Date/Time: Thu, 23 Jan 2025 04:59:41 +0000
Window sizes
View Count: 2177
[2018-11-12 09:06:10]
User150852 - Posts: 38
Is there a way to Auto size all windows to fit the chart book area? when i move between machines with different resolution, i would like to be able to make them fit with a click
[2018-11-12 11:07:42]
JanS - Posts: 46
There are the options in the Window menu: Tile Horizontally, Tile Vertically and Tile as Grid. Whichever works for you, you can set as a keyboard shortcut via Global Settings > Customize Keyboard Shortcuts > Window.
[2018-11-12 12:30:02]
I want the windows to keep their ratios and relative placement. The existing options will change all that
[2018-11-12 18:17:24]
You can do what you want. Refer to the documentation here for this:
http://www.sierrachart.com/index.php?page=doc/WindowMenu.html
Date Time Of Last Edit: 2018-11-12 18:17:31
[2018-11-13 09:30:54]
So we miss something...
Attached are Capture1,
showing a chartbook saved on my 4K machine, then shown on a 1920x1080 machine. the charts have certain sizes and relationship to each other
in Capture2 i have resized the Sierra app screen so the charts are more cut...
I am look for a mode that will make the content FIT the screen, i.e. all charts to resize and move proportionally based on the App size. i do not want to have them tiled, non grid or grid, as then they will fit the screen but will loose size and relationship
imageCapture1.PNG / V - Attached On 2018-11-13 09:24:59 UTC - Size: 119.44 KB - 470 views
imageCapture2.PNG / V - Attached On 2018-11-13 09:25:09 UTC - Size: 76.72 KB - 370 views
[2018-11-13 10:53:03]
Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/WindowMenu.html#TileAsGridHorizontally
It explains how to arrange and order the charts as you require.
