Date/Time: Sun, 08 Sep 2024 03:50:47 +0000
[User Discussion] - Volume on Price not working on continuous charts
View Count: 1818
[2013-11-01 08:17:09] |
User34424 - Posts: 21 |
I just downloaded the latest version of Sierra but I had this bug on version 1014 too When I set any chart to continuous my VoP disappears I tried it using both Rithmic and Open E Cry but it looks the same |
[2013-11-01 20:29:04] |
On the chart you are referring to, add the "Volume" study and then post an image of it, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-05 19:24:56] |
http://www.sierrachart.com/image.php?l=1383679417962.png The missing study is Volume by Price |
[2013-11-06 21:55:43] |
We are going to need to get your Chartbook to test this. Create a Chartbook that contains only a single chart demonstrating this problem and attach it here, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-06 21:59:43] |
Here you go
bug.cht - Attached On 2013-11-06 21:59:36 UTC - Size: 304.48 KB - 461 views |
[2013-11-07 16:53:31] |
After we took off all of the studies and chart drawings off of the chart in order not to confuse us, we do see the Volume Profile: http://www.sierrachart.com/image.php?l=1383843170733.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-07 16:57:35] |
We even see the Volume Profile with the Continuous Futures Contract option enabled: http://www.sierrachart.com/image.php?l=1383843424593.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-07 23:03:53] |
Sorry I forgot to check the "continuous" option |
bug.cht - Attached On 2013-11-07 23:00:41 UTC - Size: 304.48 KB - 486 views |
[2013-11-12 19:03:22] |
Any solution?
[2013-11-12 20:00:22] |
Yes. We tested this and we saw no issues. Refer to posts 6 and 7 above. Our recommendation is to remove all of the studies from the chart other than the Volume by Price study and all of the chart drawings with Tools >> Erase All Lines and you should see the study. Maybe it is being covered over by all of the other stuff you have on the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-12 20:00:34
[2013-11-12 20:02:24] |
Can you see the contentious chart using Rithmic? I can't |
