Date/Time: Thu, 23 Jan 2025 02:42:23 +0000
ver 1835 32-bit Flat to Flat is back, needs some attention
View Count: 797
[2018-11-04 14:33:59] |
User7817001 - Posts: 96 |
Thanks for Flat to Flat Please see attached for visual details. The 'Summary Trades Only For Trades List' enabled (flat to flat) in the Trade Activity Log > Trades tab > Trade Quantity for the recent closed trade(s) is not counting (summing) the last trade, until the next trade is opened and closed. After the next trade is closed, then the Trade Quantity is accurate. To test, go into sim mode, open two or three separate positions, then flatten them, then verify the accuracy of the Trade Quantity by comparing to Max Open Quantity or manually add the trades with 'Summary Trades Only for Trades List' disabled. You will find the last trade in the series is not accounted for. Then without doing anything else, open a few more positions, close them with flatten, and look back on at the 1st trade series, the Trade Quantity and Max Open Quantity will now be aligned, and this more recent trade series will be inaccurate, until the next trade. Thanks Mark |
Attachment Deleted. Capture.JPG / V - Attached On 2018-11-04 14:33:26 UTC - Size: 150.57 KB - 351 views |
[2018-11-05 00:45:04] |
We are not seeing this issue now so most likely we fixed it. There is more code review and some changes we are doing and we did fix one item which may be related to this.
[2018-11-05 10:15:18] |
1836 32-bit (25102M) Issue resolved Also, study "Trading: Profit/Loss Text" was also inaccurate in the past versions, it too appears to be accurate now (so far). Thank you Mark |
[2018-11-05 10:31:52] |
Also, study "Trading: Profit/Loss Text" was also inaccurate in the past versions, it too appears to be accurate now (so far). It would seem more likely that there was some other explanation for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-05 10:32:21
[2018-11-05 11:41:52] |
I'll take it, no matter what the reason :)
