 07:29:48
HD Request # 9 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:09 | 2018-11-13 07:29:48
HD Request # 9 | Historical data for GCZ8-COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:48
Socket (74) | Initiating close of socket by core. | 2018-11-13 07:29:48
Socket (74) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:48
Historical data download thread signaled to stop. | 2018-11-13 07:29:48
HD Request # 9 | Received 24113 records from 2018-11-12 07:21:09 to 2018-11-13 07:19:42 (24.0 hours) and wrote 24113 records for GCZ8-COMEX | 2018-11-13 07:29:48
HD Request # 9 | Completion time: 0s | 2018-11-13 07:29:48
HD Request # 9 | Intraday data download complete for GCZ8-COMEX. Unique request ID: 8 | 2018-11-13 07:29:48
Removed historical data download ID 8 | 2018-11-13 07:29:48
Rithmic Trading | Using primary service for historical data for GCZ8-COMEX | 2018-11-13 07:29:48
Historical data service client indicated that downloads are not enabled. Symbol: GCZ8-COMEX. Data Type: Intraday data | 2018-11-13 07:29:48
HD Request # 9 | Download from primary service not started due to error. | 2018-11-13 07:29:48
HD Request # 10 | Downloading Intraday chart data for HGZ8-COMEX to the file HGZ8-COMEX.scid. Service: comex | 2018-11-13 07:29:48
HD Request # 10 | Download start date-time: 2018-11-12 07:21:12.000 | 2018-11-13 07:29:48
HD Request # 10 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:29:48
Socket (75) | Creating socket. | 2018-11-13 07:29:48
Socket (75) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:29:48
Socket (74) | Socket gracefully closed by remote side. | 2018-11-13 07:29:48
Socket (74) | Closed. | 2018-11-13 07:29:48
HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:48
HD Request # 10 | Sending historical data logon request message. | 2018-11-13 07:29:48
HD Request # 10 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:12. Record interval: 1. Symbol: HGZ18 | 2018-11-13 07:29:48
HD Request # 10 | Decompressing data. | 2018-11-13 07:29:48
HD Request # 10 | Receiving Intraday data for HGZ8-COMEX starting at 2018-11-12 07:21:12 | 2018-11-13 07:29:48
HD Request # 10 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:12 | 2018-11-13 07:29:48
HD Request # 10 | Historical data for HGZ8-COMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:48
Socket (75) | Initiating close of socket by core. | 2018-11-13 07:29:48
Socket (75) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:48
HD Request # 10 | Received 16574 records from 2018-11-12 07:21:12 to 2018-11-13 07:19:46 (24.0 hours) and wrote 16574 records for HGZ8-COMEX | 2018-11-13 07:29:48
HD Request # 10 | Completion time: 0s | 2018-11-13 07:29:48
HD Request # 10 | Intraday data download complete for HGZ8-COMEX. Unique request ID: 9 | 2018-11-13 07:29:48
Removed historical data download ID 9 | 2018-11-13 07:29:48
Rithmic Trading | Using primary service for historical data for HGZ8-COMEX | 2018-11-13 07:29:48
Historical data service client indicated that downloads are not enabled. Symbol: HGZ8-COMEX. Data Type: Intraday data | 2018-11-13 07:29:48
HD Request # 10 | Download from primary service not started due to error. | 2018-11-13 07:29:48
HD Request # 11 | Downloading Intraday chart data for NGZ8-NYMEX to the file NGZ8-NYMEX.scid. Service: nymex | 2018-11-13 07:29:48
HD Request # 11 | Download start date-time: 2018-11-12 07:21:11.000 | 2018-11-13 07:29:48
HD Request # 11 | Using server: ds1.sierracharts.com port 10150 | 2018-11-13 07:29:48
Socket (76) | Creating socket. | 2018-11-13 07:29:48
Socket (76) | Connecting to IP: 8.18.161.135. | 2018-11-13 07:29:48
Socket (75) | Socket gracefully closed by remote side. | 2018-11-13 07:29:48
Socket (75) | Closed. | 2018-11-13 07:29:48
HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:48
HD Request # 11 | Sending historical data logon request message. | 2018-11-13 07:29:48
HD Request # 11 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:11. Record interval: 1. Symbol: NGZ18 | 2018-11-13 07:29:48
HD Request # 11 | Decompressing data. | 2018-11-13 07:29:49
HD Request # 11 | Receiving Intraday data for NGZ8-NYMEX starting at 2018-11-12 07:21:11 | 2018-11-13 07:29:49
HD Request # 11 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:11 | 2018-11-13 07:29:49
HD Request # 11 | Historical data for NGZ8-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:49
Socket (76) | Initiating close of socket by core. | 2018-11-13 07:29:49
Socket (76) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:49
Historical data download thread signaled to stop. | 2018-11-13 07:29:49
HD Request # 11 | Received 19526 records from 2018-11-12 07:21:11 to 2018-11-13 07:19:47 (24.0 hours) and wrote 19526 records for NGZ8-NYMEX | 2018-11-13 07:29:49
HD Request # 11 | Completion time: 0s | 2018-11-13 07:29:49
HD Request # 11 | Intraday data download complete for NGZ8-NYMEX. Unique request ID: 10 | 2018-11-13 07:29:49
Removed historical data download ID 10 | 2018-11-13 07:29:49
Rithmic Trading | Using primary service for historical data for NGZ8-NYMEX | 2018-11-13 07:29:49
Historical data service client indicated that downloads are not enabled. Symbol: NGZ8-NYMEX. Data Type: Intraday data | 2018-11-13 07:29:49
HD Request # 11 | Download from primary service not started due to error. | 2018-11-13 07:29:49
HD Request # 12 | Downloading Intraday chart data for 6JZ8-CME to the file 6JZ8-CME.scid. Service: cme | 2018-11-13 07:29:49
HD Request # 12 | Download start date-time: 2018-11-12 07:21:13.000 | 2018-11-13 07:29:49
HD Request # 12 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:29:49
Socket (77) | Creating socket. | 2018-11-13 07:29:49
Socket (77) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:29:49
Socket (76) | Socket gracefully closed by remote side. | 2018-11-13 07:29:49
Socket (76) | Closed. | 2018-11-13 07:29:49
HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:49
HD Request # 12 | Sending historical data logon request message. | 2018-11-13 07:29:49
HD Request # 12 | Requesting Intraday data. Start date-time: 2018-11-12 07:21:13. Record interval: 1. Symbol: 6JZ18 | 2018-11-13 07:29:49
HD Request # 12 | Decompressing data. | 2018-11-13 07:29:49
HD Request # 12 | Receiving Intraday data for 6JZ8-CME starting at 2018-11-12 07:21:13 | 2018-11-13 07:29:49
HD Request # 12 | Timestamp of first Intraday data file record written: 2018-11-12 07:21:13 | 2018-11-13 07:29:49
Socket (77) | Initiating close of socket by core. | 2018-11-13 07:29:49
HD Request # 12 | Historical data for 6JZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:49
Socket (77) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:49
HD Request # 12 | Received 13281 records from 2018-11-12 07:21:13 to 2018-11-13 07:19:44 (24.0 hours) and wrote 13281 records for 6JZ8-CME | 2018-11-13 07:29:49
HD Request # 12 | Completion time: 1s | 2018-11-13 07:29:49
HD Request # 12 | Intraday data download complete for 6JZ8-CME. Unique request ID: 11 | 2018-11-13 07:29:49
Removed historical data download ID 11 | 2018-11-13 07:29:49
Rithmic Trading | Using primary service for historical data for 6JZ8-CME | 2018-11-13 07:29:49
Historical data service client indicated that downloads are not enabled. Symbol: 6JZ8-CME. Data Type: Intraday data | 2018-11-13 07:29:49
HD Request # 12 | Download from primary service not started due to error. | 2018-11-13 07:29:49
HD Request # 13 | Downloading Intraday chart data for EMDZ8-CME to the file EMDZ8-CME.scid. Service: cme | 2018-11-13 07:29:49
HD Request # 13 | Download start date-time: 2018-11-12 07:20:51.000 | 2018-11-13 07:29:49
HD Request # 13 | Using server: ds1.sierracharts.com port 10150 | 2018-11-13 07:29:49
Socket (78) | Creating socket. | 2018-11-13 07:29:49
Socket (78) | Connecting to IP: 8.18.161.135. | 2018-11-13 07:29:49
Socket (77) | Socket gracefully closed by remote side. | 2018-11-13 07:29:49
Socket (77) | Closed. | 2018-11-13 07:29:49
HD Request # 13 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:49
HD Request # 13 | Sending historical data logon request message. | 2018-11-13 07:29:49
HD Request # 13 | Requesting Intraday data. Start date-time: 2018-11-12 07:20:51. Record interval: 1. Symbol: EMDZ18 | 2018-11-13 07:29:49
HD Request # 13 | Decompressing data. | 2018-11-13 07:29:49
HD Request # 13 | Receiving Intraday data for EMDZ8-CME starting at 2018-11-12 07:20:51 | 2018-11-13 07:29:50
HD Request # 13 | Timestamp of first Intraday data file record written: 2018-11-12 07:20:51 | 2018-11-13 07:29:50
Socket (78) | Initiating close of socket by core. | 2018-11-13 07:29:50
HD Request # 13 | Historical data for EMDZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:50
Socket (78) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:50
Historical data download thread signaled to stop. | 2018-11-13 07:29:50
HD Request # 13 | Received 6657 records from 2018-11-12 07:20:51 to 2018-11-13 07:18:47 (24.0 hours) and wrote 6657 records for EMDZ8-CME | 2018-11-13 07:29:50
HD Request # 13 | Completion time: 0s | 2018-11-13 07:29:50
HD Request # 13 | Intraday data download complete for EMDZ8-CME. Unique request ID: 12 | 2018-11-13 07:29:50
Removed historical data download ID 12 | 2018-11-13 07:29:50
Rithmic Trading | Using primary service for historical data for EMDZ8-CME | 2018-11-13 07:29:50
Historical data service client indicated that downloads are not enabled. Symbol: EMDZ8-CME. Data Type: Intraday data | 2018-11-13 07:29:50
HD Request # 13 | Download from primary service not started due to error. | 2018-11-13 07:29:50
HD Request # 14 | Downloading Intraday chart data for LEZ8-CME to the file LEZ8-CME.scid. Service: cme | 2018-11-13 07:29:50
HD Request # 14 | Download start date-time: 2018-11-09 13:04:59.000 | 2018-11-13 07:29:50
HD Request # 14 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:29:50
Socket (79) | Creating socket. | 2018-11-13 07:29:50
Socket (79) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:29:50
Socket (78) | Socket gracefully closed by remote side. | 2018-11-13 07:29:50
Socket (78) | Closed. | 2018-11-13 07:29:50
HD Request # 14 | Setting DTC encoding to Binary VLS | 2018-11-13 07:29:50
HD Request # 14 | Sending historical data logon request message. | 2018-11-13 07:29:50
HD Request # 14 | Requesting Intraday data. Start date-time: 2018-11-09 13:04:59. Record interval: 1. Symbol: LEZ18 | 2018-11-13 07:29:50
HD Request # 14 | Decompressing data. | 2018-11-13 07:29:50
HD Request # 14 | Receiving Intraday data for LEZ8-CME starting at 2018-11-09 13:04:59 | 2018-11-13 07:29:50
HD Request # 14 | Timestamp of first Intraday data file record written: 2018-11-09 13:04:59 | 2018-11-13 07:29:50
Socket (79) | Initiating close of socket by core. | 2018-11-13 07:29:50
HD Request # 14 | Historical data for LEZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:29:50
Socket (79) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:29:50
HD Request # 14 | Received 2461 records from 2018-11-09 13:04:59 to 2018-11-12 13:04:59 (3.0 days) and wrote 2461 records for LEZ8-CME | 2018-11-13 07:29:50
HD Request # 14 | Completion time: 0s | 2018-11-13 07:29:50
HD Request # 14 | Intraday data download complete for LEZ8-CME. Unique request ID: 13 | 2018-11-13 07:29:50
Removed historical data download ID 13 | 2018-11-13 07:29:50
Rithmic Trading | Using primary service for historical data for LEZ8-CME | 2018-11-13 07:29:50
Historical data service client indicated that downloads are not enabled. Symbol: LEZ8-CME. Data Type: Intraday data | 2018-11-13 07:29:50
HD Request # 14 | Download from primary service not started due to error. | 2018-11-13 07:29:50
Socket (79) | Socket gracefully closed by remote side. | 2018-11-13 07:29:50
Socket (79) | Closed. | 2018-11-13 07:29:50
Rithmic Trading | Port for executable: 60317 | 2018-11-13 07:30:23
Listening socket (1112). Port 60317 | Closed. | 2018-11-13 07:30:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:30:23
Rithmic Trading | Bridge process is running. | 2018-11-13 07:30:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60317 | 2018-11-13 07:30:25
DTC Client socket (81) | Creating socket. | 2018-11-13 07:30:25
DTC Client socket (81) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:30:25
Rithmic Trading | Connected to server. | 2018-11-13 07:30:25
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:30:25
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:30:25
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:30:25
Rithmic Trading | Sending logon request message. | 2018-11-13 07:30:25
