Date/Time: Thu, 23 Jan 2025 02:23:39 +0000
When adding an indicator pressing the C automatically clears the entire chart :-((
View Count: 585
[2018-11-09 16:07:56]
jsoviero - Posts: 84
Hi Support,
When searching to add a another indicator that begins with the letter C, I would normally enter c on my keyboard expecting the list of indicators to jump to those indicators beginning with the letter C. Instead the chart automatically "CLEARS" all previously loaded indicators without any warning. This is a nuisance and has caused me to lose customized charts which I spent considerable time creating.
PLEASE CHANGE THIS FUNCTION TO AT LEAST GIVE A WARNING PRIOR TO CLEARING THE CHART OF ALL INDICATORS. THANK YOU
[2018-11-09 17:07:05]
This does not make any sense. There is no such problem like this. Are you referring to pressing letter C in the Analysis >> Studies window when the Available Studies list has the focus?
There is no problem with this. Whatever behavior you are experiencing, it would seem to be some kind of an issue on your side or maybe you have set up a keyboard shortcut for that letter to perform some particular action which we do not know.
Date Time Of Last Edit: 2018-11-09 17:07:41
