Date/Time: Sat, 19 Apr 2025 09:45:12 +0000
Make Chart Studies Window Bigger
View Count: 1943
[2018-11-10 18:28:33] |
ephi144 - Posts: 54 |
Would you please Make Chart Studies Window Bigger or give it ability so that we can resize it? it too small to be able to see the whole line(s) completely.
[2018-11-10 23:08:43] |
TedMar - Posts: 191 |
check this Chart Scale and Scale Adjusting: Opening the Scale Settings Window For a Study
[2018-11-11 14:52:57] |
cmet - Posts: 689 |
+1 for this. When you open the Chart Studies window for a chart, the "Studies to Graph" Area is too small and the window should be re-sizeable so you don't have to scroll to see the entire text for each study applied to the chart. Would be great if SC would save this setting as well so that it always opens to the correct size you want/use. |
[2018-11-11 22:54:33] |
All of the "Dialog" type windows in Sierra Chart are going to get redeveloped. They will no longer be based on MFC or Windows specific code. This is a task we are going to get started on as soon as is reasonable but it is a rather big task which would probably take several months. And we think we can make them resizable and in many cases modeless so you can still interact with Sierra Chart when they are open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-11 22:54:52
[2021-07-03 02:49:34] |
NJ - Posts: 20 |
Did this happen?
[2021-07-06 13:52:59] |
John - SC Support - Posts: 39362 |
Not yet for the Chart Studies window. The start of the change has occurred, as many of the Settings windows have been updated. That is the basis of the new windows, so you will recognize the change when it occurs, as the new windows will look something like the Settings windows do now.
[2023-01-20 21:10:38] |
sean3000 - Posts: 65 |
+1 I use a 4K display with the scale set to 200% for readability which makes the "Studies to Graph" section of the Chart Studies window is difficult to use. The new SC-style settings windows are superior to the MFC windows and I'm looking forward to seeing them implemented across the board. |
[2024-03-17 22:40:40] |
User525733 - Posts: 126 |
when is this happening ????? the antiquated chart studies window looks absolute trash....can't even resize it !!!! |
[2024-03-17 23:30:01] |
Sierra_Chart Engineering - Posts: 19276 |
Yes it is absolute trash. We are getting close to updating it.
[2025-03-19 13:54:09] |
Fikklish - Posts: 5 |
+1 2025 - still waiting
[2025-03-22 13:27:48] |
LucaDM86 - Posts: 4 |
still waiting for this life changing improvement...