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:30:25
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:30:25
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:30:25
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:30:26
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:30:26
Rithmic Trading | Received logon response. | 2018-11-13 07:30:26
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:30:26
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:30:26
Rithmic Trading | Logon error received from server | 2018-11-13 07:30:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:30:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:30:26
DTC Client socket (81) | Initiating close of socket by core. | 2018-11-13 07:30:26
DTC Client socket (81) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:30:26
Rithmic Trading | Disconnected. | 2018-11-13 07:30:26
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:30:26
DTC Client socket (81) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:30:28 *
DTC Client socket (81) | Socket gracefully closed by remote side. | 2018-11-13 07:30:28
DTC Client socket (81) | Closed. | 2018-11-13 07:30:28
6EZ8-CME 2 Min #3 | Reloading chart. | 2018-11-13 07:31:47
CLZ8-NYMEX 2 Min #5 | Reloading chart. | 2018-11-13 07:31:47
HGZ8-COMEX 2 Min #7 | Reloading chart. | 2018-11-13 07:31:48
NQZ8-CME 5 Min #9 | Reloading chart. | 2018-11-13 07:31:48
RTYZ8-CME 2 Min #10 | Reloading chart. | 2018-11-13 07:31:49
ESZ8-CME 2 Min #6 | Reloading chart. | 2018-11-13 07:31:49
YMZ8-CBOT 2 Min #8 | Reloading chart. | 2018-11-13 07:31:50
HEZ8-CME 2 Min #12 | Reloading chart. | 2018-11-13 07:31:50
6CZ8-CME 2 Min #2 | Reloading chart. | 2018-11-13 07:31:51
LEZ8-CME 5 Min #13 | Reloading chart. | 2018-11-13 07:31:51
GCZ8-COMEX 2 Min #1 | Reloading chart. | 2018-11-13 07:31:52
6JZ8-CME 2 Min #4 | Reloading chart. | 2018-11-13 07:31:52
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESZ8-CME | 2018-11-13 07:31:54
Intraday data recording state for symbol ESZ8-CME is set to download 'Pending'. | 2018-11-13 07:31:54
HD Request # 15 | Downloading Intraday chart data for ESZ8-CME to the file ESZ8-CME.scid. Service: cme | 2018-11-13 07:31:54
HD Request # 15 | Download start date-time: 2018-11-08 08:58:55.000 | 2018-11-13 07:31:54
HD Request # 15 | Using server: ds1.sierracharts.com port 10150 | 2018-11-13 07:31:54
Socket (83) | Creating socket. | 2018-11-13 07:31:54
Socket (83) | Connecting to IP: 8.18.161.135. | 2018-11-13 07:31:54
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: HEZ8-CME | 2018-11-13 07:31:54
Intraday data recording state for symbol HEZ8-CME is set to download 'Pending'. | 2018-11-13 07:31:54
HD Request # 15 | Setting DTC encoding to Binary VLS | 2018-11-13 07:31:54
HD Request # 15 | Sending historical data logon request message. | 2018-11-13 07:31:54
HD Request # 15 | Requesting Intraday data. Start date-time: 2018-11-08 08:58:55. Record interval: 1. Symbol: ESZ18 | 2018-11-13 07:31:54
HD Request # 15 | Decompressing data. | 2018-11-13 07:31:54
HD Request # 15 | Receiving Intraday data for ESZ8-CME starting at 2018-11-08 08:58:55 | 2018-11-13 07:31:54
HD Request # 15 | Timestamp of first Intraday data file record written: 2018-11-08 08:58:55 | 2018-11-13 07:31:54
HD Request # 15 | Historical data for ESZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:31:55
Socket (83) | Initiating close of socket by core. | 2018-11-13 07:31:55
Socket (83) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:31:55
Historical data download thread signaled to stop. | 2018-11-13 07:31:55
HD Request # 15 | Received 120086 records from 2018-11-08 08:58:55 to 2018-11-13 07:21:50 (4.9 days) and wrote 120086 records for ESZ8-CME | 2018-11-13 07:31:55
HD Request # 15 | Completion time: 1s | 2018-11-13 07:31:55
HD Request # 15 | Intraday data download complete for ESZ8-CME. Unique request ID: 27 | 2018-11-13 07:31:55
Removed historical data download ID 27 | 2018-11-13 07:31:55
Rithmic Trading | Using primary service for historical data for ESZ8-CME | 2018-11-13 07:31:55
Historical data service client indicated that downloads are not enabled. Symbol: ESZ8-CME. Data Type: Intraday data | 2018-11-13 07:31:55
HD Request # 15 | Download from primary service not started due to error. | 2018-11-13 07:31:55
HD Request # 16 | Downloading Intraday chart data for HEZ8-CME to the file HEZ8-CME.scid. Service: cme | 2018-11-13 07:31:55
HD Request # 16 | Download start date-time: 2018-11-08 08:58:52.000 | 2018-11-13 07:31:55
HD Request # 16 | Using server: ds7.sierracharts.com port 10149 | 2018-11-13 07:31:55
Socket (84) | Creating socket. | 2018-11-13 07:31:55
Socket (84) | Connecting to IP: 8.18.161.133. | 2018-11-13 07:31:55
Socket (83) | Socket gracefully closed by remote side. | 2018-11-13 07:31:55
Socket (83) | Closed. | 2018-11-13 07:31:55
HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-11-13 07:31:55
HD Request # 16 | Sending historical data logon request message. | 2018-11-13 07:31:55
HD Request # 16 | Requesting Intraday data. Start date-time: 2018-11-08 08:58:52. Record interval: 1. Symbol: HEZ18 | 2018-11-13 07:31:55
HD Request # 16 | Decompressing data. | 2018-11-13 07:31:55
HD Request # 16 | Receiving Intraday data for HEZ8-CME starting at 2018-11-08 08:58:52 | 2018-11-13 07:31:55
HD Request # 16 | Timestamp of first Intraday data file record written: 2018-11-08 08:58:52 | 2018-11-13 07:31:55
Socket (84) | Initiating close of socket by core. | 2018-11-13 07:31:55
Socket (84) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:31:55
HD Request # 16 | Historical data for HEZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-13 07:31:55
HD Request # 16 | Received 7258 records from 2018-11-08 08:58:52 to 2018-11-12 13:04:57 (4.2 days) and wrote 7258 records for HEZ8-CME | 2018-11-13 07:31:55
HD Request # 16 | Completion time: 0s | 2018-11-13 07:31:55
HD Request # 16 | Intraday data download complete for HEZ8-CME. Unique request ID: 28 | 2018-11-13 07:31:55
Removed historical data download ID 28 | 2018-11-13 07:31:55
Rithmic Trading | Using primary service for historical data for HEZ8-CME | 2018-11-13 07:31:55
Historical data service client indicated that downloads are not enabled. Symbol: HEZ8-CME. Data Type: Intraday data | 2018-11-13 07:31:55
HD Request # 16 | Download from primary service not started due to error. | 2018-11-13 07:31:55
Socket (84) | Socket gracefully closed by remote side. | 2018-11-13 07:31:55
Socket (84) | Closed. | 2018-11-13 07:31:55
File >> Disconnect selected. | 2018-11-13 07:32:05
Rithmic Trading | Disconnected. | 2018-11-13 07:32:05
Rithmic Trading | Port for executable: 60349 | 2018-11-13 07:32:34
Listening socket (1308). Port 60349 | Closed. | 2018-11-13 07:32:34
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:32:34
Rithmic Trading | Bridge process is running. | 2018-11-13 07:32:36
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60349 | 2018-11-13 07:32:36
DTC Client socket (86) | Creating socket. | 2018-11-13 07:32:36
DTC Client socket (86) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:32:36
Rithmic Trading | Connected to server. | 2018-11-13 07:32:36
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:32:36
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:32:36
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:32:36
Rithmic Trading | Sending logon request message. | 2018-11-13 07:32:36
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:32:36
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:32:36
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:32:36
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:32:37
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:32:37
Rithmic Trading | Received logon response. | 2018-11-13 07:32:37
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:32:37
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:32:37
Rithmic Trading | Logon error received from server | 2018-11-13 07:32:37
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:32:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:37
DTC Client socket (86) | Initiating close of socket by core. | 2018-11-13 07:32:37
DTC Client socket (86) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:32:37
Rithmic Trading | Disconnected. | 2018-11-13 07:32:37
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:37
Rithmic Trading | Port for executable: 60359 | 2018-11-13 07:32:39
Listening socket (1036). Port 60359 | Closed. | 2018-11-13 07:32:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:32:39
DTC Client socket (86) | Socket gracefully closed by remote side. | 2018-11-13 07:32:39
DTC Client socket (86) | Closed. | 2018-11-13 07:32:39
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:32:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60359 | 2018-11-13 07:32:41
DTC Client socket (87) | Creating socket. | 2018-11-13 07:32:41
DTC Client socket (87) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:32:41
DTC Client socket (87) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:32:42 *
DTC Client socket (87) | Initiating close of socket by core. | 2018-11-13 07:32:42
DTC Client socket (87) | Closed. | 2018-11-13 07:32:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:32:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:42
Rithmic Trading | Disconnected. | 2018-11-13 07:32:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:42
Rithmic Trading | Port for executable: 60364 | 2018-11-13 07:32:44
Listening socket (1264). Port 60364 | Closed. | 2018-11-13 07:32:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:32:44
Rithmic Trading | Bridge process is running. | 2018-11-13 07:32:46
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60364 | 2018-11-13 07:32:46
DTC Client socket (88) | Creating socket. | 2018-11-13 07:32:46
DTC Client socket (88) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:32:46
Rithmic Trading | Connected to server. | 2018-11-13 07:32:46
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:32:46
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:32:46
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:32:46
Rithmic Trading | Sending logon request message. | 2018-11-13 07:32:46
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:32:46
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:32:46
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:32:46
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:32:46
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:32:46
Rithmic Trading | Received logon response. | 2018-11-13 07:32:46
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:32:46
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:32:46
Rithmic Trading | Logon error received from server | 2018-11-13 07:32:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:32:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:46
DTC Client socket (88) | Initiating close of socket by core. | 2018-11-13 07:32:46
DTC Client socket (88) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:32:46
Rithmic Trading | Disconnected. | 2018-11-13 07:32:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:46
Rithmic Trading | Port for executable: 60374 | 2018-11-13 07:32:48
Listening socket (1440). Port 60374 | Closed. | 2018-11-13 07:32:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:32:48
DTC Client socket (88) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:32:49 *
DTC Client socket (88) | Socket gracefully closed by remote side. | 2018-11-13 07:32:49
DTC Client socket (88) | Closed. | 2018-11-13 07:32:49
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:32:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60374 | 2018-11-13 07:32:50
DTC Client socket (89) | Creating socket. | 2018-11-13 07:32:50
DTC Client socket (89) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:32:50
DTC Client socket (89) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:32:51 *
DTC Client socket (89) | Initiating close of socket by core. | 2018-11-13 07:32:51
DTC Client socket (89) | Closed. | 2018-11-13 07:32:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:32:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:51
Rithmic Trading | Disconnected. | 2018-11-13 07:32:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:51
Rithmic Trading | Port for executable: 60377 | 2018-11-13 07:32:54
Listening socket (1268). Port 60377 | Closed. | 2018-11-13 07:32:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:32:54
