Date/Time: Thu, 23 Jan 2025 02:43:37 +0000
Connect Data Feed is greyed out
View Count: 1479
[2018-11-08 20:01:17]
funded-trader - Posts: 12
I have a trial account, if all goes well with the set-up will purchase Package 5.
I am having trouble connecting to Rithmic.
Rithmic Pro is open and I'm logged in successfully.
I followed your instructions:
connected Rithmic Trading with Paper Trading Server and Rithmic username and pw.
As per your instructions I should now go to File/Connect Data Feed but is greyed out.
[2018-11-09 02:38:16]
This means there is a current connection to Rithmic and you are all set. Continue with the instructions here:
Getting Started, Opening Charts and Basic Trading: Open A Chart
[2018-11-09 05:45:54]
When I go to Find Symbols it shows me only SC Exchange data.
For example I need ES and GC, but i tshould get data from Rithmic.
I have purchased now 1 month with the Package 5 to make sure it wasn't a problem with the free trial.
I've had Earn2trade to set-up data fro mRithmic for me, CME and COMEX, these should work.
Rithmic sees everything is set correctly as well.
[2018-11-09 18:26:46]
So it looks like you now have the problem resolved.
[2018-11-09 19:03:33]
yes thank you, my bad. I was looking for the wrong product in the list.
