Date/Time: Thu, 23 Jan 2025 05:10:40 +0000
Murray Math / Overlay
View Count: 1027
[2018-11-12 09:44:48]
User371906 - Posts: 141
I have a Murray's Math Overlay on this chart (link below),
Is there a way to set settings so that the moving averages dont disappear in back of the overlay area?
http://www.sierrachart.com/image.php?Image=154201579468.png
Thank You
Regards
g
[2018-11-12 18:42:26]
Yes, refer to:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#StudyDisplayOrder
[2018-11-13 22:49:45]
ForgivingComputers.com - Posts: 990
You can change the grey area to a transparent fill.
[2018-11-14 02:46:43]
Yes that is another way to do it. Transparency as well.
[2018-11-14 09:11:15]
SC & Bradh,
Thank you for info.
Worked.
Kindly
g
