Date/Time: Sun, 24 Nov 2024 14:05:52 +0000
P&L Commission inclusion
View Count: 2743
[2013-11-01 17:13:32]
100 - Posts: 147
I was wondering if you guys would include an option to calculate the commission as a single contract entry and exit costing 1 tic. I think this would be a great feature that would allow for accurate real time calculations.
[2013-11-04 17:19:07]
You can set whatever Commission value that you require through the Global Symbol Settings:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php
It is implemented as a round turn commission per share or contract.
[2013-11-05 21:15:28]
drywater0 - Posts: 85
Is it possible to have commissions included in the P&L displayed for the Trading DOM as opposed to only in the Trade Activity Log? Thanks very much for your help.
[2013-11-06 14:20:11]
User26059 - Posts: 19
In order to set the commission amount you have to go to Chart settings/ edit global Symbol Settings/ Additional/ round Turn Commission in order to set commission cost.
The Global settings instructions do not explain exactly how to set commission cost only how to turn it on or off.