Rithmic Trading | Bridge process is running. | 2018-11-13 07:32:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60377 | 2018-11-13 07:32:56
DTC Client socket (90) | Creating socket. | 2018-11-13 07:32:56
DTC Client socket (90) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:32:56
Rithmic Trading | Connected to server. | 2018-11-13 07:32:56
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:32:56
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:32:56
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:32:56
Rithmic Trading | Sending logon request message. | 2018-11-13 07:32:56
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:32:56
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:32:56
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:32:56
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:32:56
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:32:56
Rithmic Trading | Received logon response. | 2018-11-13 07:32:56
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:32:56
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:32:56
Rithmic Trading | Logon error received from server | 2018-11-13 07:32:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:32:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:56
DTC Client socket (90) | Initiating close of socket by core. | 2018-11-13 07:32:56
DTC Client socket (90) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:32:56
Rithmic Trading | Disconnected. | 2018-11-13 07:32:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:32:56
Rithmic Trading | Port for executable: 60388 | 2018-11-13 07:32:58
Listening socket (1532). Port 60388 | Closed. | 2018-11-13 07:32:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:32:58
DTC Client socket (90) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:32:59 *
DTC Client socket (90) | Socket gracefully closed by remote side. | 2018-11-13 07:32:59
DTC Client socket (90) | Closed. | 2018-11-13 07:32:59
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:33:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60388 | 2018-11-13 07:33:00
DTC Client socket (92) | Creating socket. | 2018-11-13 07:33:00
DTC Client socket (92) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:00
DTC Client socket (92) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:33:01 *
DTC Client socket (92) | Initiating close of socket by core. | 2018-11-13 07:33:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:01
DTC Client socket (92) | Closed. | 2018-11-13 07:33:01
Rithmic Trading | Disconnected. | 2018-11-13 07:33:01
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:01
Rithmic Trading | Port for executable: 60391 | 2018-11-13 07:33:03
Listening socket (1496). Port 60391 | Closed. | 2018-11-13 07:33:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:03
Rithmic Trading | Bridge process is running. | 2018-11-13 07:33:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60391 | 2018-11-13 07:33:05
DTC Client socket (93) | Creating socket. | 2018-11-13 07:33:05
DTC Client socket (93) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:05
Rithmic Trading | Connected to server. | 2018-11-13 07:33:05
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:33:05
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:33:05
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:33:05
Rithmic Trading | Sending logon request message. | 2018-11-13 07:33:05
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:33:05
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:33:05
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:33:05
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:33:06
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:33:06
Rithmic Trading | Received logon response. | 2018-11-13 07:33:06
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:33:06
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:33:06
Rithmic Trading | Logon error received from server | 2018-11-13 07:33:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:06
DTC Client socket (93) | Initiating close of socket by core. | 2018-11-13 07:33:06
DTC Client socket (93) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:33:06
Rithmic Trading | Disconnected. | 2018-11-13 07:33:06
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:06
Rithmic Trading | Port for executable: 60401 | 2018-11-13 07:33:08
Listening socket (1556). Port 60401 | Closed. | 2018-11-13 07:33:08
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:08
DTC Client socket (93) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:33:08 *
DTC Client socket (93) | Socket gracefully closed by remote side. | 2018-11-13 07:33:08
DTC Client socket (93) | Closed. | 2018-11-13 07:33:09
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:33:10
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60401 | 2018-11-13 07:33:10
DTC Client socket (94) | Creating socket. | 2018-11-13 07:33:10
DTC Client socket (94) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:10
DTC Client socket (94) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:33:11 *
DTC Client socket (94) | Initiating close of socket by core. | 2018-11-13 07:33:11
DTC Client socket (94) | Closed. | 2018-11-13 07:33:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:11
Rithmic Trading | Disconnected. | 2018-11-13 07:33:11
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:11
Rithmic Trading | Port for executable: 60403 | 2018-11-13 07:33:13
Listening socket (1580). Port 60403 | Closed. | 2018-11-13 07:33:13
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:13
Rithmic Trading | Bridge process is running. | 2018-11-13 07:33:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60403 | 2018-11-13 07:33:15
DTC Client socket (95) | Creating socket. | 2018-11-13 07:33:15
DTC Client socket (95) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:15
Rithmic Trading | Connected to server. | 2018-11-13 07:33:15
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:33:15
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:33:15
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:33:15
Rithmic Trading | Sending logon request message. | 2018-11-13 07:33:15
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:33:15
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:33:15
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:33:15
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:33:16
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:33:16
Rithmic Trading | Received logon response. | 2018-11-13 07:33:16
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:33:16
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:33:16
Rithmic Trading | Logon error received from server | 2018-11-13 07:33:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:16
DTC Client socket (95) | Initiating close of socket by core. | 2018-11-13 07:33:16
DTC Client socket (95) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:33:16
Rithmic Trading | Disconnected. | 2018-11-13 07:33:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:16
Rithmic Trading | Port for executable: 60414 | 2018-11-13 07:33:18
Listening socket (1552). Port 60414 | Closed. | 2018-11-13 07:33:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:18
DTC Client socket (95) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:33:18 *
DTC Client socket (95) | Socket gracefully closed by remote side. | 2018-11-13 07:33:18
DTC Client socket (95) | Closed. | 2018-11-13 07:33:18
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:33:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60414 | 2018-11-13 07:33:20
DTC Client socket (96) | Creating socket. | 2018-11-13 07:33:20
DTC Client socket (96) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:20
DTC Client socket (96) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:33:21 *
DTC Client socket (96) | Initiating close of socket by core. | 2018-11-13 07:33:21
DTC Client socket (96) | Closed. | 2018-11-13 07:33:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:21
Rithmic Trading | Disconnected. | 2018-11-13 07:33:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:21
Rithmic Trading | Port for executable: 60418 | 2018-11-13 07:33:23
Listening socket (1572). Port 60418 | Closed. | 2018-11-13 07:33:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:23
Rithmic Trading | Bridge process is running. | 2018-11-13 07:33:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60418 | 2018-11-13 07:33:25
DTC Client socket (97) | Creating socket. | 2018-11-13 07:33:25
DTC Client socket (97) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:25
Rithmic Trading | Connected to server. | 2018-11-13 07:33:25
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:33:25
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:33:25
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:33:25
Rithmic Trading | Sending logon request message. | 2018-11-13 07:33:25
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:33:25
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:33:25
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:33:25
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:33:26
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:33:26
Rithmic Trading | Received logon response. | 2018-11-13 07:33:26
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:33:26
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:33:26
Rithmic Trading | Logon error received from server | 2018-11-13 07:33:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:26
DTC Client socket (97) | Initiating close of socket by core. | 2018-11-13 07:33:26
DTC Client socket (97) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:33:26
Rithmic Trading | Disconnected. | 2018-11-13 07:33:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:26
Rithmic Trading | Port for executable: 60429 | 2018-11-13 07:33:28
Listening socket (1528). Port 60429 | Closed. | 2018-11-13 07:33:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:28
DTC Client socket (97) | Socket gracefully closed by remote side. | 2018-11-13 07:33:28
DTC Client socket (97) | Closed. | 2018-11-13 07:33:28
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:33:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60429 | 2018-11-13 07:33:30
DTC Client socket (98) | Creating socket. | 2018-11-13 07:33:30
DTC Client socket (98) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:30
DTC Client socket (98) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:33:31 *
DTC Client socket (98) | Initiating close of socket by core. | 2018-11-13 07:33:31
DTC Client socket (98) | Closed. | 2018-11-13 07:33:31
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:31
Rithmic Trading | Disconnected. | 2018-11-13 07:33:31
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:31
Rithmic Trading | Port for executable: 60437 | 2018-11-13 07:33:33
Listening socket (1440). Port 60437 | Closed. | 2018-11-13 07:33:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:33
Rithmic Trading | Bridge process is running. | 2018-11-13 07:33:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60437 | 2018-11-13 07:33:35
DTC Client socket (99) | Creating socket. | 2018-11-13 07:33:35
DTC Client socket (99) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:35
Rithmic Trading | Connected to server. | 2018-11-13 07:33:35
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:33:35
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:33:35
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:33:35
Rithmic Trading | Sending logon request message. | 2018-11-13 07:33:35
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:33:35
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:33:35
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:33:35
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:33:36
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:33:36
Rithmic Trading | Received logon response. | 2018-11-13 07:33:36
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:33:36
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:33:36
Rithmic Trading | Logon error received from server | 2018-11-13 07:33:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:36
DTC Client socket (99) | Initiating close of socket by core. | 2018-11-13 07:33:36
DTC Client socket (99) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:33:36
Rithmic Trading | Disconnected. | 2018-11-13 07:33:36
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:36
