Date/Time: Thu, 23 Jan 2025 05:09:05 +0000
drawing line synchro
View Count: 612
[2018-11-12 11:48:12] |
User831597 - Posts: 18 |
is impossible find in short time one particular small info inh very huge amount of info in suuport web board and dont want spend half of day by searching so better for me is ask ...how set horizontal line which i put in one chart to be viewed in all charts in one chartbook ...??
[2018-11-12 18:37:37] |
Refer to: http://www.sierrachart.com/index.php?page=doc/CopyingChartDrawingsFromOtherChartsAutomatically.html The Support Board search is here: https://www.sierrachart.com/SupportBoard.php?do=Search Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
