Date/Time: Thu, 23 Jan 2025 02:37:23 +0000
Problem with Connection on three workstations in the same office
View Count: 1246
[2018-11-08 15:23:22]
User722634 - Posts: 6
Hi guys.
I have 3 workstations that are connected with sierrachart to the same datafeed "rhitmic" and it doesnt work. Always it connects maximum two workstations. If i connect three, then one is disconnecting... in the attachement you can see the problem. That is the bridge. The last time i installed it, the installer said that the update is not correct... can you please help me? That problem came new. In the past we had 5 workstations working on one datafeed and it worked... so something happended after the update.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=23446
[2018-11-08 18:50:37]
That Message Log has no relevancy here. The number of connections is controlled by Rithmic. You need to work this out with them and your broker. But there are exchange rules that they have to comply with so you may not get what you want anyway.
There could be another reason for the connection problem, but the image you posted is insufficient. You need to provide the entire message log:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2018-11-08 18:56:51
