Date/Time: Thu, 23 Jan 2025 05:11:57 +0000
Using DTC server to feed DTC client data start to delay
View Count: 584
[2018-11-12 15:25:54]
User567294 - Posts: 47
I am using one instance as DTC server to stream data to remote client instance, but the DTC client instance start to delay after 5 mintues connection. What would be possiable problem from? only reconnect the client side,then data back to normal for about few mintues, then start delay again. I am using 1837 verion.
thanks
Rex
[2018-11-12 16:40:21]
This means there is insufficient bandwidth between the client and server. You need to resolve this.
