Date/Time: Thu, 23 Jan 2025 02:29:31 +0000
cannot connect to cqg data service
View Count: 616
[2018-11-06 05:32:14] |
User132538 - Posts: 2 |
I received a message to contact you because I exceeded 20 login attempts on 10 minutes and therefore I could not login to cqg data.
[2018-11-06 06:13:12] |
You need to contact your broker about this. Those messages are from CQG not Sierra Chart.
