Date/Time: Thu, 23 Jan 2025 02:28:52 +0000
unable to connect
View Count: 719
[2018-11-05 15:36:42]
User391787 - Posts: 3
Rithmic Trading | Port for executable: 50116 | 2018-11-05 14:54:12
Listening socket (1784). Port 50116 | Closed. | 2018-11-05 14:54:12
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-05 14:54:12
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50116. Current folder: C:\SierraChart\Rim | 2018-11-05 14:54:12
DTC Client socket (1) | Socket gracefully closed by remote side. | 2018-11-05 14:54:13
DTC Client socket (1) | Closed. | 2018-11-05 14:54:13
Rithmic Trading | Bridge process is not running! | 2018-11-05 14:54:14
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50116 | 2018-11-05 14:54:14
DTC Client socket (1) | Creating socket. | 2018-11-05 14:54:14
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2018-11-05 14:54:14
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-11-05 14:54:15 *
DTC Client socket (1) | Signaling to core to close socket | 2018-11-05 14:54:15
DTC Client socket (1) | Closed. | 2018-11-05 14:54:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-05 14:54:15
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-05 14:54:15
Rithmic Trading | Disconnected. | 2018-11-05 14:54:15
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-05 14:54:15
[2018-11-05 17:12:18]
This log is incomplete and is not useful.
Provide a copy of the Message Log by following these instructions:
Date Time Of Last Edit: 2018-11-05 17:12:28
[2018-11-05 17:20:43]
Reading Internal Order ID file. | 2018-11-05 14:50:01
Reading Trade Orders file. | 2018-11-05 14:50:01
Reading Trade Positions file. | 2018-11-05 14:50:01
Account Balance file. | 2018-11-05 14:50:01
Listening on UDP port 22903. | 2018-11-05 14:50:01
Software version: 1834 64-bit | 2018-11-05 14:50:01
Usage end date: 2018-11-26 | 2018-11-05 14:50:01
Enabled for: Advanced Features. | 2018-11-05 14:50:01
Enabled for: Sierra Chart Historical Data Service. | 2018-11-05 14:50:01
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-11-05 14:50:01
Enabled for: INDEXES_DATA_BARCHART | 2018-11-05 14:50:01
Enabled for: CBOE Indices | 2018-11-05 14:50:01
Received 1 data feed usernames. | 2018-11-05 14:50:01
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-11-05 14:50:01
Current selected Data/Trading service: Rithmic Trading | 2018-11-05 14:50:01
Chart Update Interval: 500 | 2018-11-05 14:50:01
Time Zone: +00:00:00 (UTC+00) | 2018-11-05 14:50:01
2018-11-05 08:50:00 Local computer time | 2018-11-05 14:50:01
2018-11-05 14:50:00 Local computer time in UTC | 2018-11-05 14:50:01
2018-11-05 14:50:00 Local computer time in SC Time Zone | 2018-11-05 14:50:01
2018-11-05 14:49:55 Server time in UTC | 2018-11-05 14:50:01
Local computer UTC time and Server UTC time difference: 4 seconds. | 2018-11-05 14:50:01
Program path: C:\SierraChart\ | 2018-11-05 14:50:01
Data Files path: C:\SierraChart\Data\ | 2018-11-05 14:50:01
OS Version Number: 10.0 | 2018-11-05 14:50:01
Locale Setting: C | 2018-11-05 14:50:01
Rithmic Trading | Port for executable: 51328 | 2018-11-05 17:15:33
Listening socket (1464). Port 51328 | Closed. | 2018-11-05 17:15:33
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-05 17:15:33
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51328. Current folder: C:\SierraChart\Rim | 2018-11-05 17:15:33
Rithmic Trading | Bridge process is running. | 2018-11-05 17:15:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 51328 | 2018-11-05 17:15:35
DTC Client socket (1) | Creating socket. | 2018-11-05 17:15:35
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2018-11-05 17:15:35
Rithmic Trading | Connected to server. | 2018-11-05 17:15:35
Rithmic Trading | Starting socket receive thread. | 2018-11-05 17:15:35
Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-05 17:15:35
Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-05 17:15:35
Rithmic Trading | Sending logon request message. | 2018-11-05 17:15:35
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-05 17:15:35
Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-05 17:15:35
Rithmic Trading | Message from server: Connecting to Rithmic 01 US server. | 2018-11-05 17:15:35
Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-05 17:15:36
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-05 17:15:36
Rithmic Trading | Received logon response. | 2018-11-05 17:15:36
Rithmic Trading | Server Name: DTC Bridge. | 2018-11-05 17:15:36
Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-05 17:15:36
Rithmic Trading | Logon error received from server | 2018-11-05 17:15:36
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-11-05 17:15:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-05 17:15:36
DTC Client socket (1) | Signaling to core to close socket | 2018-11-05 17:15:36
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-05 17:15:36
Rithmic Trading | Disconnected. | 2018-11-05 17:15:36
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-11-05 17:15:36
DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-11-05 17:15:38 *
DTC Client socket (1) | Socket gracefully closed by remote side. | 2018-11-05 17:15:38
DTC Client socket (1) | Closed. | 2018-11-05 17:15:38
Rithmic Trading | Port for executable: 51351 | 2018-11-05 17:17:36
Listening socket (1460). Port 51351 | Closed. | 2018-11-05 17:17:36
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-05 17:17:36
Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:51351. Current folder: C:\SierraChart\Rim | 2018-11-05 17:17:36
Date Time Of Last Edit: 2018-11-05 17:26:23
[2018-11-05 17:25:46]
You are getting a permission denied error from Rithmic:
Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2018-11-05 16:53:03
Refer to:
Rithmic Trading Platform Service: Permission Denied Resolution Procedure
Date Time Of Last Edit: 2018-11-05 17:25:52