Rithmic Trading | Port for executable: 60447 | 2018-11-13 07:33:38
Listening socket (1552). Port 60447 | Closed. | 2018-11-13 07:33:38
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:38
DTC Client socket (99) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:33:38 *
DTC Client socket (99) | Socket gracefully closed by remote side. | 2018-11-13 07:33:38
DTC Client socket (99) | Closed. | 2018-11-13 07:33:38
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:33:40
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60447 | 2018-11-13 07:33:40
DTC Client socket (100) | Creating socket. | 2018-11-13 07:33:40
DTC Client socket (100) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:40
DTC Client socket (100) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:33:41 *
DTC Client socket (100) | Initiating close of socket by core. | 2018-11-13 07:33:41
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:41
DTC Client socket (100) | Closed. | 2018-11-13 07:33:41
Rithmic Trading | Disconnected. | 2018-11-13 07:33:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:41
Rithmic Trading | Port for executable: 60450 | 2018-11-13 07:33:43
Listening socket (1036). Port 60450 | Closed. | 2018-11-13 07:33:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:43
Rithmic Trading | Bridge process is running. | 2018-11-13 07:33:45
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60450 | 2018-11-13 07:33:45
DTC Client socket (101) | Creating socket. | 2018-11-13 07:33:45
DTC Client socket (101) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:45
Rithmic Trading | Connected to server. | 2018-11-13 07:33:45
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:33:45
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:33:45
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:33:45
Rithmic Trading | Sending logon request message. | 2018-11-13 07:33:45
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:33:45
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:33:45
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:33:45
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:33:46
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:33:46
Rithmic Trading | Received logon response. | 2018-11-13 07:33:46
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:33:46
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:33:46
Rithmic Trading | Logon error received from server | 2018-11-13 07:33:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:46
DTC Client socket (101) | Initiating close of socket by core. | 2018-11-13 07:33:46
DTC Client socket (101) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:33:46
Rithmic Trading | Disconnected. | 2018-11-13 07:33:46
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:46
Rithmic Trading | Port for executable: 60461 | 2018-11-13 07:33:48
Listening socket (1572). Port 60461 | Closed. | 2018-11-13 07:33:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:48
DTC Client socket (101) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:33:49 *
DTC Client socket (101) | Socket gracefully closed by remote side. | 2018-11-13 07:33:49
DTC Client socket (101) | Closed. | 2018-11-13 07:33:49
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:33:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60461 | 2018-11-13 07:33:50
DTC Client socket (102) | Creating socket. | 2018-11-13 07:33:50
DTC Client socket (102) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:50
DTC Client socket (102) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:33:51 *
DTC Client socket (102) | Initiating close of socket by core. | 2018-11-13 07:33:51
DTC Client socket (102) | Closed. | 2018-11-13 07:33:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:51
Rithmic Trading | Disconnected. | 2018-11-13 07:33:51
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:51
Rithmic Trading | Port for executable: 60463 | 2018-11-13 07:33:53
Listening socket (1352). Port 60463 | Closed. | 2018-11-13 07:33:53
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:53
Rithmic Trading | Bridge process is running. | 2018-11-13 07:33:55
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60463 | 2018-11-13 07:33:55
DTC Client socket (103) | Creating socket. | 2018-11-13 07:33:55
DTC Client socket (103) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:33:55
Rithmic Trading | Connected to server. | 2018-11-13 07:33:55
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:33:55
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:33:55
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:33:55
Rithmic Trading | Sending logon request message. | 2018-11-13 07:33:55
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:33:55
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:33:55
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:33:55
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:33:56
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:33:56
Rithmic Trading | Received logon response. | 2018-11-13 07:33:56
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:33:56
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:33:56
Rithmic Trading | Logon error received from server | 2018-11-13 07:33:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:33:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:56
DTC Client socket (103) | Initiating close of socket by core. | 2018-11-13 07:33:56
DTC Client socket (103) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:33:56
Rithmic Trading | Disconnected. | 2018-11-13 07:33:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:33:56
Rithmic Trading | Port for executable: 60475 | 2018-11-13 07:33:58
Listening socket (1580). Port 60475 | Closed. | 2018-11-13 07:33:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:33:58
DTC Client socket (103) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:33:58 *
DTC Client socket (103) | Socket gracefully closed by remote side. | 2018-11-13 07:33:58
DTC Client socket (103) | Closed. | 2018-11-13 07:33:58
Rithmic Trading | Bridge process is running. | 2018-11-13 07:34:00
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60475 | 2018-11-13 07:34:00
DTC Client socket (105) | Creating socket. | 2018-11-13 07:34:00
DTC Client socket (105) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:00
Rithmic Trading | Connected to server. | 2018-11-13 07:34:00
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:34:00
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:34:00
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:34:00
Rithmic Trading | Sending logon request message. | 2018-11-13 07:34:00
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:34:00
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:34:00
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:34:00
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:34:01
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:34:01
Rithmic Trading | Received logon response. | 2018-11-13 07:34:01
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:34:01
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:34:01
Rithmic Trading | Logon error received from server | 2018-11-13 07:34:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:01
DTC Client socket (105) | Initiating close of socket by core. | 2018-11-13 07:34:01
DTC Client socket (105) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:34:01
Rithmic Trading | Disconnected. | 2018-11-13 07:34:01
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:01
Rithmic Trading | Port for executable: 60487 | 2018-11-13 07:34:03
Listening socket (1608). Port 60487 | Closed. | 2018-11-13 07:34:03
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:03
DTC Client socket (105) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:34:03 *
DTC Client socket (105) | Socket gracefully closed by remote side. | 2018-11-13 07:34:03
DTC Client socket (105) | Closed. | 2018-11-13 07:34:03
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:34:05
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60487 | 2018-11-13 07:34:05
DTC Client socket (106) | Creating socket. | 2018-11-13 07:34:05
DTC Client socket (106) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:05
DTC Client socket (106) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:34:06 *
DTC Client socket (106) | Initiating close of socket by core. | 2018-11-13 07:34:06
DTC Client socket (106) | Closed. | 2018-11-13 07:34:06
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:06
Rithmic Trading | Disconnected. | 2018-11-13 07:34:06
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:06
Rithmic Trading | Port for executable: 60490 | 2018-11-13 07:34:08
Listening socket (1592). Port 60490 | Closed. | 2018-11-13 07:34:08
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:08
Rithmic Trading | Bridge process is running. | 2018-11-13 07:34:10
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60490 | 2018-11-13 07:34:10
DTC Client socket (107) | Creating socket. | 2018-11-13 07:34:10
DTC Client socket (107) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:10
Rithmic Trading | Connected to server. | 2018-11-13 07:34:10
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:34:10
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:34:10
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:34:10
Rithmic Trading | Sending logon request message. | 2018-11-13 07:34:10
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:34:10
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:34:10
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:34:10
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:34:11
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:34:11
Rithmic Trading | Received logon response. | 2018-11-13 07:34:11
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:34:11
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:34:11
Rithmic Trading | Logon error received from server | 2018-11-13 07:34:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:11
DTC Client socket (107) | Initiating close of socket by core. | 2018-11-13 07:34:11
DTC Client socket (107) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:34:11
Rithmic Trading | Disconnected. | 2018-11-13 07:34:11
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:11
Rithmic Trading | Port for executable: 60500 | 2018-11-13 07:34:13
Listening socket (1608). Port 60500 | Closed. | 2018-11-13 07:34:13
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:13
DTC Client socket (107) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:34:13 *
DTC Client socket (107) | Socket gracefully closed by remote side. | 2018-11-13 07:34:13
DTC Client socket (107) | Closed. | 2018-11-13 07:34:13
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:34:15
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60500 | 2018-11-13 07:34:15
DTC Client socket (108) | Creating socket. | 2018-11-13 07:34:15
DTC Client socket (108) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:15
DTC Client socket (108) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:34:16 *
DTC Client socket (108) | Initiating close of socket by core. | 2018-11-13 07:34:16
DTC Client socket (108) | Closed. | 2018-11-13 07:34:16
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:16
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:16
Rithmic Trading | Disconnected. | 2018-11-13 07:34:16
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:16
Rithmic Trading | Port for executable: 60503 | 2018-11-13 07:34:18
Listening socket (1532). Port 60503 | Closed. | 2018-11-13 07:34:18
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:18
Rithmic Trading | Bridge process is running. | 2018-11-13 07:34:20
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60503 | 2018-11-13 07:34:20
DTC Client socket (109) | Creating socket. | 2018-11-13 07:34:20
DTC Client socket (109) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:20
Rithmic Trading | Connected to server. | 2018-11-13 07:34:20
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:34:20
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:34:20
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:34:20
Rithmic Trading | Sending logon request message. | 2018-11-13 07:34:20
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:34:20
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:34:20
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:34:20
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:34:20
