Date/Time: Thu, 23 Jan 2025 02:44:54 +0000
When drawing RECTANGLE - there are no borders anymore.
View Count: 709
[2018-11-05 07:25:37]
NCooley - Posts: 20
Rectangle, Extending Rectangle both DONT have borders WHEN DRAWING/MOVING/ADJUSTING them.
ANy idea what setting ive changed or NEED to change? This happened from update.
Thank you
[2018-11-05 21:53:48]
John - SC Support - Posts: 37420
The border is controlled by the Width setting on the Chart Drawing Properties/Configuration pages. When set to 0 the border will not display. This is described in the section Options >> Outline >> Color/Style/Width: under this link: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle Configuration
[2018-11-06 00:08:46]
NCooley - Posts: 20
Thank you very much!! I kinda remember putting them to 0. Not sure why. Ahh this is great.
