Date/Time: Thu, 23 Jan 2025 02:30:28 +0000
Replay - Chart Appears to Be Updating Only Once a Second - In Bursts
View Count: 1020
[2018-11-05 22:37:53]
User45989 - Posts: 54
When I replay a chart utilizing tick data (DOM, Footprint), when playing at 1.00 speed, I am getting bursts of data that appear to pause every second or so. This makes replaying for practice unrealistic.
To try and solve the problem I have:
- tested on two different machines.
- ensured that virus checking was turned off (Windows Defender)
- ensured that the chart update interval setting is at a high enough resolution
I can provide a video to demonstrate the issue if requested.
[2018-11-06 15:59:52]
I should add that I am using a 1 Tick intraday data storage time unit in the Data/Trade Service settings and am using IQFeed as my data source.
[2018-11-06 18:43:06]
Refer to:
http://www.sierrachart.com/index.php?page=doc/ReplayChart.html#HistoricalIntradayDataRecordTimeframeEffect
Due to how the time stamping is done it does make sense that you would see one second at a time with a replay speed of 1. This will be improved upon in the coming months. There is nothing you can do now.
Date Time Of Last Edit: 2018-11-06 18:43:40