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:34:20
Rithmic Trading | Received logon response. | 2018-11-13 07:34:21
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:34:21
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:34:21
Rithmic Trading | Logon error received from server | 2018-11-13 07:34:21
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:21
DTC Client socket (109) | Initiating close of socket by core. | 2018-11-13 07:34:21
DTC Client socket (109) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:34:21
Rithmic Trading | Disconnected. | 2018-11-13 07:34:21
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:21
Rithmic Trading | Port for executable: 60513 | 2018-11-13 07:34:23
Listening socket (1592). Port 60513 | Closed. | 2018-11-13 07:34:23
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:23
DTC Client socket (109) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:34:23 *
DTC Client socket (109) | Socket gracefully closed by remote side. | 2018-11-13 07:34:23
DTC Client socket (109) | Closed. | 2018-11-13 07:34:23
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:34:25
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60513 | 2018-11-13 07:34:25
DTC Client socket (110) | Creating socket. | 2018-11-13 07:34:25
DTC Client socket (110) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:25
DTC Client socket (110) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:34:26 *
DTC Client socket (110) | Initiating close of socket by core. | 2018-11-13 07:34:26
DTC Client socket (110) | Closed. | 2018-11-13 07:34:26
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:26
Rithmic Trading | Disconnected. | 2018-11-13 07:34:26
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:26
Rithmic Trading | Port for executable: 60521 | 2018-11-13 07:34:28
Listening socket (1608). Port 60521 | Closed. | 2018-11-13 07:34:28
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:28
Rithmic Trading | Bridge process is running. | 2018-11-13 07:34:30
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60521 | 2018-11-13 07:34:30
DTC Client socket (111) | Creating socket. | 2018-11-13 07:34:30
DTC Client socket (111) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:30
Rithmic Trading | Connected to server. | 2018-11-13 07:34:30
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:34:30
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:34:30
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:34:30
Rithmic Trading | Sending logon request message. | 2018-11-13 07:34:30
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:34:30
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:34:30
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:34:30
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:34:30
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:34:30
Rithmic Trading | Received logon response. | 2018-11-13 07:34:30
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:34:30
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:34:30
Rithmic Trading | Logon error received from server | 2018-11-13 07:34:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:30
DTC Client socket (111) | Initiating close of socket by core. | 2018-11-13 07:34:30
DTC Client socket (111) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:34:30
Rithmic Trading | Disconnected. | 2018-11-13 07:34:30
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:30
Rithmic Trading | Port for executable: 60533 | 2018-11-13 07:34:32
Listening socket (1236). Port 60533 | Closed. | 2018-11-13 07:34:32
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:32
DTC Client socket (111) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:34:33 *
DTC Client socket (111) | Socket gracefully closed by remote side. | 2018-11-13 07:34:33
DTC Client socket (111) | Closed. | 2018-11-13 07:34:33
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:34:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60533 | 2018-11-13 07:34:34
DTC Client socket (112) | Creating socket. | 2018-11-13 07:34:34
DTC Client socket (112) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:34
DTC Client socket (112) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:34:35 *
DTC Client socket (112) | Initiating close of socket by core. | 2018-11-13 07:34:35
DTC Client socket (112) | Closed. | 2018-11-13 07:34:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:35
Rithmic Trading | Disconnected. | 2018-11-13 07:34:35
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:35
Rithmic Trading | Port for executable: 60537 | 2018-11-13 07:34:37
Listening socket (648). Port 60537 | Closed. | 2018-11-13 07:34:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:37
Rithmic Trading | Bridge process is running. | 2018-11-13 07:34:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60537 | 2018-11-13 07:34:39
DTC Client socket (113) | Creating socket. | 2018-11-13 07:34:39
DTC Client socket (113) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:39
Rithmic Trading | Connected to server. | 2018-11-13 07:34:39
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:34:39
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:34:39
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:34:39
Rithmic Trading | Sending logon request message. | 2018-11-13 07:34:39
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:34:39
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:34:39
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:34:39
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:34:40
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:34:40
Rithmic Trading | Received logon response. | 2018-11-13 07:34:40
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:34:40
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:34:40
Rithmic Trading | Logon error received from server | 2018-11-13 07:34:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:40
DTC Client socket (113) | Initiating close of socket by core. | 2018-11-13 07:34:40
DTC Client socket (113) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:34:40
Rithmic Trading | Disconnected. | 2018-11-13 07:34:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:40
Rithmic Trading | Port for executable: 60547 | 2018-11-13 07:34:42
Listening socket (648). Port 60547 | Closed. | 2018-11-13 07:34:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:42
DTC Client socket (113) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:34:42 *
DTC Client socket (113) | Socket gracefully closed by remote side. | 2018-11-13 07:34:42
DTC Client socket (113) | Closed. | 2018-11-13 07:34:42
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:34:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60547 | 2018-11-13 07:34:44
DTC Client socket (114) | Creating socket. | 2018-11-13 07:34:44
DTC Client socket (114) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:44
DTC Client socket (114) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:34:45 *
DTC Client socket (114) | Initiating close of socket by core. | 2018-11-13 07:34:45
DTC Client socket (114) | Closed. | 2018-11-13 07:34:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:45
Rithmic Trading | Disconnected. | 2018-11-13 07:34:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:45
Rithmic Trading | Port for executable: 60549 | 2018-11-13 07:34:47
Listening socket (1512). Port 60549 | Closed. | 2018-11-13 07:34:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:47
Rithmic Trading | Bridge process is running. | 2018-11-13 07:34:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60549 | 2018-11-13 07:34:49
DTC Client socket (115) | Creating socket. | 2018-11-13 07:34:49
DTC Client socket (115) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:49
Rithmic Trading | Connected to server. | 2018-11-13 07:34:49
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:34:49
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:34:49
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:34:49
Rithmic Trading | Sending logon request message. | 2018-11-13 07:34:49
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:34:49
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:34:49
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:34:49
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:34:50
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:34:50
Rithmic Trading | Received logon response. | 2018-11-13 07:34:50
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:34:50
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:34:50
Rithmic Trading | Logon error received from server | 2018-11-13 07:34:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:50
DTC Client socket (115) | Initiating close of socket by core. | 2018-11-13 07:34:50
DTC Client socket (115) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:34:50
Rithmic Trading | Disconnected. | 2018-11-13 07:34:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:50
Rithmic Trading | Port for executable: 60559 | 2018-11-13 07:34:52
Listening socket (1380). Port 60559 | Closed. | 2018-11-13 07:34:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:52
DTC Client socket (115) | Socket gracefully closed by remote side. | 2018-11-13 07:34:52
DTC Client socket (115) | Closed. | 2018-11-13 07:34:52
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:34:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60559 | 2018-11-13 07:34:54
DTC Client socket (116) | Creating socket. | 2018-11-13 07:34:54
DTC Client socket (116) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:54
DTC Client socket (116) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:34:55 *
DTC Client socket (116) | Initiating close of socket by core. | 2018-11-13 07:34:55
DTC Client socket (116) | Closed. | 2018-11-13 07:34:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:34:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:55
Rithmic Trading | Disconnected. | 2018-11-13 07:34:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:34:55
Rithmic Trading | Port for executable: 60561 | 2018-11-13 07:34:57
Listening socket (1452). Port 60561 | Closed. | 2018-11-13 07:34:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:34:57
Rithmic Trading | Bridge process is running. | 2018-11-13 07:34:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60561 | 2018-11-13 07:34:59
DTC Client socket (118) | Creating socket. | 2018-11-13 07:34:59
DTC Client socket (118) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:34:59
Rithmic Trading | Connected to server. | 2018-11-13 07:34:59
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:34:59
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:34:59
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:34:59
Rithmic Trading | Sending logon request message. | 2018-11-13 07:34:59
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:34:59
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:34:59
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:34:59
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:35:00
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:35:00
Rithmic Trading | Received logon response. | 2018-11-13 07:35:00
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:35:00
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:35:00
Rithmic Trading | Logon error received from server | 2018-11-13 07:35:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:00
DTC Client socket (118) | Initiating close of socket by core. | 2018-11-13 07:35:00
DTC Client socket (118) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:35:00
Rithmic Trading | Disconnected. | 2018-11-13 07:35:00
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:00
Rithmic Trading | Port for executable: 60572 | 2018-11-13 07:35:02
Listening socket (1592). Port 60572 | Closed. | 2018-11-13 07:35:02
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:02
DTC Client socket (118) | Socket gracefully closed by remote side. | 2018-11-13 07:35:02
DTC Client socket (118) | Closed. | 2018-11-13 07:35:02
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60572 | 2018-11-13 07:35:04
DTC Client socket (119) | Creating socket. | 2018-11-13 07:35:04
DTC Client socket (119) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:04
DTC Client socket (119) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:35:05 *
DTC Client socket (119) | Initiating close of socket by core. | 2018-11-13 07:35:05
