Date/Time: Thu, 23 Jan 2025 05:12:50 +0000
Crosshair across charts
View Count: 2104
[2018-11-12 09:09:13] |
User150852 - Posts: 38 |
When i have some charts (daily, weekly, monthly...) for a single stock, is there a way to show the crosshairs (as i move on one chart) also on the other charts? e.g. when i move on daily and look at pivot point, it is insightful to see where this point falls on the weekly, monthly... (and the other way around) |
[2018-11-12 19:55:59] |
Refer to the following: Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On)
