Date/Time: Thu, 23 Jan 2025 02:45:23 +0000
Study Subgraph Reciprocal
View Count: 862
[2018-11-09 19:54:18] |
User50927 - Posts: 91 |
Can you add a "Study Subgraph Reciprocal" to your standard collection of formulas. Sometimes I need to flip the value of a variable other than price, for which there is "1 Divided by Price", but I can't. Thanks.
[2018-11-09 22:44:58] |
You can use the Spreadsheet Formula to accomplish what you want. Just enter in the formula =1 / IDn.SGm where n is the Study ID containing the Subgraph you want to invert and m is the Subgraph number you want to invert. You will find the documentation for the Spreadsheet Formula study here: Spreadsheet Formula Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
