Date/Time: Sun, 24 Nov 2024 11:35:26 +0000
[User Discussion] - Where can I find the code for Study/Price Overlay
View Count: 1612
[2013-11-01 19:55:58]
RMF2 - Posts: 43
Hi, I'm looking for the code for the Study/Price Overlay study.
I have done a file search for a number of terms in the ACS_Source directory with no luck and I've searched the old and new boards.
Where is it located?
Thanks for your help.
[2013-11-01 20:28:27]
This is not available. We would like to make it available but it is not so simple due to various dependencies which are not part of ACSIL.
[2013-11-01 22:26:28]
vegasfoster - Posts: 444
Maybe not what you are looking for, but this one shows you how to reference studies on other charts, if that would be helpful.
attachmentBMMultiStudyScoring.cpp - Attached On 2013-11-01 22:26:07 UTC - Size: 5.32 KB - 631 views
[2013-11-02 10:46:11]
RMF2 - Posts: 43
Thanks for the replies SC Support and vegasfoster.
vegasfoster, that just might do the trick. I will try to combine it with other code to sync up timeframes and make up code similar to "Fill Blanks With Last Value"; that feature is really helpful.
[2013-11-02 13:41:41]
crazybears - Posts: 314
Hi
maybe you already saw it ,if no, take a look here :
http://www.sierrachart.com/index.php?l=doc/doc_ACSILRefOtherTimeFrames.php#DirectReferencing
[2013-11-04 12:08:55]
RMF2 - Posts: 43
Thanks, crazybears.
That's exactly the reference I had in mind.
