Date/Time: Wed, 22 Jan 2025 23:24:51 +0000
Table/Columnar data overlay on chart
View Count: 543
[2018-11-04 17:27:36] |
jaxscott - Posts: 57 |
I'm trying to overlay a table of columnar data (ADR averages over 1, 3, 5, 10, 20 days) on my daily chart. I know I can put 5 Text Display For Study studies and position them by eye, but I wonder if there is a way to put a table or columnar format of the data so resizing the chart doesn't disturb the spacing. i.e. it looks much neater if there were a consistent display of data rather than the dynamic respecting that happens when the chart is maximized, etc.
[2018-11-04 21:58:36] |
Really we recommend that you have a look at the Study Summary window instead: Study Summary Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
