Date/Time: Thu, 23 Jan 2025 05:16:45 +0000
Realtime data for AMD stopped updating
View Count: 604
[2018-11-12 21:22:17] |
User816220 - Posts: 80 |
The SC realtime data feed for symbol AMD stopped updating as of 14:50:40 ET. I checked several other equities symbols; none were affected. I see up-to-date historical data when I choose "Download Data From End Of Chart", but I'm not getting streaming data for that particular symbol. |
log.txt - Attached On 2018-11-12 21:21:22 UTC - Size: 349.37 KB - 342 views |
[2018-11-12 21:53:25] |
It started updating again after disconnecting and reconnecting to the feed.
[2018-11-12 22:24:43] |
We need realize now why this happened and we are implementing a solution to it after the close.
