Date/Time: Thu, 23 Jan 2025 05:13:37 +0000
POC TPO doesn't match with POC Volume profile
View Count: 1391
[2018-11-13 11:02:38] |
User661434 - Posts: 27 |
This is my chart, its a weekly chart and the POC's doesnt match, how can this be adjusted. http://www.sierrachart.com/image.php?Image=1542106729221.png Thank You |
[2018-11-13 12:08:12] |
User907968 - Posts: 825 |
Why would you expect TPO POC and VP POC to match? They are not the same thing at all.
[2018-11-13 14:33:45] |
User138602 - Posts: 169 |
As said...not the same...why would you need 2 times the same info anyway? In FACT most interestingly would be the most obvious differences...one or two TPOs compared with huge volume...but the big institutions dont accumulate/ distribute like this...
[2018-11-13 16:30:52] |
okey, I learned and I understand it now, thanks. So If a VP POC is higher than a TPO POC, this would mean that there is selling pressure and vice versa? |
[2018-11-13 17:55:18] |
Is the question about why there is a difference between the TPO Point of Control and the Volume Point of Control. If so, the calculation methods are documented here: Time Price Opportunity (TPO) Profile Charts: How Point of Control and Value Area Are Calculated Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-13 17:55:45
