Date/Time: Fri, 24 Jan 2025 03:49:25 +0000
Stock option data?
View Count: 1425
[2018-11-05 04:09:18]
User389493 - Posts: 16
I would like to see some stock option charts on Sierra Chart. Can I do this using Sierra data?
Otherwise, I have an IB account, and tried connecting it to Sierra. It connected, but I couldn't figure out the correct symbols for stock options.
So what might be the simplest and most efficient way to reliably study stock option charts on Sierra Chart? If the answer is to use IB data, where might I find info on the correct symbols?
[2018-11-05 17:18:03]
The best way is for us to add a feature to request the available options for an underlying symbol from TWS. We will see if we can get this done in the next couple of weeks.
We have been meaning to do this with Interactive Brokers.
For now here is the options format:
Interactive Brokers Symbols: Stock Format
Date Time Of Last Edit: 2018-11-05 17:18:30
[2018-11-05 21:10:48]
Thanks for that. How will I know when the new feature has been added? Or where, in Sierra Chart, will this option appear?
[2018-11-06 20:45:43]
Check back in about a month.
[2019-01-05 06:42:15]
On Nov 5, you said,
"The best way is for us to add a feature to request the available options for an underlying symbol from TWS. We will see if we can get this done in the next couple of weeks. We have been meaning to do this with Interactive Brokers."
Have you done this yet? In particular, I want to see some stock options in Sierra Chart using IB data.
If you've added this, how do I access it?
Thanks.
