Date/Time: Thu, 23 Jan 2025 02:32:54 +0000
Repetitive Bars at the Open
View Count: 589
[2018-11-09 23:49:59] |
User260560 - Posts: 37 |
Hi, I have two instance of Sierra chart both using sierra chart data wtih ib. On one of the instance, for volume and tick charts, it produces several repetitive bars at market open, while the other instance works fine. I went through the support board and found a post having the same problem, so I went and changed my intraday data storage unit to 1 tick, but my chart still loads multiple same bars for volume and tick charts. Could you help me with this issue please, thanks!
Date Time Of Last Edit: 2018-11-09 23:50:44
[2018-11-10 03:05:06] |
Refer to this section here: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Repeating Bars with Number of Trades or Volume Bars And refer to: Interactive Brokers Trading Service: Using Sierra Chart Historical Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-10 03:06:21
