Date/Time: Thu, 23 Jan 2025 05:14:20 +0000
Trade Activity Log
View Count: 750
[2018-11-06 13:21:39]
User228927 - Posts: 55
I saved a trade activity log. But when later try importing the saved file, it acts like it imports, but I do not see the trades in the log.
[2018-11-06 20:31:41]
What version of Sierra Chart are you running. Make sure you are running an up-to-date version:
And make sure you exported the data using the File >> Export command on the Trade Activity Log menu.
[2018-11-13 23:14:21]
Am working on version 1841, act like it is importing but trades are not in log. I did File>>Export in Trade Activity Log.
[2018-11-14 02:06:57]
Attach the file here that you are trying to import and we will test it ourselves. Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2018-11-14 02:52:58]
Here is file
attachmentTradeActivityLogExport_2018-10-30.txt - Attached On 2018-11-14 02:52:38 UTC - Size: 121.77 KB - 308 views
[2018-11-14 06:40:06]
Okay we see what the problem is. We added a new step to the instructions here:
Trade Activity Log: Importing and Exporting Data
Make sure to follow step 4. That is the issue.
