Date/Time: Thu, 23 Jan 2025 02:45:29 +0000
[Programming Help] - Notepadd++ reinstalls on each SC Update?
View Count: 614
[2018-11-11 22:44:43]
User553714 - Posts: 184
Can you please consider not including Notepad++ with SC version updates? I recently upgraded NPP over the weekend to the current V7.5.9 and my SC update this morning has rolled me back to NPP V7.5.1. I also would like to keep some customization of NPP instead of losing it each time I update SC. Off course there may be reasons you do this I am not aware of. Thanks
[2018-11-11 23:00:32]
What you need to do is install Notepad++ into a separate folder and use that one. And also through Global Settings >> General Settings you can set Sierra Chart to use that installation of notepad.
Date Time Of Last Edit: 2018-11-11 23:00:47
