Date/Time: Thu, 23 Jan 2025 02:26:34 +0000
Spread - 3 charts indicator cannot handle negative values.
View Count: 1484
[2018-11-05 10:28:32] |
User644165 - Posts: 25 |
Hi All, I would like to see the bund-bobl-shatz butterfly spread chart. The correct value should be(5*159.58 - 10*131.28 + 20*111.965 = 1724.4) but instead it calculates (5*159.58 + 10*131.28 + 111.965*20). In this spread I am selling DLZ18 agains DBZ18 and DGZ18. Please see screenshot below. http://prntscr.com/lejsfa Can you please fix it? Thanks. |
[2018-11-05 17:52:21] |
You already have the capability to do this by using a negative Chart # Multiplier: Spread - 3 Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-07 07:30:56] |
But as you can see on in the screenshot, I was using the Spread -3 charts indicator with negative values, but it didt do the math correctly. Please see screenshot below. http://prntscr.com/lejsfa Thanks. |
[2018-11-07 19:38:45] |
Use this study instead: Combination Symbol Chart
