Date/Time: Sun, 24 Nov 2024 11:36:34 +0000
No data is loaded
View Count: 1287
[2013-11-01 18:17:51]
User31158 - Posts: 1
Hello, I use the demo version Sierrachart. when you run the story is loaded to the latest quotes, and then refuses to boot. is on the same level. please tell me what is necessary to fix it. (the day before it worked fine). Thank you!
[2013-11-01 20:27:02]
Restart Sierra Chart.
Select File >> Connect To Data Feed.
Provide a copy of the Message Log, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#log