DTC Client socket (119) | Closed. | 2018-11-13 07:35:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:05
Rithmic Trading | Disconnected. | 2018-11-13 07:35:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:05
Rithmic Trading | Port for executable: 60574 | 2018-11-13 07:35:07
Listening socket (1444). Port 60574 | Closed. | 2018-11-13 07:35:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:07
Rithmic Trading | Bridge process is running. | 2018-11-13 07:35:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60574 | 2018-11-13 07:35:09
DTC Client socket (120) | Creating socket. | 2018-11-13 07:35:09
DTC Client socket (120) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:09
Rithmic Trading | Connected to server. | 2018-11-13 07:35:09
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:35:09
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:35:09
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:35:09
Rithmic Trading | Sending logon request message. | 2018-11-13 07:35:09
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:35:09
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:35:09
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:35:09
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:35:10
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:35:10
Rithmic Trading | Received logon response. | 2018-11-13 07:35:10
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:35:10
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:35:10
Rithmic Trading | Logon error received from server | 2018-11-13 07:35:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:10
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:10
DTC Client socket (120) | Initiating close of socket by core. | 2018-11-13 07:35:10
DTC Client socket (120) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:35:10
Rithmic Trading | Disconnected. | 2018-11-13 07:35:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:10
Rithmic Trading | Port for executable: 60586 | 2018-11-13 07:35:12
Listening socket (1476). Port 60586 | Closed. | 2018-11-13 07:35:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:12
DTC Client socket (120) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:35:12 *
DTC Client socket (120) | Socket gracefully closed by remote side. | 2018-11-13 07:35:12
DTC Client socket (120) | Closed. | 2018-11-13 07:35:12
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60586 | 2018-11-13 07:35:14
DTC Client socket (121) | Creating socket. | 2018-11-13 07:35:14
DTC Client socket (121) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:14
DTC Client socket (121) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:35:15 *
DTC Client socket (121) | Initiating close of socket by core. | 2018-11-13 07:35:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:15
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:15
DTC Client socket (121) | Closed. | 2018-11-13 07:35:15
Rithmic Trading | Disconnected. | 2018-11-13 07:35:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:15
Rithmic Trading | Port for executable: 60588 | 2018-11-13 07:35:17
Listening socket (832). Port 60588 | Closed. | 2018-11-13 07:35:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:17
Rithmic Trading | Bridge process is running. | 2018-11-13 07:35:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60588 | 2018-11-13 07:35:19
DTC Client socket (122) | Creating socket. | 2018-11-13 07:35:19
DTC Client socket (122) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:19
Rithmic Trading | Connected to server. | 2018-11-13 07:35:19
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:35:19
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:35:19
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:35:19
Rithmic Trading | Sending logon request message. | 2018-11-13 07:35:19
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:35:19
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:35:19
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:35:19
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:35:19
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:35:19
Rithmic Trading | Received logon response. | 2018-11-13 07:35:19
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:35:19
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:35:19
Rithmic Trading | Logon error received from server | 2018-11-13 07:35:19
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:19
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:19
DTC Client socket (122) | Initiating close of socket by core. | 2018-11-13 07:35:19
DTC Client socket (122) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:35:19
Rithmic Trading | Disconnected. | 2018-11-13 07:35:19
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:19
Rithmic Trading | Port for executable: 60598 | 2018-11-13 07:35:21
Listening socket (1600). Port 60598 | Closed. | 2018-11-13 07:35:21
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:21
DTC Client socket (122) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:35:22 *
DTC Client socket (122) | Socket gracefully closed by remote side. | 2018-11-13 07:35:22
DTC Client socket (122) | Closed. | 2018-11-13 07:35:22
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:23
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60598 | 2018-11-13 07:35:23
DTC Client socket (123) | Creating socket. | 2018-11-13 07:35:23
DTC Client socket (123) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:23
DTC Client socket (123) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:35:24 *
DTC Client socket (123) | Initiating close of socket by core. | 2018-11-13 07:35:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:24
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:25
DTC Client socket (123) | Closed. | 2018-11-13 07:35:25
Rithmic Trading | Disconnected. | 2018-11-13 07:35:25
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:25
Rithmic Trading | Port for executable: 60600 | 2018-11-13 07:35:27
Listening socket (1232). Port 60600 | Closed. | 2018-11-13 07:35:27
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:27
Rithmic Trading | Bridge process is running. | 2018-11-13 07:35:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60600 | 2018-11-13 07:35:29
DTC Client socket (124) | Creating socket. | 2018-11-13 07:35:29
DTC Client socket (124) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:29
Rithmic Trading | Connected to server. | 2018-11-13 07:35:29
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:35:29
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:35:29
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:35:29
Rithmic Trading | Sending logon request message. | 2018-11-13 07:35:29
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:35:29
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:35:29
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:35:29
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:35:30
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:35:30
Rithmic Trading | Received logon response. | 2018-11-13 07:35:30
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:35:30
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:35:30
Rithmic Trading | Logon error received from server | 2018-11-13 07:35:30
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:30
DTC Client socket (124) | Initiating close of socket by core. | 2018-11-13 07:35:30
DTC Client socket (124) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:35:30
Rithmic Trading | Disconnected. | 2018-11-13 07:35:30
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:30
Rithmic Trading | Port for executable: 60611 | 2018-11-13 07:35:32
Listening socket (1052). Port 60611 | Closed. | 2018-11-13 07:35:32
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:32
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:34
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60611 | 2018-11-13 07:35:34
DTC Client socket (125) | Creating socket. | 2018-11-13 07:35:34
DTC Client socket (125) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:34
DTC Client socket (125) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:35:35 *
DTC Client socket (125) | Initiating close of socket by core. | 2018-11-13 07:35:35
DTC Client socket (125) | Closed. | 2018-11-13 07:35:35
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:35
Rithmic Trading | Disconnected. | 2018-11-13 07:35:35
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:35
Rithmic Trading | Port for executable: 60614 | 2018-11-13 07:35:37
Listening socket (1600). Port 60614 | Closed. | 2018-11-13 07:35:37
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:37
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:39
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60614 | 2018-11-13 07:35:39
DTC Client socket (126) | Creating socket. | 2018-11-13 07:35:39
DTC Client socket (126) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:39
DTC Client socket (126) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:35:40 *
DTC Client socket (126) | Initiating close of socket by core. | 2018-11-13 07:35:40
DTC Client socket (126) | Closed. | 2018-11-13 07:35:40
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:40
Rithmic Trading | Disconnected. | 2018-11-13 07:35:40
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:40
Rithmic Trading | Port for executable: 60616 | 2018-11-13 07:35:42
Listening socket (1612). Port 60616 | Closed. | 2018-11-13 07:35:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:42
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60616 | 2018-11-13 07:35:44
DTC Client socket (127) | Creating socket. | 2018-11-13 07:35:44
DTC Client socket (127) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:44
DTC Client socket (127) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:35:45 *
DTC Client socket (127) | Initiating close of socket by core. | 2018-11-13 07:35:45
DTC Client socket (127) | Closed. | 2018-11-13 07:35:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:45
Rithmic Trading | Disconnected. | 2018-11-13 07:35:45
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:45
Rithmic Trading | Port for executable: 60620 | 2018-11-13 07:35:47
Listening socket (1612). Port 60620 | Closed. | 2018-11-13 07:35:47
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:47
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:49
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60620 | 2018-11-13 07:35:49
DTC Client socket (128) | Creating socket. | 2018-11-13 07:35:49
DTC Client socket (128) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:49
DTC Client socket (128) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:35:50 *
DTC Client socket (128) | Initiating close of socket by core. | 2018-11-13 07:35:50
DTC Client socket (128) | Closed. | 2018-11-13 07:35:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:50
Rithmic Trading | Disconnected. | 2018-11-13 07:35:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:50
DTC Client socket (124) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:35:52 *
DTC Client socket (124) | Socket gracefully closed by remote side. | 2018-11-13 07:35:52
DTC Client socket (124) | Closed. | 2018-11-13 07:35:52
Rithmic Trading | Port for executable: 60622 | 2018-11-13 07:35:52
Listening socket (1052). Port 60622 | Closed. | 2018-11-13 07:35:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:52
Rithmic Trading | Bridge process is running. | 2018-11-13 07:35:54
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60622 | 2018-11-13 07:35:54
DTC Client socket (129) | Creating socket. | 2018-11-13 07:35:54
DTC Client socket (129) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:54
Rithmic Trading | Connected to server. | 2018-11-13 07:35:54
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:35:54
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:35:54
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:35:54
Rithmic Trading | Sending logon request message. | 2018-11-13 07:35:54
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:35:54
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:35:54
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:35:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:35:55
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:35:55
Rithmic Trading | Received logon response. | 2018-11-13 07:35:55
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:35:55
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:35:55
