Date/Time: Thu, 23 Jan 2025 02:29:40 +0000
Connecting to TD Ameritrade (Think or Swim)
View Count: 2289
[2018-11-08 16:50:32] |
User573770 - Posts: 8 |
I am trying to connect to TD Ameritrade to make a TPO chart for the ES futures. The SPX500 data appears to be correctly connected but I cannot obtain the ESZ18 data
[2018-11-08 16:57:34] |
Sierra Chart - Max - Posts: 5779 |
From: https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#Introduction Futures trading and real-time futures market data is *not* supported with the interface that TD Ameritrade provides to Sierra Chart and other programs. Although you can use the Sierra Chart Real-Time and Historical Exchange Data Feed, and access the real-time futures data supported by this Sierra Chart data feed when using your TD Ameritrade account. You will be able to take advantage of the lower-priced CME Group exchange fees since you are using a trading account through TD Ameritrade. The Sierra Chart Real-Time and Historical Exchange Data Feed has its own separate pricing from the Sierra Chart Service Packages and therefore is an additional cost.
Link to the Sierra Chart Real-Time and Historical Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support |
[2018-11-08 21:39:04] |
Thank you for the above information. I tried to follow the directions and put funds into the account. However I received the Failed to activate. See attachment. I could not find the License agreement mentioned in instructions. I am trying to purchase the CME with market depth for non pro trading account CME, GBLX
[2018-11-08 23:28:06] |
You need to follow the instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Before you can activate an Exchange, you need to activate the service as is shown in the above detailed step-by-step instructions. Sierra Chart Support |
