Date/Time: Thu, 23 Jan 2025 05:02:41 +0000
Exporting data
View Count: 659
[2018-11-13 07:58:06]
User723592 - Posts: 9
1.) I want to export the data of a 30min chart of the ES for the last 30 days. I only want high, low, open, close volume for each 30min bar. However, the program is always exporting every singel tick trade. what settings do I need to adjust?
please instruct...
2.) Do you have an API from which I can download/export data directly? I would need it for backtesting purposes
kind regards
hf jr.
[2018-11-13 10:45:09]
1. You need to use this particular command:
Edit Menu: Edit >> Export Bar Data to Text File
2. Refer to:
Data and Trading Communications (DTC) Protocol Server