Rithmic Trading | Logon error received from server | 2018-11-13 07:35:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:35:55
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:55
DTC Client socket (129) | Initiating close of socket by core. | 2018-11-13 07:35:55
DTC Client socket (129) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:35:55
Rithmic Trading | Disconnected. | 2018-11-13 07:35:55
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:35:55
Rithmic Trading | Port for executable: 60632 | 2018-11-13 07:35:57
Listening socket (1284). Port 60632 | Closed. | 2018-11-13 07:35:57
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:35:57
DTC Client socket (129) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:35:57 *
DTC Client socket (129) | Socket gracefully closed by remote side. | 2018-11-13 07:35:57
DTC Client socket (129) | Closed. | 2018-11-13 07:35:57
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:35:59
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60632 | 2018-11-13 07:35:59
DTC Client socket (131) | Creating socket. | 2018-11-13 07:35:59
DTC Client socket (131) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:35:59
DTC Client socket (131) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:36:00 *
DTC Client socket (131) | Initiating close of socket by core. | 2018-11-13 07:36:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:00
DTC Client socket (131) | Closed. | 2018-11-13 07:36:00
Rithmic Trading | Disconnected. | 2018-11-13 07:36:00
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:00
Rithmic Trading | Port for executable: 60636 | 2018-11-13 07:36:02
Listening socket (1640). Port 60636 | Closed. | 2018-11-13 07:36:02
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:02
Rithmic Trading | Bridge process is running. | 2018-11-13 07:36:04
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60636 | 2018-11-13 07:36:04
DTC Client socket (132) | Creating socket. | 2018-11-13 07:36:04
DTC Client socket (132) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:04
Rithmic Trading | Connected to server. | 2018-11-13 07:36:04
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:36:04
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:36:04
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:36:04
Rithmic Trading | Sending logon request message. | 2018-11-13 07:36:04
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:36:04
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:36:04
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:36:04
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:36:05
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:36:05
Rithmic Trading | Received logon response. | 2018-11-13 07:36:05
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:36:05
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:36:05
Rithmic Trading | Logon error received from server | 2018-11-13 07:36:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:05
DTC Client socket (132) | Initiating close of socket by core. | 2018-11-13 07:36:05
DTC Client socket (132) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:36:05
Rithmic Trading | Disconnected. | 2018-11-13 07:36:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:05
Rithmic Trading | Port for executable: 60646 | 2018-11-13 07:36:07
Listening socket (1632). Port 60646 | Closed. | 2018-11-13 07:36:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:07
DTC Client socket (132) | Socket gracefully closed by remote side. | 2018-11-13 07:36:07
DTC Client socket (132) | Closed. | 2018-11-13 07:36:07
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:36:09
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60646 | 2018-11-13 07:36:09
DTC Client socket (133) | Creating socket. | 2018-11-13 07:36:09
DTC Client socket (133) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:09
DTC Client socket (133) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:36:10 *
DTC Client socket (133) | Initiating close of socket by core. | 2018-11-13 07:36:10
DTC Client socket (133) | Closed. | 2018-11-13 07:36:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:10
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:10
Rithmic Trading | Disconnected. | 2018-11-13 07:36:10
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:10
Rithmic Trading | Port for executable: 60648 | 2018-11-13 07:36:12
Listening socket (1580). Port 60648 | Closed. | 2018-11-13 07:36:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:12
Rithmic Trading | Bridge process is running. | 2018-11-13 07:36:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60648 | 2018-11-13 07:36:14
DTC Client socket (134) | Creating socket. | 2018-11-13 07:36:14
DTC Client socket (134) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:14
Rithmic Trading | Connected to server. | 2018-11-13 07:36:14
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:36:14
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:36:14
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:36:14
Rithmic Trading | Sending logon request message. | 2018-11-13 07:36:14
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:36:14
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:36:14
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:36:14
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:36:14
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:36:15
Rithmic Trading | Received logon response. | 2018-11-13 07:36:15
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:36:15
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:36:15
Rithmic Trading | Logon error received from server | 2018-11-13 07:36:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:15
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:15
DTC Client socket (134) | Initiating close of socket by core. | 2018-11-13 07:36:15
DTC Client socket (134) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:36:15
Rithmic Trading | Disconnected. | 2018-11-13 07:36:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:15
Rithmic Trading | Port for executable: 60658 | 2018-11-13 07:36:17
Listening socket (1648). Port 60658 | Closed. | 2018-11-13 07:36:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:17
DTC Client socket (134) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:36:17 *
DTC Client socket (134) | Socket gracefully closed by remote side. | 2018-11-13 07:36:17
DTC Client socket (134) | Closed. | 2018-11-13 07:36:17
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:36:19
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60658 | 2018-11-13 07:36:19
DTC Client socket (135) | Creating socket. | 2018-11-13 07:36:19
DTC Client socket (135) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:19
DTC Client socket (135) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:36:20 *
DTC Client socket (135) | Initiating close of socket by core. | 2018-11-13 07:36:20
DTC Client socket (135) | Closed. | 2018-11-13 07:36:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:20
Rithmic Trading | Disconnected. | 2018-11-13 07:36:20
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:20
Rithmic Trading | Port for executable: 60664 | 2018-11-13 07:36:22
Listening socket (832). Port 60664 | Closed. | 2018-11-13 07:36:22
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:22
Rithmic Trading | Bridge process is running. | 2018-11-13 07:36:24
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60664 | 2018-11-13 07:36:24
DTC Client socket (136) | Creating socket. | 2018-11-13 07:36:24
DTC Client socket (136) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:24
Rithmic Trading | Connected to server. | 2018-11-13 07:36:24
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:36:24
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:36:24
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:36:24
Rithmic Trading | Sending logon request message. | 2018-11-13 07:36:24
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:36:24
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:36:24
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:36:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:36:24
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:36:24
Rithmic Trading | Received logon response. | 2018-11-13 07:36:24
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:36:24
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:36:24
Rithmic Trading | Logon error received from server | 2018-11-13 07:36:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:24
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:24
DTC Client socket (136) | Initiating close of socket by core. | 2018-11-13 07:36:24
DTC Client socket (136) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:36:24
Rithmic Trading | Disconnected. | 2018-11-13 07:36:24
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:24
Rithmic Trading | Port for executable: 60674 | 2018-11-13 07:36:26
Listening socket (1636). Port 60674 | Closed. | 2018-11-13 07:36:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:26
DTC Client socket (136) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:36:27 *
DTC Client socket (136) | Socket gracefully closed by remote side. | 2018-11-13 07:36:27
DTC Client socket (136) | Closed. | 2018-11-13 07:36:27
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:36:28
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60674 | 2018-11-13 07:36:28
DTC Client socket (137) | Creating socket. | 2018-11-13 07:36:28
DTC Client socket (137) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:28
DTC Client socket (137) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:36:29 *
DTC Client socket (137) | Initiating close of socket by core. | 2018-11-13 07:36:29
DTC Client socket (137) | Closed. | 2018-11-13 07:36:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:29
Rithmic Trading | Disconnected. | 2018-11-13 07:36:29
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:29
Rithmic Trading | Port for executable: 60676 | 2018-11-13 07:36:31
Listening socket (1496). Port 60676 | Closed. | 2018-11-13 07:36:31
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:31
Rithmic Trading | Bridge process is running. | 2018-11-13 07:36:33
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60676 | 2018-11-13 07:36:33
DTC Client socket (138) | Creating socket. | 2018-11-13 07:36:33
DTC Client socket (138) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:33
Rithmic Trading | Connected to server. | 2018-11-13 07:36:33
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:36:33
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:36:33
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:36:33
Rithmic Trading | Sending logon request message. | 2018-11-13 07:36:33
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:36:33
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:36:33
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:36:33
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:36:34
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:36:34
Rithmic Trading | Received logon response. | 2018-11-13 07:36:34
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:36:34
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:36:34
Rithmic Trading | Logon error received from server | 2018-11-13 07:36:34
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:34
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:34
DTC Client socket (138) | Initiating close of socket by core. | 2018-11-13 07:36:34
DTC Client socket (138) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:36:34
Rithmic Trading | Disconnected. | 2018-11-13 07:36:34
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:34
Rithmic Trading | Port for executable: 60686 | 2018-11-13 07:36:36
Listening socket (1496). Port 60686 | Closed. | 2018-11-13 07:36:36
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:36:36
DTC Client socket (138) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:36:37 *
DTC Client socket (138) | Socket gracefully closed by remote side. | 2018-11-13 07:36:37
DTC Client socket (138) | Closed. | 2018-11-13 07:36:37
Rithmic Trading | Bridge process is not running! | 2018-11-13 07:36:38
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60686 | 2018-11-13 07:36:38
DTC Client socket (139) | Creating socket. | 2018-11-13 07:36:38
DTC Client socket (139) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:36:38
DTC Client socket (139) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-13 07:36:39 *
