Date/Time: Thu, 28 Mar 2024 20:28:33 +0000
Volume by Price - Maximum Delta Bar Width
View Count: 2496
[2018-11-12 14:44:57] |
User993113 - Posts: 70 |
In the Volume by Price study, is there a way to control the Maximum Delta Bar Width independently from the Maximum Volume Bar Width? With Ninja Trader it is straight forward to have control over those settings that I can not see in the VbP study by Sierrachart. Maximum Delta Bar Width Percentage Right Align Delta Bars If you take a look at this picture it should be clear what I mean. Thank you. Date Time Of Last Edit: 2019-01-14 13:07:42
Private File |
[2018-11-13 11:45:35] |
The width of a Volume by Price volume bar is based on the Displayed Volume as defined in the Input - Volume Bar Calculation Method. Keep in mind, though, that if the Input for Bid Volume/Ask Volume Coloring Method is set to anything other than None, then the bars may be extended longer depending on the combination of these settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-18 12:31:04] |
I tryed the Dominant Bid Or Ask Volume Coloring (#2) and I see that it draws the dominant side available with Separate Bid/Ask Volume Coloring (#1). This is the total volume of the dominant side and I'm not interested in it; what I'm looking for is the Difference Of Bid And Ask Volume Coloring (#3). But as you can see in picture #3 , it is not clear so I'm asking for 1) an amplification factor of the Difference Of Bid And Ask Volume Coloring as you can see in picture #4 without the need of two different VbP studies. 2) and the option to invert the Delta profile orientation (picture #5) ; both inside the VbP settings. Thank You Date Time Of Last Edit: 2019-01-14 13:08:01
Private File |
[2018-11-19 07:44:35] |
Dingor - Posts: 13 |
great idea, sometimes it's hard to see it |
[2018-11-26 14:14:21] |
any comment by sierrachart about that? I'm just asking for a better visualization of what you already calculate. Thank you. |
[2018-12-03 14:27:56] |
User829216 - Posts: 15 |
+1 pls update SC support as I have also asked for the same. You have a fab product and it can only get better |
[2018-12-04 18:00:27] |
We need some time to review this and understand what is being requested.
[2019-01-21 07:28:58] |
Dear Support, I repeat what I'm loooking for Looking at the attached pitcure, you can see in #1 the default Volume by Price with the Bid Volume and Ask Volume Coloring Method = Difference Of Bid And Ask Volume Coloring. Because I don't have control over the width of the Difference Of Bid And Ask Volume Coloring, in #2 I had to overlay a second VbP changing the Volume Bar Calculation Method to Ask Volume - Bid Volume, that way I can control it. For this to be usable also in the Draw Volume Profile, I need two controls inside the Volume by Price study; they could be named something like: Maximum Delta Bar Width Type Maximum Delta Bar Width Percentage They both must be independent from their respective Volume Settings ( Maximum Volume Bar Width Type and Maximum Volume Bar Width Percentage) In number #3 you can see that I had set the Right Align Volume Bars options to Yes in the overlayed VbP For this I need an option independent from the Right Align Volume Bars named something like: Right Align Delta Bars Thank You Date Time Of Last Edit: 2019-02-04 10:40:28
Maximum Delta Bar Width.png / V - Attached On 2019-01-21 07:26:51 UTC - Size: 191.94 KB - 559 views |
[2019-02-04 11:35:43] |
+ 1 for post 8 request
[2019-02-04 20:09:45] |
Image 3 is what SC Engineers should be aiming for as it gives in my opinion the best way of seeing volume and delta side by side.
[2020-02-12 20:01:49] |
TeddyTornado - Posts: 6 |
Is there finally any solution after several requests from different people?
