Date/Time: Thu, 23 Jan 2025 05:00:30 +0000
QuoteBord - DailyChange wrong
View Count: 799
[2018-11-09 21:05:38]
TedMar - Posts: 190
in Example :Daily Range is 0.64 but Daily change 0.10
image2018-11-09 21_54_56-Window.png / V - Attached On 2018-11-09 20:58:31 UTC - Size: 10.02 KB - 268 views
[2018-11-09 21:30:37]
This is what is provided by the exchange. It is accurate. A new trading day has begun.
[2018-11-09 22:01:49]
TedMar - Posts: 190
Sorry, but i understand, how i can set real DailyChange in QuotaBoard for Europa session 8-22 UTC or UTC+1 ?
[2018-11-09 22:46:36]
This cannot be changed.
[2018-11-10 02:59:04]
TedMar - Posts: 190
this is bad situation, some filds from qoutebord are unusable :(
[2018-11-12 00:42:28]
This is the official quotation data from the data feed and it cannot be changed.
Would be best that you create your own custom daily chart bars:
Chart Session Times: Creating Daily Bars with Custom Session Times
And then you look at the daily price change from bar to bar.
[2018-11-14 06:51:11]
TedMar - Posts: 190
Is it possible to replicate QuoteBoard with Spredsheet?
In fact u idea "...And then you look at the daily price change from bar to bar." is not good for >40 Quotas. I need to see diffrences on the fly between Markets and Contracts.
[2018-11-14 18:07:09]
Refer to Quote Spreadsheets:
Getting Quotes: Quotes on Spreadsheets