DTC Client socket (139) | Initiating close of socket by core. | 2018-11-13 07:36:39
DTC Client socket (139) | Closed. | 2018-11-13 07:36:39
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:36:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:39
Rithmic Trading | Disconnected. | 2018-11-13 07:36:39
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:36:39
Rithmic Trading | Port for executable: 60701 | 2018-11-13 07:38:39
Listening socket (1664). Port 60701 | Closed. | 2018-11-13 07:38:39
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:38:39
Rithmic Trading | Bridge process is running. | 2018-11-13 07:38:41
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60701 | 2018-11-13 07:38:41
DTC Client socket (142) | Creating socket. | 2018-11-13 07:38:41
DTC Client socket (142) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:38:41
Rithmic Trading | Connected to server. | 2018-11-13 07:38:41
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:38:41
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:38:41
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:38:42
Rithmic Trading | Sending logon request message. | 2018-11-13 07:38:42
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:38:42
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:38:42
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:38:42
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:38:42
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:38:42
Rithmic Trading | Received logon response. | 2018-11-13 07:38:42
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:38:42
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:38:42
Rithmic Trading | Logon error received from server | 2018-11-13 07:38:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:38:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:38:42
DTC Client socket (142) | Initiating close of socket by core. | 2018-11-13 07:38:42
DTC Client socket (142) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:38:42
Rithmic Trading | Disconnected. | 2018-11-13 07:38:42
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:38:42
DTC Client socket (142) | Socket gracefully closed by remote side. | 2018-11-13 07:38:45
DTC Client socket (142) | Closed. | 2018-11-13 07:38:45
Rithmic Trading | Port for executable: 60727 | 2018-11-13 07:40:42
Listening socket (1224). Port 60727 | Closed. | 2018-11-13 07:40:42
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:40:42
Rithmic Trading | Bridge process is running. | 2018-11-13 07:40:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60727 | 2018-11-13 07:40:44
DTC Client socket (145) | Creating socket. | 2018-11-13 07:40:44
DTC Client socket (145) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:40:44
Rithmic Trading | Connected to server. | 2018-11-13 07:40:44
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:40:44
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:40:44
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:40:44
Rithmic Trading | Sending logon request message. | 2018-11-13 07:40:44
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:40:44
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:40:44
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:40:44
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:40:45
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:40:45
Rithmic Trading | Received logon response. | 2018-11-13 07:40:45
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:40:45
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:40:45
Rithmic Trading | Logon error received from server | 2018-11-13 07:40:45
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:40:45
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:40:45
DTC Client socket (145) | Initiating close of socket by core. | 2018-11-13 07:40:45
DTC Client socket (145) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:40:45
Rithmic Trading | Disconnected. | 2018-11-13 07:40:45
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:40:45
DTC Client socket (145) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:40:48 *
DTC Client socket (145) | Socket gracefully closed by remote side. | 2018-11-13 07:40:48
DTC Client socket (145) | Closed. | 2018-11-13 07:40:48
Rithmic Trading | Port for executable: 60742 | 2018-11-13 07:42:45
Listening socket (1224). Port 60742 | Closed. | 2018-11-13 07:42:45
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:42:45
Rithmic Trading | Bridge process is running. | 2018-11-13 07:42:47
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60742 | 2018-11-13 07:42:47
DTC Client socket (148) | Creating socket. | 2018-11-13 07:42:47
DTC Client socket (148) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:42:47
Rithmic Trading | Connected to server. | 2018-11-13 07:42:47
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:42:47
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:42:47
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:42:47
Rithmic Trading | Sending logon request message. | 2018-11-13 07:42:47
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:42:47
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:42:47
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:42:47
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:42:48
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:42:48
Rithmic Trading | Received logon response. | 2018-11-13 07:42:48
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:42:48
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:42:48
Rithmic Trading | Logon error received from server | 2018-11-13 07:42:48
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:42:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:42:48
DTC Client socket (148) | Initiating close of socket by core. | 2018-11-13 07:42:48
DTC Client socket (148) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:42:48
Rithmic Trading | Disconnected. | 2018-11-13 07:42:48
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:42:48
DTC Client socket (148) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:42:50 *
DTC Client socket (148) | Socket gracefully closed by remote side. | 2018-11-13 07:42:50
DTC Client socket (148) | Closed. | 2018-11-13 07:42:50
Rithmic Trading | Port for executable: 60785 | 2018-11-13 07:44:48
Listening socket (1580). Port 60785 | Closed. | 2018-11-13 07:44:48
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:44:48
Rithmic Trading | Bridge process is running. | 2018-11-13 07:44:50
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60785 | 2018-11-13 07:44:50
DTC Client socket (151) | Creating socket. | 2018-11-13 07:44:50
DTC Client socket (151) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:44:50
Rithmic Trading | Connected to server. | 2018-11-13 07:44:50
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:44:50
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:44:50
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:44:50
Rithmic Trading | Sending logon request message. | 2018-11-13 07:44:50
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:44:50
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:44:50
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:44:50
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:44:51
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:44:51
Rithmic Trading | Received logon response. | 2018-11-13 07:44:51
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:44:51
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:44:51
Rithmic Trading | Logon error received from server | 2018-11-13 07:44:51
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:44:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:44:51
DTC Client socket (151) | Initiating close of socket by core. | 2018-11-13 07:44:51
DTC Client socket (151) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:44:51
Rithmic Trading | Disconnected. | 2018-11-13 07:44:51
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:44:51
DTC Client socket (151) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:44:53 *
DTC Client socket (151) | Socket gracefully closed by remote side. | 2018-11-13 07:44:53
DTC Client socket (151) | Closed. | 2018-11-13 07:44:53
Rithmic Trading | Port for executable: 60812 | 2018-11-13 07:46:51
Listening socket (1672). Port 60812 | Closed. | 2018-11-13 07:46:51
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:46:51
Rithmic Trading | Bridge process is running. | 2018-11-13 07:46:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60812 | 2018-11-13 07:46:53
DTC Client socket (154) | Creating socket. | 2018-11-13 07:46:53
DTC Client socket (154) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:46:53
Rithmic Trading | Connected to server. | 2018-11-13 07:46:53
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:46:53
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:46:53
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:46:53
Rithmic Trading | Sending logon request message. | 2018-11-13 07:46:53
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:46:53
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:46:53
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:46:53
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:46:54
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:46:54
Rithmic Trading | Received logon response. | 2018-11-13 07:46:54
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:46:54
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:46:54
Rithmic Trading | Logon error received from server | 2018-11-13 07:46:54
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:46:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:46:54
DTC Client socket (154) | Initiating close of socket by core. | 2018-11-13 07:46:54
DTC Client socket (154) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:46:54
Rithmic Trading | Disconnected. | 2018-11-13 07:46:54
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:46:54
DTC Client socket (154) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:47:16 *
DTC Client socket (154) | Socket gracefully closed by remote side. | 2018-11-13 07:47:16
DTC Client socket (154) | Closed. | 2018-11-13 07:47:16
Rithmic Trading | Port for executable: 60846 | 2018-11-13 07:48:54
Listening socket (1224). Port 60846 | Closed. | 2018-11-13 07:48:54
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-13 07:48:54
Rithmic Trading | Bridge process is running. | 2018-11-13 07:48:56
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60846 | 2018-11-13 07:48:56
DTC Client socket (157) | Creating socket. | 2018-11-13 07:48:56
DTC Client socket (157) | Connecting to IP: 127.0.0.1. | 2018-11-13 07:48:56
Rithmic Trading | Connected to server. | 2018-11-13 07:48:56
Rithmic Trading | Starting socket receive thread. | 2018-11-13 07:48:56
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-13 07:48:56
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-13 07:48:56
Rithmic Trading | Sending logon request message. | 2018-11-13 07:48:56
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-13 07:48:56
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-13 07:48:56
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-13 07:48:56
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-13 07:48:57
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-13 07:48:57
Rithmic Trading | Received logon response. | 2018-11-13 07:48:57
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-13 07:48:57
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-13 07:48:57
Rithmic Trading | Logon error received from server | 2018-11-13 07:48:57
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-13 07:48:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:48:57
DTC Client socket (157) | Initiating close of socket by core. | 2018-11-13 07:48:57
DTC Client socket (157) | Shutdown started. Waiting for graceful close. | 2018-11-13 07:48:57
Rithmic Trading | Disconnected. | 2018-11-13 07:48:57
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-13 07:48:57
DTC Client socket (157) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-13 07:48:59 *
DTC Client socket (157) | Socket gracefully closed by remote side. | 2018-11-13 07:48:59
DTC Client socket (157) | Closed. | 2018-11-13 07:48:59
imagesierra-not-connecting.png / V - Attached On 2018-11-13 13:48:23 UTC - Size: 63.4 KB - 260 views
[2018-11-13 18:24:56]
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
